Go Back   ADVrider > Bikes > Beasts > The British Invasion: Triumph Tigers
Old 08-09-2012, 10:02 AM   #13906
blacktiger
Tigers R great.
blacktiger's Avatar
Oddometer: 3,778
Keeping with the Tool Tube theme.......
I installed mine today.
Hung it off the SWmotech pannier frame using two holes in the frame that are redundant for Givi panniers and a simple plate.
For the instalation on my Scrambler I had a clamp plate made up with threaded holes to support the plastic of the tube mounting...
(almost) got it inline with the frame tube so it looks noice......it will when the bracket has some paint on it....
How it looks from behind...
An idea that I came up with which is an advantage of my thick plate is that if you use a longer middle screw, it can be used as a locking device:-
a) to stop the top coming loose.
b) to stop thieving hands getting at the contents without an Allen key.
Job done. Just got to get out for a ride to make sure it doesn't fall off or foul the chain guard. And then strip it all off for some black Hammerite.
2002 black Tiger955i, 72000 miles and counting.
2011 black Tiger800XC, The other British Land Rover. 40000 miles and counting.
2013 black Tiger800XC, The other British Land Rover. 500 miles and counting.
blacktiger screwed with this post 08-09-2012 at 10:43 AM
blacktiger is offline   Reply With Quote
Old 08-09-2012, 11:23 AM   #13907
T
T's Avatar
Oddometer: 5,398
Had to do a front XC tube exchange roadside today. 25 minutes start to finish at a relaxed pace. Bead broke easily with hand pressure. The warning sign: Bike wanted to go straight when I wanted to turn as I came to a stop sign. A very small hole and a very fast leak down. I'll patch the damaged tube for a spare....
Inconsequential Adventurer
T screwed with this post 08-09-2012 at 05:17 PM
T is offline   Reply With Quote
Old 08-09-2012, 11:38 AM   #13908
bross
Where we riding to?
bross's Avatar
Oddometer: 4,552
Seahorse 720 cases mounted
I posted awhile back the mounting of the Seahorse 520 cases. They've been good for grocery getting and running errands etc. but just thought they'd be too small for trips so I ordered a set of 720s. Same width as the 520s but now I've got lots of space. The 520s will be going on my wife's DR.
Just a bit wider than the mirrors
Happy Trails pannier mount kit, uses knobs inside the bag so it's a quick tool less job to remove the bags.
Here's a couple shots showing how I think the Happy Trails racks will protect the passenger pegs with the bags on or off.
from the top
bross is online now   Reply With Quote
Old 08-09-2012, 12:24 PM   #13909
spewler
Not (w)reckless
Oddometer: 108
Seat cover deteriorating?
On the rider's seat the fabric is deteriorating, and not at a seam. It's happening at two spots: on the right rear portion of the rider's perch maybe 1" away from the gap between it and the passenger seat, and at the right front about mid-thigh. Anybody have this problem? Sorry I don't have pictures because I'm at work. Could this be an item under warranty? I bought the bike new and have owned it for 15 months (30,000 miles)...seems a bit premature for the cover to deteriorate.
2011 Triumph Tiger 800 XC (25,000 miles)
2001 Aprilia Futura (127,000+ miles)
spewler is offline   Reply With Quote
Old 08-09-2012, 12:47 PM   #13910
Snapper
Snapper's Avatar
Oddometer: 2,508
Have you ever put anything on it? One guy here mentioned he Amour-All'd the passenger seat and it started deteriorating. I only have 15k, but my seat looks fine,
Lateral G Junkie
Fear Deer
Snapper is offline   Reply With Quote
Old 08-09-2012, 01:37 PM   #13911
elan
Oddometer: 130
Originally Posted by cyclingtom View Post
Had to do a front XC front tube exchange roadside today. 25 minutes start to finish at a relaxed pace. Bead broke easily with hand pressure. The warning sign: Bike wanted to go straight when I wanted to turn as I came to a stop sign. A very small hole and a very fast leak down. I'll patch the damaged tube for a spare....
I assume you have a center stand? If so, how do you keep the front end off the ground while working with it? Nice work!
elan is offline   Reply With Quote
Old 08-09-2012, 01:45 PM   #13912
ecb12
Oddometer: 10
Anyone seen an update on when the '13s will be coming out?
ecb12 is offline   Reply With Quote
Old 08-09-2012, 01:52 PM   #13913
fbj913
I ride
fbj913's Avatar
Oddometer: 2,358
you take the front wheel off the bike and the back will be heavy enough to keep it back heavy.(with center stand)
fbj913 is offline   Reply With Quote
Old 08-09-2012, 02:15 PM   #13914
browneye
PIN IT & BANG GEARS
browneye's Avatar
Oddometer: 5,814
Works for the rear too. Unless you have a bunch of cargo strapped on.
Chris Brown - "The Browneye"
"Without Motorcycles, People Live Very Boring Lives." - Malcolm Smith
Camp Nelson 2014 RR Laguna Seca 2012 RR Sequoia 3-Day Campout Thanksgiving 2012
browneye is online now   Reply With Quote
Old 08-09-2012, 02:50 PM   #13915
spewler
Not (w)reckless
Oddometer: 108
Snapper, had a bad experience putting Armor All on the seat of my first streetbike, so I steer clear of putting that stuff on the seat.
Old 08-09-2012, 02:58 PM   #13916
T
T's Avatar
Oddometer: 5,398
Yeah, What these guys said. If you didn't have a centerstand you'd have to do it "dirt bike" style- lay it on its side. For the front make sure you have a 17mm allen head (not provided in the factory tool kit).
Old 08-09-2012, 03:19 PM   #13917
browneye
PIN IT & BANG GEARS
browneye's Avatar
Oddometer: 5,814
If you don't have a center stand you need one of these: http://endurostar.com/
The Tiger is about max size for one, but they will work. They are rated up to KTM950/990, and the tiger isn't any heavier, so good to go. I've used one on my Versys, it was about 450lbs fueled. Great solution, very compact.
Once a bike is on a sidestand they are very easy to lift one end just lifting and pushing a bit. This guy's little invention is brilliant.
Old 08-09-2012, 04:57 PM   #13918
elan
Oddometer: 130
Awesome, thanks everyone. I've done plenty of work on bikes, but it's always been in my garage.
Not too experienced with getting stuff done out in the field.
Old 08-09-2012, 05:21 PM   #13919
T
T's Avatar
Oddometer: 5,398
It's always nice to take care of work in the garage but being prepared for a field assignment will keep you from walking or calling for trailer assistance....
Old 08-09-2012, 06:58 PM   #13920
Oshiat
Oddometer: 157
I put Armor-All on mine at the service depts direction, didn't help at all. They replaced the seat under warranty yesterday.
Oshiat is offline   Reply With Quote
Times are GMT -7.   It's 04:19 PM.
