Go Back   ADVrider > Bikes > Beasts > The British Invasion: Triumph Tigers
Old 07-27-2012, 08:05 PM   #13741
fbj913
I ride
fbj913's Avatar
Oddometer: 2,358
Originally Posted by PYG RYDR View Post
I did a thread search without success.
So what rear tube do you prefer for our XC?
TIA
One that holds air
I still have both stock tubes in mine after 13,000+ miles they are still truckin along. Michelin makes a good tube.
fbj913 is offline   Reply With Quote
Old 07-28-2012, 12:12 AM   #13742
av_mech
Risk Taker
av_mech's Avatar
Oddometer: 1,143
I'm not a fan of heavy duty tubes. They are harder to install, heavier to carry as spares, and I never fun a low enough tire pressure to worry about a pinch flat. Also, it won't protect against a puncture, which is your most common flat. I agree with fb, any one that holds air.
2011 Triumph 800 XC
2007 Honda CRF 250X
1994 Kawasaki KLX 650R
THE ADVENTURES OF TYSON AND HOBBES
THE BACKCOUNTRY PURSUIT- Boise, Idaho's consignment specialist for ADV gear!
av_mech is offline   Reply With Quote
Old 07-28-2012, 03:42 AM   #13743
motomuppet
Oddometer: 467
anyone used a Metzler Sahara 3 on the front of their 800xc? I just found 90/90 - 21 in my store room I forgot I had and was thinking it should work well no?
motomuppet is offline   Reply With Quote
Old 07-28-2012, 05:18 AM   #13744
RichardU
Let's Ride
Oddometer: 903
Originally Posted by av_mech View Post
I'm not a fan of heavy duty tubes. They are harder to install ...
I always put the tube in the tire before I put the tire on the rim. You won't need to stuff the tube in later and risk having it twisted. And heavy duty tubes are no more difficult -- maybe slightly easier.
RichardU is offline   Reply With Quote
Old 07-28-2012, 05:21 AM   #13745
fbj913
I ride
fbj913's Avatar
Oddometer: 2,358
unless you have to change the tube and not the tire. heavy duty tubes are harder to twist anyway.
Old 07-28-2012, 06:22 AM   #13746
Mercury264
Once you go Triple...
Mercury264's Avatar
Oddometer: 22,170
+1
Little bit of air to help them keep their shape and they go in just fine. I do agree they are much heavier and bulkier to carry as spares though so I generally only carry regular tubes as spares.
'12 Tiger 800XC
'07 TE510
'02 Sprint ST
'99 XR650L
'99 Speed Triple
Mercury264 is online now   Reply With Quote
Old 07-28-2012, 06:23 AM   #13747
Bueller
Cashin?
Bueller's Avatar
Oddometer: 17,276
1) Install one bead of the tire on the wheel
2) Stuff tube inside tire, and valve stem through hole in rim
3) Inflate tube to get out all of the wrinkles
4) remove valve core to deflate tube
5) Install 2nd bead of tire
I come from Harley land, where we dealt with tons of tubes. I know there are other ways to do it, but when we used that method we didn't wind up with pinched tubes.
"Bueller, you're an island of sense in a sea of bullshit" - swimmer
"bueller, you ARE an island of reason in a sea of bullshit" - quasigentrified
Bueller is offline   Reply With Quote
Old 07-28-2012, 08:23 AM   #13748
bross
Where we riding to?
bross's Avatar
Oddometer: 4,550
Neither am I but that's the only one they had in stock so I just bought it. I usually just run regular tubes as well.
Old 07-28-2012, 11:39 AM   #13749
Rob Dirt
More or less in line
Rob Dirt's Avatar
Oddometer: 2,567
Who has ran out of gas & did it hurt anything? Where you able to tilt the bike & find more usable fuel?
Heart of Dixie
Rob Dirt is offline   Reply With Quote
Old 07-28-2012, 11:49 AM   #13750
Picky28
Oddometer: 7
Hi all. My first post here
I'm a super sport rider who got the bug of dual sports and adventure riding after going for a ride with friends who ride BMW and KTM's.
I test roade the F800GS and Tiger XC and plan on buying the Tiger XC in a couple of weeks.
I wanted to know if the 2013 models have come out and if not, when are they coming out. I'm in California if that makes any difference.
Picky28 is offline   Reply With Quote
Old 07-28-2012, 12:25 PM   #13751
fbj913
I ride
fbj913's Avatar
Oddometer: 2,358
yes, no it won't hurt anything. why would it? didn't try to find more.
Old 07-28-2012, 01:06 PM   #13752
live2ridetahoe
RN
live2ridetahoe's Avatar
Oddometer: 1,466
I have heard no changes for upcoming 2013 models. Might be worth finding a closeout on 2012s when the time is right. Welcome to the club!
JG
live2ridetahoe is offline   Reply With Quote
Old 07-28-2012, 01:30 PM   #13753
Rob Dirt
Rob Dirt's Avatar
Oddometer: 2,567
It says in the book "don't run out". I can imagine air entering the fuel rails not being a good thing. Just curious about any side effects or extra gas not usable.
Heart of Dixie
Old 07-28-2012, 01:43 PM   #13754
cug
Oddometer: 4,879
It's normally only a problem with diesels if you run out. If you run low the fuel pump might not be cooled anymore, therefore running hot. I'm not certain whether that's the same concept as with the Beemers, but there it's not recommended running super low all the time just for this.
cug is online now   Reply With Quote
Old 07-28-2012, 01:58 PM   #13755
T
stay classy
T's Avatar
Oddometer: 5,398
When in doubt go to the British Triumph Forums. Those guys get to experience our problems a year in advance....
It seems that the Tiger 800's and XC's will not start if the fuel is not registering. Fuel not registering can be caused by being out of fuel, of course, and by a weak or dead battery. It appears that the ECU must read the fuel gauge in order for the bike to start.
If the fuel gauge reads zero, it won't start. If you have disconnected the battery or it has lost some voltage your ECU will shut down, when you switch on you need to tell the ECU that there is fuel available. The ECU can only check the fuel if the fuel is moving about (don't ask why). That's why you have to sit on the bike and preferably shake it from side to side with the ignition switched on until the fuel gauge starts to move.
Had the same issue myself after not using the bike during the snow and forgetting to plug the Optimate (Battery Tender) in. The battery does not need to get completely flat for this to happen, just drop in voltage a little.
One person reported they had to wheel the bike around in a circle to get the fuel to show on the gauge. Once the fuel gauge starts registering, the bike will start.
Inconsequential Adventurer
T is offline   Reply With Quote
Times are GMT -7.   It's 05:35 PM.
