07-21-2012, 10:19 AM
#13666 |
Oddometer: 1,841
Spacers groove. How bad is it? Flip it if you can and keep running it. Problem I've always seen is that from the factory they don't grease them enough. Keep them greased and clean and you'll be gravy. I wouldn't make any out of harder material.
Ride 365 LLC Braaaap! |
07-21-2012, 11:03 AM
#13667 | ||
Yes its dirty, thanks.
Oddometer: 1,495
I am in the same boat as the other guy, I have flipped mine and now both sides are grooved pretty good. Mine are greased and clean and still develop grooves from a weekend of dirt riding. I am surprised you aren't seeing it on yours as you ride the dirt a fair amount. Making steel spacers is very common on many bikes to prevent exactly what we are experiencing. The GS 800s were having a similar problem leading to bearing failure, now a few companies make stainless ones. The xc bearings are sealed so it shouldn't be so drastic for us. Getting steel spacers is the obvious choice to take care of this problem, I am not sure why you recommend not changing them.
2012 Tiger 800XC 04 DRZ400S |
07-21-2012, 11:53 AM
#13668 |
armchair asshole
Oddometer: 2,536
If there was enough of a demand I could model the spacers and find out how much they would cost to get made out of 304SS from one of the local machine shops that I've dealt with. I am guessing pricing would be similar to the bike bandit price unless there were demand for more than say 50.
07-21-2012, 12:20 PM
#13669 |
Oddometer: 497
That's my thought too. When you increase the hardness of the spacer, what becomes the sacrificial part? I've got 9k miles on mine and no problems with the minor grooving. We'll see, I plan to keep and eye on it. |
07-21-2012, 01:34 PM
#13670 |
Oddometer: 1,495
The only thing causing the problem is the lip of the seal where it touches the spacer. I don't see what you are worrying about sacrificing? Either the seal and aluminum spacer wear, or just the seal wears in the case of using stainless. Am I missing something here?
07-21-2012, 01:59 PM
#13671 |
Oddometer: 497
I could be the one missing something, but I'm definably not worried.
![]() Like I said, I plan to keep an eye on it. After 9,000 miles though, it really doesn't seem to be anything to worry about. |
07-21-2012, 02:07 PM
#13672 |
Risk Taker
Oddometer: 1,104
After 18,700 miles of riding, I finally had to do a trail side flat repair.
![]() ![]() This worked awesome!!! I worked the tire away from the rim just a bit to that safety lock deal. Lean the bike over and the bead popped with out any issue. Super easy! ![]() ![]() New tube installed and re-inflating. ![]() 52 minutes. Back on the road! ![]() I'll be doing the tubeless mod this week when I pull the 21 in. tube out of the rear. This would have been an easy plug and go.
2011 Triumph 800 XC 2007 Honda CRF 250X 1994 Kawasaki KLX 650R THE ADVENTURES OF TYSON AND HOBBES THE BACKCOUNTRY PURSUIT- Boise, Idaho's consignment specialist for ADV gear! |
07-21-2012, 02:34 PM
#13673 | |
STILL Jim Williams
Oddometer: 5,951
![]() Looks like a great mod. I just wonder how reliable it will prove to be! |
07-21-2012, 03:15 PM
#13674 | |
Sim Sala Bim
Oddometer: 3,377
The square required a bit of effort to remove but came away cleanly. I applied the fast cure 5200 to the void and waited 2 1/2 hrs.. This stuff sets way faster than the regular. Installed tire, filled bathtub up 8" and bubble tested tire (if you are married and care about that relationship, wait til your wife goes shopping for a couple of hours). Good. Road test tire-All good. I have yet to take a ride over 100 miles non-stop with the spokes sealed so I can't speak to that aspect of endurance-yet. So maybe if one of you guys wants to do an Iron Butt run.... I'll keep you updated. ![]() ![]()
Inconsequential Adventurer Upon us all a little rain must fall. L.Z. |
07-21-2012, 07:08 PM
#13675 | |
Sim Sala Bim
Oddometer: 3,377
Can I get a closeup of your GPS mount attachment (over instrument cluster) from the back/windscreen side? Thanks, Tom
07-21-2012, 08:41 PM
#13676 | |
Oddometer: 1,841
Mine are not very grooved and I have 13k on my Tiger. Don't know why. I always use good grease and use it generously when reinstalling. I also get them very clean before remounting.
07-21-2012, 11:20 PM
#13677 | |
Oddometer: 104
![]() AvMech, I salute you. I don't have any experience with these size tires/wheels but I do my own changes with a no mar on my street bikes. The Tiger is my first bike with tubes. I am planning a trip to Yellowstone with a bud next month and thought mounting up the E07's I bought would be good practice so I tried to do them both with spoons. The front was not too bad but the rear kicked my ass. I gave up and finished it on the no mar.
Flying Dave screwed with this post 07-21-2012 at 11:28 PM |
07-22-2012, 04:49 AM
#13678 | |
Oddometer: 497
sure thing! |
07-22-2012, 04:56 AM
#13679 | |
Oddometer: 497
32/36 At these pressures I get modest heating and pressure increases on the highway. They still look new at 1500 miles. I drop into the mid 20's for extended dirt, but short runs at HWY pressure have been fine. |
07-22-2012, 07:12 AM
#13680 | ||
Let's Ride
Oddometer: 875
