04-27-2012, 04:44 PM
#12526 |
800 (Ironhide!)
Oddometer: 12
04-27-2012, 05:55 PM
#12527 | |
Oddometer: 356
I run K60 scouts on my F800gs,,,great wear rate,good on the black stuff and off road...no mud here, only sand so cant help you there. going to be in Finland at the end of july sent you a PM reef |
04-28-2012, 02:11 AM
#12528 |
Tigers R great.
I'll chip in for the K60. Thy a great all round tyre. Although I've just changed the front to a Mefo explorer because, although it looks the same as a K60, it has smaller tread blocks. The K60 front does wander in soft mud. The Mefo has a softer carcass and, therefore, flexes more and is better when I ran it at 20psi two weekends ago. Also, the Mefo seems to NOT wear at all. It's taken well over 1000 miles to get rid of the molding frills.
2002 Tiger955i in black, 69000 miles. 2012 Tiger800XC in black, 19000 miles. Bike history [(N) = bought new] :- YAS1, RD350B(N), XS750(N), XT500, XJ650(N), XJ900S(N), CBX750, XL185S, XR250RF, XR600, KTM600LC4, TDR250, R100GS, TS200R, Tiger955i(N), Scrambler900efi, Tiger800XC(N)... |
04-28-2012, 03:25 AM
#12529 | |
Oddometer: 12
It appears that the K60's are worth of their reputation -> long lasting good traction. Keep on riding Masi |
04-28-2012, 07:52 AM
#12530 |
Oddometer: 596
Yep - Easier ABS disabling & ambient temp display would be my vote. The ODO issue...? it stares at you for a few seconds EVERY time you turn the key on - good enough for me. Ordered a temp guage handle bar clip, pg 110, 2012 catalog, from AEROstitch, $10. Will see how it works.
04-28-2012, 12:12 PM
#12531 |
armchair asshole
Oddometer: 2,700
Only difference was a trip to the hardware store was the fix and not a 6 month wait. Works great otherwise. Still, a boneheaded move by someone at HB. The vendor I bought it from notified them of the issue. I suspect someone just put the wrong springs in the kit because they were not even close to fitting.
04-28-2012, 01:39 PM
#12532 |
armchair asshole
Oddometer: 2,700
tune ecu
I was trying to connect to my ECU today with TuneECU to install the latest map that has recently been mentioned in this thread and kept getting an error about not being able to connect. Drivers installed etc... I think I may have an incorrect obdII cable. I believe there are two kinds? Can someone who successfully connects to their bike post a link to the cable they bought? Thanks
04-28-2012, 02:32 PM
#12533 | |
Where we riding to?
Oddometer: 3,572
04-28-2012, 03:57 PM
#12534 |
armchair asshole
Oddometer: 2,700
04-28-2012, 06:40 PM
#12535 |
AKA-Crazy Old Man
Oddometer: 208
Here is the one that I used, just don't use the software that comes with the cable, TuneECU software should connect itself.
http://www.ebay.com/itm/Triumph-Bike...item35afd40c21 Jerry
67 going on 25 and Retired ![]() |
04-29-2012, 07:07 AM
#12536 | |
Deputy Cultural Attaché
http://www.amazon.com/gp/product/B00...ls_o04_s00_i00
Successfully surviving motorcycling since 1976. |
04-29-2012, 08:27 AM
#12537 | |
armchair asshole
Oddometer: 2,700
04-29-2012, 08:36 AM
#12538 |
The Flying Dutchman
Oddometer: 141
I bought a cable on Amazon and could not get it to work. The cable had some kind of chip in it that would not allow it to work with the TuneECU drivers. I ended up buying a second cable on Ebay from "gameadvance".
http://www.ebay.ca/itm/320785937779?...84.m1439.l2649 As soon as I plugged it in everything connected just fine. So beware, not all cables are the same.
WITHOUT RISK........THERE IS NO ADVENTURE |
04-29-2012, 08:51 AM
#12539 | |
Dreamer
Oddometer: 7
SW-MOTOECH EVO Topring concern
![]() I was expecting the simplicity of a quick pin to release the bag, but it has a rotary mechanism that actuates four dogs that release the bag. My main concern is with the release pull cord that routes through the body of the mount. If (when) this cord fails there is no way to release the bag. I hate it when manufacturers make designs more complex with little to no benefit in function. Has anybody with this topring had any issues? Share my concerns? |
04-29-2012, 08:55 AM
#12540 | |
Oddometer: 431
