Go Back   ADVrider > Bikes > Beasts > The British Invasion: Triumph Tigers
Old 08-12-2012, 06:50 AM   #13951
levain
STILL Jim Williams
levain's Avatar
Oddometer: 7,257
Originally Posted by levain View Post
I've seen some of the seats in this thread from Corbin & saddleman. I'm wondering what your impressions are of the above, and whether you have gone the custom route? I had a Bill Mayer on my GS that was great. Also had a Sargent once upon a time, and that seat really fit my ass Too bad they're dragging their feet on production
That was awhile back. Anymore input on seats?
Click Here!
2012 Triumph Tiger 800 XC
2008 Yamaha WR250R
1971 Lambretta DL
levain is offline   Reply With Quote
Old 08-12-2012, 08:33 AM   #13952
Rabbot
rain+superbike=adventure
Rabbot's Avatar
Oddometer: 561
Originally Posted by advtenn View Post
I'll try to clear things up as best I can.
The 2011 skid plate bolts to the black steel bracket in the front of the bike just under the header and oil filter. (two bolts about 4" apart) and spring tension is required to keep the plate from moving around.
The 2012 plate does not bolt to the black steel bracket. It bolts to the under side of the oil sump. (4) nuts with rubber dampeners that hold the plate on. However the black steel bracket is still used, but only as a crumple mechanism. On the 2011 mounting design when the steel bracket collaspses the whole plate will shift back and into the header pipe.
I need to get a look at yours again and see if mine can be modified to it.
"Red hair and black leather, my favorite color scheme".
Rabbot is offline   Reply With Quote
Old 08-12-2012, 09:22 AM   #13953
burmbuster
burmbuster's Avatar
Oddometer: 1,430
Great minds think alike!
Originally Posted by Evomx971 View Post
Wanted a small tankbag for my XC and always wanted to try one of the quick lock bags. I thought about installing one of those SAE electrical pass-thru connectors in it, but instead I think I'll just get a Powerlet cord that will reach from the outlet next to the key and just leave it unzipped about a 1/4" in the front and run the cord in there when I want the bag "electrified" to charge a phone or whatever. Last pic is of the bag expanded.
I have the exact same setup. I used the Powerlet cord from the bag to the key switch Powerlet Socket and a dual cigerette outlet inside the bag. Same bag and all. I started to get the City bag but it seems too tall for my liking.
burmbuster is offline   Reply With Quote
Old 08-12-2012, 09:30 AM   #13954
Mercury264
Once you go Triple...
Mercury264's Avatar
Oddometer: 22,143
Originally Posted by burmbuster View Post
I highly suggest that you back the tension bolts almost all the way out and lube them with never seize the next time you adjust your chain. You will thank me a year from now. If you don't, you risk having the bolts corrode and seize. Your only recourse then is to remove the swing arm and drill them out. Not fun. This isn't inherent to just the Tiger. It's inherent to every bike with this type of chain tensioner.
These bolts constantly get wet and dirty.
Brad
Just changed the rear tire on the Tigger and I also did this - I have had issues in the past on my Husky with this. Threads were dry as a bone so I slavered plenty of anti-seize on both bolts so I should be OK. I also greased the rear axle and packed the area round the wheel bearings with grease. We should be good to go now
'12 Tiger 800XC
'07 TE510
'02 Sprint ST
'99 XR650L
'99 Speed Triple
Old 08-13-2012, 11:18 AM   #13955
The Breeze
Oddometer: 205
Originally Posted by easypeasy View Post
I went for a ride today around Mt. St. Helen's. In Washington state. Now this was not an average ride on primary roads, this was 80% off road and wouldn't you know it after being on an old logging road that was mostly volcanic ash my tiger 800 Xc did not want to idle and would die if I did not give it a little extra throttle when stopped. I have read about the stepper motor not functioning properly after bikes have been ridden in dusty conditions. When I got back home I took some wd 40 and sprayed a small amount on the stepper motor shaft and wouldn't you know it my bike was instantly fixed and now idles as it should. Now for the fix. NO Need to pull the tank just take a Qtip and tape it to something long like a pencil ect. Dab a little of your favorite grease on the Qtip and apply it to the stepper motor shaft, problem solved. As a side note volcanic ash is a very fine abrasive dust that most of you out there will not encounter. I read about the stepper motor problem here and I hope this helps a fellow inmate. Easypeasy out!!!!!!
