Go Back   ADVrider > Bikes > Beasts > The British Invasion: Triumph Tigers
Old 08-01-2012, 06:10 AM   #13801
clax
clax's Avatar
Oddometer: 93
i like looking at racks
Hey Marlowerluke, Just wondering if you could tell me where I could see a pic of the rack you just bought. I know what you mean about briskly...I dragged one of my Happy Trails mounted in the neutral postion and Im always conscious of doing that again..
Cheers,
Clay
Originally Posted by marloweluke View Post
Hello Navillus,
The racks are the ones Roger at Caribou Luggage sells with the cases as a package. They are Hepco and Becker racks which I am really happy with. The racks remove easily with a one size allen key. Much better then the SW Motech racks I had on a previous bike. The cases are 36 liters each. As mentioned mine are mounted 1" higher then stock, and have not had any trouble touching down the cases when riding "briskly" even when the pegs touch down. Other then that they are mounted standard, so the spacing from the bike is what you see. It looks exaggerated in the picture, in reality it looks very reasonable. 39" across is not any wider then most systems I have seen.
http://tigerclay.blogspot.com/
clax is offline   Reply With Quote
Old 08-01-2012, 06:34 AM   #13802
nhspirit
Just Ride
nhspirit's Avatar
Oddometer: 101
Hey Guys, This may be a stupid question but can anyone tell me if the rear brake calipers are suppose to rock from side to side. The left front doesn't move at all and the right front ever so slightly but the rear caliper has a bit of movement side to side. Should I be concerned?
Current Ride:
2013 HD Heritage Classic
nhspirit is offline   Reply With Quote
Old 08-01-2012, 06:40 AM   #13803
fbj913
I ride
fbj913's Avatar
Oddometer: 2,358
Originally Posted by clax View Post
thanx for your comment BT. Anyway, I haven't posted on here until yesterday after the fix. The bike seems to be holding oil fine and the 2nd chain and sprockets I had shipped to me arrived finally. Looks WAY better quality than the original set and I'm gonna bet they last longer.
I've never done much long distance touring and I'm learning a lot this trip, so all the pointers are great. I was preparing for 6 months and there is still so much I could of done and learned, it seems like a bottomless pit. I'm gonna chaulk it up and do things a little bit different next time.
Cioa,
Clay
thats the best way to learn. good luck and i hope your trip goes well for you. stay safe!
fbj913 is offline   Reply With Quote
Old 08-01-2012, 06:47 AM   #13804
fbj913
I ride
fbj913's Avatar
Oddometer: 2,358
They will move just a bit. I'm no brake expert but I do know that they somewhat "float" side to side. Make sure the bolts on the front are tight. Not much you can tighten in the rear. Just make sure its all installed correctly.
Old 08-01-2012, 06:58 AM   #13805
bluesman
Oddometer: 3,340
Sliding brake calipers moving by design. Fixed calipers (pistons on both sides) do not move.
bluesman is offline   Reply With Quote
Old 08-01-2012, 07:00 AM   #13806
browneye
PIN IT & BANG GEARS
browneye's Avatar
Oddometer: 5,793
Center Stand Q
I have a helluva time getting this bike up on the center stand, even worse with a load. Am I doing something wrong? Or is there some secret trick to it?
I press the stand foot with my right foot, grab the passenger footpeg bracket or the pannier frame near there, and lift and press at the same time. I'm gonna either bust a hernia or herniate a disc in my back doing this. Do I need to grab further forward on the bike? I don't weigh much either, seems pressing harder on the foot helps, but I just got nothin' more. It's not easy to rock it off the stand either, from sitting on the bike. I look like a fooking idiot.
Chris Brown - "The Browneye"
"Without Motorcycles, People Live Very Boring Lives." - Malcolm Smith
Camp Nelson 2014 RR Laguna Seca 2012 RR Sequoia 3-Day Campout Thanksgiving 2012
browneye is offline   Reply With Quote
Old 08-01-2012, 07:08 AM   #13807
Mercury264
Once you go Triple...
Mercury264's Avatar
Oddometer: 22,168
I struggle too - it is MUCH harder than, say my Sprint. I also seem to catch my leg on the passenger footpeg every single time.
'12 Tiger 800XC
'07 TE510
'02 Sprint ST
'99 XR650L
'99 Speed Triple
Old 08-01-2012, 07:17 AM   #13808
T
stay classy
T's Avatar
Oddometer: 5,397
With no brake applied the caliper will move 0.5-2mm: floating design like most. Your left front would probably move too with enough force.
Apply some lever/pedal and see how they tighten up.....
Inconsequential Adventurer
T is offline   Reply With Quote
Old 08-01-2012, 07:21 AM   #13809
Rob Dirt
More or less in line
Rob Dirt's Avatar
Oddometer: 2,567
It is a pain to get up on the centerstand. I use the pass peg bracket. Getting it off the centerstand is easy. Just put the sidestand down first & standing next to the bike, push it forward.
I almost got stuck one time on a hill. I used the hill to help me get the fully loaded Tiger up on the CS. When I was ready to leave, I almost busted a gut trying to push it up hill & off the stand. I'll never do that again.
Heart of Dixie
Rob Dirt is offline   Reply With Quote
Old 08-01-2012, 07:22 AM   #13810
T
stay classy
T's Avatar
Oddometer: 5,397
This '012 ain't too bad but my 05 was a real bitch. On both I found if I grabbed the engine guard with my left hand and the passenger bracket with my right, with back/up momentum they were on the stand and sitting pretty....
Old 08-01-2012, 07:25 AM   #13811
nhspirit
Just Ride
nhspirit's Avatar
Oddometer: 101
Just tried this and yes they tighten up, Thanks, feeling better about it now.
Thanks, also Fbj913 & bluesman for your reply
Current Ride:
Old 08-01-2012, 07:56 AM   #13812
Snapper
Snapper's Avatar
Oddometer: 2,507
Originally Posted by cug View Post
Had some fun last weekend:
Touch down since the risers Cug?
Lateral G Junkie
Fear Deer
Snapper is offline   Reply With Quote
Old 08-01-2012, 08:01 AM   #13813
cug
Oddometer: 4,876
No touching down since the risers, but I haven't been riding alone since installing them. Meaning - I wasn't going very fast. In this photo series I wasn't leaning over very much, it was just a corner with a nice view into it, but I had only about a hundred meters to get up to speed and then take the first corner.
I'd need to go for a ride alone to actually get into the flow.
cug is online now   Reply With Quote
Old 08-02-2012, 02:00 AM   #13814
blacktiger
Tigers R great.
blacktiger's Avatar
Oddometer: 3,774
What he said.
Yes there'll be some movement. So long as all the bolts are tight you're good to go.
2002 black Tiger955i, 72000 miles and counting.
2011 black Tiger800XC, The other British Land Rover. 40000 miles and counting.
2013 black Tiger800XC, The other British Land Rover. 500 miles and counting.
blacktiger is offline   Reply With Quote
Old 08-02-2012, 02:04 AM   #13815
blacktiger
Tigers R great.
blacktiger's Avatar
Oddometer: 3,774
Sounds like you need a Gym membership.
I don't find it any worse than my Tiger955. I think most bikes with long travel suspension will be harder than a standard road bike because we've got to lift it further. i.e. there's 40mm of sag to overcome before it even starts to get off the ground.
Times are GMT -7.   It's 07:35 PM.
