Go Back   ADVrider > Bikes > Beasts > The British Invasion: Triumph Tigers
Old 08-06-2012, 11:07 AM   #13846
Mercury264
Once you go Triple...
Mercury264's Avatar
Oddometer: 22,143
Originally Posted by Rob Dirt View Post
There's probably pieces of the sticker still messing up the clicks. Mine only clicks once per turn for the same reason. Just count the turns. It's still doing the same job. I think the book says 24 clicks out which is 12 full rotations.
I figured the lack of clicks wasn't really a big issue
Originally Posted by browneye View Post
Yes, 2 clicks per turn.
Mine was doing the sticking thing too but I think it was the detent, not a sticker. I just turned it quickly past the detent and it kept going. The fit of the adjust screw is very loose in its holder, and I think the detent gets sticky. I don't have a fix, but did notice the same thing.
Final question on this - does it have to be on the center stand to adjust - I'm thinking no since not every bike has one
'12 Tiger 800XC
'07 TE510
'02 Sprint ST
'99 XR650L
'99 Speed Triple
Old 08-06-2012, 11:10 AM   #13847
Yossarian™
Deputy Cultural Attaché
Yossarian™'s Avatar
Oddometer: 9,655
No need to unload the rear suspension to adjust it.
Old 08-06-2012, 11:22 AM   #13848
Mercury264
Mercury264's Avatar
Oddometer: 22,143
Super.
Thanks all...
'12 Tiger 800XC
'07 TE510
'02 Sprint ST
'99 XR650L
'99 Speed Triple
Old 08-06-2012, 02:23 PM   #13849
Hallwine
Hallwine's Avatar
Location: Sheffield, Peoples Republic of South Yorkshire
Oddometer: 87
Home made hand guard extenders and aluminium rack. ADV lights and a tool tube. And of course the "New" Blue colour. ARDcases have gone onto the racks now but I do not have a picture to hand.newbaby with most farkles in place. The racks are the H&B ones as is the tank protector
Failure is not an option - Mission control JSC Houston
I say we take off and nuke the site from orbit, its the only way to be sure.
Hallwine is offline   Reply With Quote
Old 08-06-2012, 07:34 PM   #13850
afireinside
Oddometer: 3
Did you make that tool tube bracket? I'm intrigued...
afireinside is offline   Reply With Quote
Old 08-06-2012, 07:39 PM   #13851
fbj913
I ride
fbj913's Avatar
Oddometer: 2,358
tool tube looks to be attached to the luggage rack
fbj913 is offline   Reply With Quote
Old 08-07-2012, 01:21 AM   #13852
blacktiger
Tigers R great.
blacktiger's Avatar
Oddometer: 3,749
there was then something like a label or something that seemed to be stuck in the threads ?
Mine did the same. That sticker had the adjustment lines on it.
Now it's gone, so long as you keep the adjuster lubed (I use a teflon type spray) and know where you are on the scale, I just do it by number of turns in or out. If fact, I think it helps to wind it all the way in and (almost) all the way out every so often to keep it all moving freely. If you don't do that it'll seize solid.
2002 black Tiger955i, 72000 miles and counting.
2011 black Tiger800XC, The other British Land Rover. 40000 miles and counting.
2013 black Tiger800XC, The other British Land Rover. 500 miles and counting.
blacktiger is offline   Reply With Quote
Old 08-07-2012, 01:27 AM   #13853
blacktiger
Tigers R great.
blacktiger's Avatar
Oddometer: 3,749
With bog standard "P" clips. He's lucky to find the tubes on the pannier frames at just the right distance apart. I'm currently trying to figure out how to mount my tool tube to the SWmotech frames which are completely different.
Old 08-07-2012, 02:27 AM   #13854
blacktiger
Tigers R great.
blacktiger's Avatar
Oddometer: 3,749
Originally Posted by Geology Rocks View Post
How big of a concern is the passenger pegs cracking frames in easy drops in all seriousness? I am looking to add an 800xc to the garage as an off road bike, but that issues concerns me a bit.
Thoughts?
Joe
I dropped mine hard in a slippery ford just the other weekend and nothing got broken. I went down "like a sack of spuds".
The things that touched down where :-
Crashbars, Triumph accessory ones.
Handlebars. The 1050 Tiger hand guards got scratched.
Rear footrest.
and..
The givi latch on the pannier frame.
There was paint missing on the OE crashbars and some of the slippery slime on the rear footrest. I had to drag the bike out (with help) because the surface under water was so slippery I could hardly stand up to pick the bike up.
I think you've got to be unlucky for the rear peg to touch down that hard on something. Of course it could happen but then it could also break several other bits as well. And, maybe, the pannier frames acted like crash bars. etc. etc. I like to think that Triumph designed the crash bars to be effective in keeping the rear pegs off the ground so long as that ground is level.....maybe!
Old 08-07-2012, 03:58 AM   #13855
littlelionmonster
Rerutnevda ylranG
littlelionmonster's Avatar
Oddometer: 844
Anyone know how to reset the scheduled maintenance counter? Changed oil last night and tried to reset/changed it but couldn't get anywhere.
littlelionmonster is offline   Reply With Quote
Old 08-07-2012, 04:01 AM   #13856
cug
Oddometer: 4,863
You can do this with DealerTool.
cug is offline   Reply With Quote
Old 08-07-2012, 06:03 AM   #13857
PirateDunk
Oddometer: 71
Don't bother. I have the Motech frames and have a home made tool tube made up from some 90mm pvc pipe with some drain pipe clamps. On both sides of the rear subframe there are some plastic blanks into 6mm threaded holes in the frame. The perfect place to mount a tube, also makes it look like a twin zorst set up. With the 90mm pipes my tube squishes a bit and sits under the removable frames.
PirateDunk is offline   Reply With Quote
Old 08-07-2012, 08:27 AM   #13858
browneye
PIN IT & BANG GEARS
browneye's Avatar
Oddometer: 5,619
Thoughts?
Joe
I wouldn't choose it for an 'offroad bike'. There are many better choices.
For one, it's at least 150lbs too heavy. It doesn't have the suspension for it either
IMO the Tiger is a terrific road bike that has been setup as an adventure bike, with capabililties to go off pavement. Like dirt roads. To me, 'offroad' means trail riding. I wouldn't never consider it as an offroad motorbike.
Maybe it's just terminology.
If your focus is dirt look at KTM690, the new Husky650 replacement for the 630, or go with something even lighter, like KTM 500/525/530/450 EXC's. Or Husky TE449/511.
The lack of subframe thing is a poor design IMO, but not a deal breaker. I don't drop road bikes. If I do it's a real crash, and you just have to fix what you break.
If you know you're going to be dropping it then the fix for the rear pegs is to cut them off and insert sacraficial connectors inside the tubes. Most of the pannier rack systems attach to them so that kind of negates that solution as well.
Chris Brown - "The Browneye"
"Without Motorcycles, People Live Very Boring Lives." - Malcolm Smith
Camp Nelson 2014 RRLaguna Seca 2012 RRSequoia 3-Day CampoutThanksgiving 2012
browneye is offline   Reply With Quote
Old 08-07-2012, 09:32 AM   #13859
KildareMan
KildareMan's Avatar
Oddometer: 653
Thoughts?
Joe
It's not a concern. Funilly not a concern for 1200gs either
KildareMan is offline   Reply With Quote
Old 08-07-2012, 10:59 AM   #13860
cug
Oddometer: 4,863
The R1200GS has a subframe so it wouldn't be that big of a problem anyways as you can replace the subframe independently.
Times are GMT -7.   It's 01:59 PM.