Easypeasy..........great post!!!
I've been trying to think of a quick and dirty way to deal with this issue/problem (in the field)...... This is much easier than removing tank, etc., which would be a complete PIA while on the trail. Thanks again
The Breeze is offline   Reply With Quote
Old 08-13-2012, 11:24 AM   #13956
browneye
PIN IT & BANG GEARS
browneye's Avatar
Oddometer: 5,616
UNI pre-filter
Wrote UNI Filter here on these, here's their reply:
Hello,
We do not offer.
The UNI Australia is a different company.
Best regards,
Tom Gross
V.P Sales
Uni Filter Inc.
1468 Manhattan Ave,
Fullerton, Ca. 92831
714-535-6933 X 26
Fax. 714-535-6927
Toll Free: 877-406-1763
Chris Brown - "The Browneye"
"Without Motorcycles, People Live Very Boring Lives." - Malcolm Smith
Camp Nelson 2014 RRLaguna Seca 2012 RRSequoia 3-Day CampoutThanksgiving 2012
browneye is offline   Reply With Quote
Old 08-13-2012, 05:32 PM   #13957
swimmer
armchair asshole
swimmer's Avatar
Oddometer: 4,577
Originally Posted by cug View Post
So, last weekend I got my center stand installed - best farkle on the bike so far ...
And today the 15mm raising links arrived and I got them installed:
I installed just the links, then did a short test ride. I might imagine it but I think it falls just ever so slightly quicker into corners. Not a big difference, but I think it's noticeable. I'll know more when I have a chance to go out and ride my favorite routes.
After that I moved the front forks down so that they sit flush with the upper fork clamp now. That gives me about 4mm more in the front and 15mm in the rear. Long term we'll see whether I'm still dragging the foot pegs. Probably - though just a bit later and maybe not as often.
But one thing is certain: I'm very happy that I bought only the 15mm raising links.
The rear wheel is still about 10mm off the ground when the bike is on the standard Roadie center stand, it doesn't lean much further on the side stand and I didn't notice any other issues with this.
The next step will be to get the front suspension upgraded. Want to look into getting Traxxion AK-20 fork cartridges installed. Then have the seat re-worked to be about 20mm higher and more comfy, get some Pivot Pegz with rubber tops (heavier - might reduce vibration just a bit more than the standard pegs without the rubber thingy in), install the heated grips which sit in the garage now for 4 months already, get either some Bark Buster Storm handguards or the ones from the Tiger 1050, look into luggage. This bike seems to really get a royal treatment with me ...
cug, these don't show up on the Lust website, where did you get them from and how much were they? Thanks
swimmer is offline   Reply With Quote
Old 08-13-2012, 06:20 PM   #13958
cug
Oddometer: 4,863
Check here:
http://www.lustracing.co.uk/suspensi...k-up-kits.html
I paid $106.06 including shipping to the US. Way too much considering that there are now eBay offers for much better prices. But I didn't find them when I searched, and overall the Lust Racing kit was something I found easily, I don't like adjustable links (as I want to make sure they are the same and stay the same), and the four-way kit wasn't out at the time when I ordered.
Nevertheless, it does what I wanted it to do (give me that little bit of more ground clearance) and therefore it was worth the money for me personally. Next time I'd do with a slightly longer rear shock while doing the rear suspension at the same time. But I postponed rear suspension for now, therefore the link got me the result right away. As I also raised the front of the bike, the handling effect might not be there as much, but the raising certainly is.
cug is offline   Reply With Quote
Old 08-13-2012, 06:58 PM   #13959
Yossarian™
Deputy Cultural Attaché
Yossarian™'s Avatar
Oddometer: 9,655
Looking in past the injector from the RH side of the bike, I can see a small opening that would allow one to squirt a lubricating spray such as WD40 into the area of the bushing. However, I can't quite figure out how to get a Qtip with grease to the area; I just don't see a straight shot anywhere that has a big enough opening to pass a Qtip through.
