Old 07-26-2012, 04:47 AM   #13786
internalcombust
Yes its dirty, thanks.
internalcombust's Avatar
Oddometer: 1,495
Originally Posted by av_mech View Post
No going back now. The valve stem hole is drilled out and the 5200 is curing. I wish I could have found the fast dry stuff cause I may actually have the weekend off and the rim will still be curing. I took a lot of pics and I'll do a full DIY with a few things that I would recommend doing differently.
Definitely keeping an out eye out for this thread and long term success.
2012 Tiger 800XC
04 DRZ400S
internalcombust is offline   Reply With Quote
Old 07-26-2012, 04:51 AM   #13787
ABHulgan
The Flying Mythos
ABHulgan's Avatar
Oddometer: 979
"I tried to move my mind there and nowhere else and imagine a single detail that, if I didn't see it that weekend, I never would... The world is easily lost."
James Dickey
ABHulgan is offline   Reply With Quote
Old 07-26-2012, 05:47 AM   #13788
PirateJohn
Radical centrist
PirateJohn's Avatar
Oddometer: 21,234
Originally Posted by RichardU View Post
Now you're really trying to start a fight.
I use this: http://www.webbikeworld.com/t2/motor...chain-lube.htm
Really! ;)
Special chain lube like that makes sense.
40 years ago when I was a young bicycle racer many of us used gasoline to clean chains and WD-40 to lube them, then the word went around that both products removed existing lubricants and were a bad idea. The word was that most mechanics on professional teams cleaned chains in diesel fuel, so that's what I started to do.
Just FYI you would be surprised at the amount of friction there is in a poorly maintained chain.
PirateJohn --
http://www.PirateJohn.com
IBA #7552 - SS1K in 2000 and 50CC in 2002
In the Laredo, TX area and always willing to help travelers escaping into Mexico.
PirateJohn is offline   Reply With Quote
Old 07-26-2012, 09:15 AM   #13789
Bueller
Cashin?
Bueller's Avatar
Oddometer: 16,328
I'd never used an auto chain oiler on any bike until yesterday. I got a loobman for less than 30 bucks delivered and figured what the hell, I'll try it. I installed it on my roadie last night. Bit of a PITA but seems to do a good job of keeping the chain lubed. I used BMW synthetic gear lube because I no longer have a shaftie and have nothing to use the gear lube on, but come to think of it considering BMW FD issues now my chain will probably fail
"Bueller, you're an island of sense in a sea of bullshit" - swimmer
Bueller is offline   Reply With Quote
Old 07-26-2012, 09:25 AM   #13790
swimmer
armchair asshole
swimmer's Avatar
Oddometer: 2,554
Originally Posted by Mercury264 View Post
Never understood the fascination with oiling chains when modern O and X-ring chains are sealed units. Sure, oil them to stop rust on the outside but aside from that, they don't need oiling as much as folks think they do.
So, assuming when you lube your chain you rotate the back wheel by hand you don't notice any difference in how freely it rotates before/after lubing?
I've put off of adding my pro-oiler to my tiger but I am now planning on doing it. I've used it on my 3 previous motorcycles. The benefits/disadvantages of chain oilers has been discussed elsewhere so I am not going to get into it. And not all oilers are created equal. If you want your motorcycle to operate efficiently with minimal chain friction and without the normal increase in friction between lubing a good chain oiler can provide this with minimal mess.
swimmer is offline   Reply With Quote
Old 07-26-2012, 09:47 AM   #13791
acap650
acap650
acap650's Avatar
Oddometer: 354
I've been using Loobman for several years. They are messy and the recomended system for mounting to swingarm is stupid, but they work. I've done installs on several bikes and have always found a chainguard bolt that serves as an attaching point for the delivery piece near the rear sprocket. The ziptie whiskers rubbing on the sprocket usually need to be replaced at rear tire replacement time. I use whatever leftover oil I have - gear lube is good for hot weather and ATF works well in the cold. Folks who like a clean rear wheel should look elsewhere but oil is not sticky like chain lube and is easily cleaned with S100 or WD40. Never having to spray the chain is priceless, especially on long trips. I'll never go back.
acap650 is offline   Reply With Quote
Old 07-27-2012, 11:57 AM   #13792
bross
Where we riding to?
bross's Avatar
Oddometer: 3,508
Little ride
My wife and I took the afternoon off and did a little exploring. Love this bike on these roads.
Old 07-27-2012, 03:56 PM   #13793
PYG RYDR
Adventure-Dual Sport
PYG RYDR's Avatar
Oddometer: 263
Question Rear Tubes
I did a thread search without success.
So what rear tube do you prefer for our XC?
TIA
PYG RYDR
T800XC-VFR800-XR650L-WR250R
MSTA-NVR
There are two things to aim at in life: first, to get what you want; and, after that, to enjoy it.
Only the wisest of humans achieve the second.
Logan Pearsall Smith
PYG RYDR is offline   Reply With Quote
Old 07-27-2012, 04:29 PM   #13794
bross
Where we riding to?
bross's Avatar
Oddometer: 3,508
TIA
I just bought this one from Motorcycle Superstore...
Pirelli Heavy Duty Inner Tubes
Color- --, Size- 130/140/150/160-17br /> SKU#403662
Old 07-27-2012, 08:05 PM   #13795
fbj913
fbj913's Avatar
Oddometer: 1,842
TIA
One that holds air
I still have both stock tubes in mine after 13,000+ miles they are still truckin along. Michelin makes a good tube.
Ride 365 LLC
Braaaap!
fbj913 is offline   Reply With Quote
Old 07-28-2012, 12:12 AM   #13796
av_mech
Risk Taker
av_mech's Avatar
Oddometer: 1,104
I'm not a fan of heavy duty tubes. They are harder to install, heavier to carry as spares, and I never fun a low enough tire pressure to worry about a pinch flat. Also, it won't protect against a puncture, which is your most common flat. I agree with fb, any one that holds air.
2011 Triumph 800 XC
2007 Honda CRF 250X
1994 Kawasaki KLX 650R
THE ADVENTURES OF TYSON AND HOBBES
THE BACKCOUNTRY PURSUIT- Boise, Idaho's consignment specialist for ADV gear!
av_mech is offline   Reply With Quote
Old 07-28-2012, 03:42 AM   #13797
motomuppet
Oddometer: 158
anyone used a Metzler Sahara 3 on the front of their 800xc? I just found 90/90 - 21 in my store room I forgot I had and was thinking it should work well no?
motomuppet is online now   Reply With Quote
Old 07-28-2012, 05:18 AM   #13798
RichardU
Let's Ride
Oddometer: 875
I'm not a fan of heavy duty tubes. They are harder to install ...
I always put the tube in the tire before I put the tire on the rim. You won't need to stuff the tube in later and risk having it twisted. And heavy duty tubes are no more difficult -- maybe slightly easier.
RichardU is offline   Reply With Quote
Old 07-28-2012, 05:21 AM   #13799
fbj913
fbj913's Avatar
Oddometer: 1,842
unless you have to change the tube and not the tire. heavy duty tubes are harder to twist anyway.
Ride 365 LLC
Braaaap!
Old 07-28-2012, 06:22 AM   #13800
Mercury264
Once you go Triple...
Mercury264's Avatar
Oddometer: 20,410
+1
Little bit of air to help them keep their shape and they go in just fine. I do agree they are much heavier and bulkier to carry as spares though so I generally only carry regular tubes as spares.
'12 Tiger 800XC
'07 TE510
'02 Sprint ST
'99 XR650L
'99 Speed Triple
Times are GMT -7.   It's 01:58 AM.
