Go Back   ADVrider > Bikes > Beasts > British Beasts: Triumph Tigers
Old 08-10-2012, 12:48 PM   #13936
browneye
PIN IT & BANG GEARS
browneye's Avatar
Oddometer: 6,257
Originally Posted by gallowaystx View Post
So I am weighing my options - trans lab vs TAT vs Alaska.
My offroad experience is minimal - but on road plentiful, and I am pretty confident I can learn on the job. Anybody want to steer me towards one ride or the other?
I own an 800 Roadie and am trying to figure out which will be the best option without buying a different bike. In the rest of my life the roadie is ideally suited to my needs.
If needs be I will buy a small dualsport to do the trip but I would prefer to do it on my tiger - I guess I am just appealing to my more experienced inmates for advice on this.
Skidplate gets added to the list - didn't even think about that one.
IMO the roadie is a great machine for an Alaska trip - it's mostly hiway with some gravel sections. I can't speak for the other two destinations, nor have I actually ridden to Alaska. If other road bikes can make it you can too. And there's lots to see on the way.
Chris Brown - "The Browneye"
"Without Motorcycles, People Live Very Boring Lives." - Malcolm Smith
Camp Nelson 2014 RR Laguna Seca 2012 RR Sequoia 3-Day Campout Thanksgiving 2012
browneye is online now   Reply With Quote
Old 08-10-2012, 01:02 PM   #13937
Rabbot
rain+superbike=adventure
Rabbot's Avatar
Oddometer: 563
Originally Posted by fbj913 View Post
I assume your speaking of the Triumph skid plate? It sounds to me like you slammed your skid plate into something. Most likely a rock... to me it seems like your skid plate did it's job. Mine is all bashed up too. They are not bullet proof. Check out the Alt Rider plate. I will replace mine with Alt Rider when the time comes. You definitely have to be aware of what line you pick when your riding a heavy bike.
Oh I hit rocks. The plate looks great. It's the mounting bracket that bends or fails. Alt Rider mounts the same way so not a solution. Thanks for offing a possible solution tho.
"Red hair and black leather, my favorite color scheme".
Rabbot is offline   Reply With Quote
Old 08-10-2012, 01:07 PM   #13938
advtenn
advtenn's Avatar
Oddometer: 1,373
You need a rock crusher
bikes guns and shine
"My body thinks my brains gone crazy" ..........Corky McMillian
advtenn is offline   Reply With Quote
Old 08-10-2012, 01:11 PM   #13939
Rabbot
Rabbot's Avatar
Oddometer: 563
I'm thinking I need a new adventure bike. Perhaps I can get one of these.
Old 08-10-2012, 02:49 PM   #13940
RichardU
Let's Ride
Oddometer: 903
The problem I've had with mounting the skid plate (XC with SW Motech skid plate) is the four rubber bushings on the bottom. All four of mine de-glued within 1,000 miles. I reassembled them with JB Weld, and I think one of them has come apart again. It is a bit disconcerting to realize the skid plate is essentially glued onto this bike.
RichardU is offline   Reply With Quote
Old 08-10-2012, 06:19 PM   #13941
Ducken
Ducken's Avatar
Oddometer: 107
skid plate
Rob, don't forget, the 2011 skid plate attaches differently than the 2012 skid plate. The redesign of how the 2012 is mounted should eliminate the rattle issues.
First I've heard of this one. Anyone care to elaborate on the difference between 2011 and 2012 mounting differences for the Triumph accessory aluminum skid plate? Worthy of an upgrade, or is updating an early (Silver frame) 2011 possible? Ken
Ducken is offline   Reply With Quote
Old 08-10-2012, 07:23 PM   #13942
Rabbot
Rabbot's Avatar
Oddometer: 563
The Rubber on mine only makes contact from the spring tension in the skid plate while mounted. My guess is you have damaged the mounting bracket like I have and now there is no tension so it can rattle. If the Rubber mounts bounce off the bottom of the motor enough times I can see them coming loose. But mine is not rubber mounted. Isolated by the grommets touching when everything is straight and all points are making contact yes. Mine is mounted to the bracket in front by two screws and one underneath. Bad design. It was obvious mine was bent once I removed the skid plate. What was shocking was how much. I was fortunate enough to be traveling with a friend with a 2012 Tiger. We could compare the two and reshape mine to match his. Mine was tacoed. Would never had been able to bend it into the right shape with out his as a reference. Sorry did not take any pictures and I'm kicking myself for it now.