Any tips on how you got to it?
Yossarian™ screwed with this post 08-13-2012 at 07:01 PM Reason: added photo
Old 08-13-2012, 07:40 PM   #13960
marloweluke
The Flying Dutchman
marloweluke's Avatar
Oddometer: 149
Check here:
I bought the 4 option dog bones from "Projection" for my Roadie, however having tried all of the settings I recommend you don't go any more then 15mm raise. The least increase with the Projection was still 13mm which is fine. The second was 23mm and was too much, adversely affecting the handling. I never rode it with the other too settings as things just would have been worse. Rebound was worse and the bike became very twitchy and unnerving at 23mm. I will be putting the stock dog bones in and raising the back by 13mm with a new rear shock I ordered. So if anyone wants to try the Projection dog bones once I have my new shock you are welcome to them. Just pay me the postage.
I also raised the front as much as it would go, about 4mm and mounted the side stand inside the frame with 9mm stainless steel spacers after grinding the crap out of it in a left hand compression turn. Scared me good and threw me off line quite a bit. Didn't come close to crashing thankfully and the sidestand safety plunger just barely escaped damage. So far so good, haven't scraped anything since.
WITHOUT RISK........THERE IS NO ADVENTURE
marloweluke is offline   Reply With Quote
Old 08-14-2012, 03:25 AM   #13961
Mr_Chris
Get away, evil car!
Mr_Chris's Avatar
Oddometer: 295
Hello,
We do not offer.
Best regards,
Tom Gross
V.P Sales
Uni Filter Inc.
1468 Manhattan Ave,
714-535-6933 X 26
Fax. 714-535-6927
It's tough living in a backwater. But you can move to Australia!
The right company is here ---> http://www.uniflow.com.au/
I own, yet cannot find, the ABS version of the filter on their site. Otherwise you all could paypal me $30 each and if there's about 20 that's $100 for a box to California -- at least, that oughtta be enough, wouldn't it? I might need to be careful heh. Anyway just ask em at the Aussie unifilter and I'm guessing they'd sell you 20 in one shipment...
Chris
Lusting for: Currently Sated with the new XCx
Current: 2012 Berg FE570, 2010 Street Triple R (wifey), 2015 Tiger 800 XCx -- O YEA!
Sold: 1975 CT90, 2008 XVS650, 2007 Rocket III Classic, 2010 Rocket III Roadster, 2011 800 XC
Mr_Chris is offline   Reply With Quote
Old 08-14-2012, 05:07 AM   #13962
PYG RYDR
Adventure-Dual Sport
PYG RYDR's Avatar
Oddometer: 382
Thumb
Chris
Thanks Chris.
I sent a inquiry to them yesterday regarding pricing and shipping costs for a group buy. Will post the results here later.
PYG RYDR
T800XC-VFR800-XR650L-WR250R
MSTA-NVR
There are two things to aim at in life: first, to get what you want; and, after that, to enjoy it.
Only the wisest of humans achieve the second.
Logan Pearsall Smith
PYG RYDR is online now   Reply With Quote
Old 08-14-2012, 08:14 AM   #13963
browneye
PIN IT & BANG GEARS
browneye's Avatar
Oddometer: 5,616
Originally Posted by PYG RYDR View Post
Thanks Chris.
I would take one.
Old 08-14-2012, 08:37 AM   #13964
PYG RYDR
PYG RYDR's Avatar
Oddometer: 382
Thumb
I would take one.
If you want on the Group Buy List for the Uniflo Pre-filter, add your name to the list, which is located here.
http://advrider.com/forums/showthrea...704559&page=84
Specify ABS or standard.
Thanks.
PYG RYDR
MSTA-NVR
Old 08-14-2012, 09:49 AM   #13965
littlelionmonster
Rerutnevda ylranG
littlelionmonster's Avatar
Oddometer: 844
Has anyone tried to relocate the front blinkers to a more protected position. I was comparing the 800 to a 1200 and a 1200 ga this weekend and they have a much better location. Since I've already knocked one off, it's something I'm looking at doing
littlelionmonster is offline   Reply With Quote
Times are GMT -7.   It's 10:05 AM.