Old 08-10-2012, 07:25 PM   #13943
Rabbot
Rabbot's Avatar
Oddometer: 563
IMHO the difference is minor. They both have the same bracket in the front where the two bolts connect it to the bracket I'm talking about. Just look at yours and you will see. It's the weak link and it is very weak.
Old 08-11-2012, 04:10 AM   #13944
advtenn
advtenn's Avatar
Oddometer: 1,373
I'll try to clear things up as best I can.
The 2011 skid plate bolts to the black steel bracket in the front of the bike just under the header and oil filter. (two bolts about 4" apart) and spring tension is required to keep the plate from moving around.
The 2012 plate does not bolt to the black steel bracket. It bolts to the under side of the oil sump. (4) nuts with rubber dampeners that hold the plate on. However the black steel bracket is still used, but only as a crumple mechanism. On the 2011 mounting design when the steel bracket collaspses the whole plate will shift back and into the header pipe.
advtenn screwed with this post 08-11-2012 at 04:22 AM
Old 08-11-2012, 06:05 AM   #13945
Bueller
Cashin?
Bueller's Avatar
Oddometer: 17,331
JB weld isn't the right bonding agent for that material. I re-glued mine with heavy duty super glue and immediately cured the glue with a heat gun. That was 3000 miles ago, and I haven't had an issue since. But it is a shitty quality mount.
"Bueller, you're an island of sense in a sea of bullshit" - swimmer
"bueller, you ARE an island of reason in a sea of bullshit" - quasigentrified
Bueller is online now   Reply With Quote
Old 08-11-2012, 01:59 PM   #13946
burmbuster
burmbuster's Avatar
Oddometer: 1,432
SM Motech Risers.....
At 5'9" the SW Motech risers are not the ticket. I am going for the 2" pivot risers from ROX. If anyone needs a set of SW Motech risers I can accommodate, cheap. send me a PM.
Brad
burmbuster is offline   Reply With Quote
Old 08-11-2012, 02:05 PM   #13947
RichardU
Let's Ride
Oddometer: 903
Thanks. I get the feeling I'll have the opportunity to re-glue these many times.
And thanks, advtenn, for clearing things up. Now to muddy them again, the SW Motech plate attaches to both the four rubber bushings under the sump and to two in front (2012 800XC).
Old 08-11-2012, 05:39 PM   #13948
helotaxi
Oddometer: 380
Originally Posted by Birdy68 View Post
Good idea - but the fact is, 90% of the pannier racks USE the rear peg's tubing for a support point!
Happy Trails
Touratech
Hepco Becker
GIVI
SW Motech
Metal Mule
...and ...and ...and...
A shame really as I'd like to remove them - but I have the Metal Mule panniers....
And, NOT the Wolfman. They actually bolt to the frame itself.
helotaxi is offline   Reply With Quote
Old 08-11-2012, 06:36 PM   #13949
easypeasy
Oddometer: 28
Talking Stepper motor and volcanic ash don't mix.
I went for a ride today around Mt. St. Helen's. In Washington state. Now this was not an average ride on primary roads, this was 80% off road and wouldn't you know it after being on an old logging road that was mostly volcanic ash my tiger 800 Xc did not want to idle and would die if I did not give it a little extra throttle when stopped. I have read about the stepper motor not functioning properly after bikes have been ridden in dusty conditions. When I got back home I took some wd 40 and sprayed a small amount on the stepper motor shaft and wouldn't you know it my bike was instantly fixed and now idles as it should. Now for the fix. NO Need to pull the tank just take a Qtip and tape it to something long like a pencil ect. Dab a little of your favorite grease on the Qtip and apply it to the stepper motor shaft, problem solved. As a side note volcanic ash is a very fine abrasive dust that most of you out there will not encounter. I read about the stepper motor problem here and I hope this helps a fellow inmate. Easypeasy out!!!!!!
easypeasy is offline   Reply With Quote
Old 08-11-2012, 09:03 PM   #13950
burmbuster
burmbuster's Avatar
Oddometer: 1,432
For those of you new to these offload chain adjusters....
I highly suggest that you back the tension bolts almost all the way out and lube them with never seize the next time you adjust your chain. You will thank me a year from now. If you don't, you risk having the bolts corrode and seize. Your only recourse then is to remove the swing arm and drill them out. Not fun. This isn't inherent to just the Tiger. It's inherent to every bike with this type of chain tensioner.
These bolts constantly get wet and dirty.
Brad
burmbuster screwed with this post 08-12-2012 at 07:21 AM
Times are GMT -7.   It's 08:31 PM.
