Go Back   ADVrider > Bikes > Beasts > British Beasts: Triumph Tigers
Old 08-14-2012, 09:24 AM   #13966
browneye
PIN IT & BANG GEARS
browneye's Avatar
Oddometer: 6,370
Originally Posted by PYG RYDR View Post
If you want on the Group Buy List for the Uniflo Pre-filter, add your name to the list, which is located here.
http://advrider.com/forums/showthrea...704559&page=84
Specify ABS or standard.
Thanks.
Done.
Chris Brown - "The Browneye"
"Without Motorcycles, People Live Very Boring Lives." - Malcolm Smith
Camp Nelson 2014 RR Laguna Seca 2012 RR Sequoia 3-Day Campout Thanksgiving 2012
browneye is offline   Reply With Quote
Old 08-14-2012, 10:30 AM   #13967
KildareMan
KildareMan's Avatar
Oddometer: 692
Cleaned my unifilter - it's been on for a year now. White spirit to clean then Rockoil foam filter oil to re-oil. Tried to get the unifilter oil but they can't post it to Ireland. Their suggestion was as above, but NOT an aerosol.
KildareMan is offline   Reply With Quote
Old 08-14-2012, 10:53 PM   #13968
Ducken
Ducken's Avatar
Oddometer: 108
Front blinker relocation
Originally Posted by littlelionmonster View Post
Has anyone tried to relocate the front blinkers to a more protected position. I was comparing the 800 to a 1200 and a 1200 ga this weekend and they have a much better location. Since I've already knocked one off, it's something I'm looking at doing
Moved the front blinkers on my Tiger after my buddy broke one of his in a parking lot tip over. We made some brackets out of sheet metal, painted black. The sheet metal brackets were a trial, if it worked out, we were going to reproduce them in heavy Kydex plastic. Six months later, still no rust on the brackets, I'm in no hurry to make the plastic ones. The blinkers are mounted to the bolts behind the headllight, on the side of the body work that connects the tank area to the beak area. Will work on pictures soon. Ken
Ducken is offline   Reply With Quote
Old 08-15-2012, 04:44 AM   #13969
littlelionmonster
Rerutnevda ylranG
littlelionmonster's Avatar
Oddometer: 890
Would be great to see the pictures. I was looking at mounting them in a similar location - Thanks
littlelionmonster is offline   Reply With Quote
Old 08-15-2012, 10:55 AM   #13970
burmbuster
burmbuster's Avatar
Oddometer: 1,432
Triumph rear mudguard extension
Ordered the Triumph mud guard extension through MADSS and was told Triumph is no longer offering it due to a design flaw. Anyone else heard this? I would go for the Touratech one but I don't want their name plastered on the back of my bike. Ay other options?
burmbuster is offline   Reply With Quote
Old 08-15-2012, 11:10 AM   #13971
burmbuster
burmbuster's Avatar
Oddometer: 1,432
Just confirmed with a dealer....
The rear mud guard is now obsolete according to Triumph.
Old 08-15-2012, 11:18 AM   #13972
TAMPAJIM
Oddometer: 494
I purchased a set of truck mud guards(rubberized flaps), and cut one down, then mounted to the tag assembly.
Works great , looks like it part of the bike, cost $14 and I still have one left for the next bike.
__________
Jim
TAMPAJIM is offline   Reply With Quote
Old 08-15-2012, 11:19 AM   #13973
internalcombust
Yes its dirty, thanks.
internalcombust's Avatar
Oddometer: 1,586
Made my own out of an old sport bike rear fender. Cut it to size and bolted it to stock fender.
2012 Tiger 800XC
04 DRZ400S
79 GL1000 basket case
internalcombust is offline   Reply With Quote
Old 08-15-2012, 11:28 AM   #13974
PYG RYDR
Adventure-Dual Sport
PYG RYDR's Avatar
Oddometer: 394
Question Front Tire Preference
I am preparing for a 4,000 mile ride from VA to ME and back. I am spooning on a Heidenau K60 Scout 170-70 rear, and I have a choice for the front between a Heidenau K60 Scout or a Mefo Explorer. I have both front tires on hand. Our route will be gravel and asphalt mostly. Anyone run these fronts and have a recommendation?
TIA
PYG RYDR
T800XC-VFR800-XR650L-WR250R
MSTA-NVR
There are two things to aim at in life: first, to get what you want; and, after that, to enjoy it.
Only the wisest of humans achieve the second.
Logan Pearsall Smith
PYG RYDR is online now   Reply With Quote
Old 08-15-2012, 11:35 AM   #13975
Rabbot
rain+superbike=adventure
Rabbot's Avatar
Oddometer: 564
TIA
Just got back from almost 3000 miles riding in CO. Asphalt and gravel roads mostly. I mounted k60 Scouts front and rear. Loved the rear, front sucks. Don't know about the Mefo, but it has to be better then the k60. I'm putting the TKC80 I took off the front back on. Better grip both on and off road.
"Red hair and black leather, my favorite color scheme".
Rabbot is offline   Reply With Quote
Old 08-15-2012, 12:00 PM   #13976
SMIFFXC
SMIFFXC's Avatar
Oddometer: 138
I heard they stopped making the rear extender because you can't use it if you have the Triumph panniers, the rack gets in the way. I have the extender and have never had a problem. The dealer did tell me they were discontinued after I got mine.
SMIFFXC is offline   Reply With Quote
Old 08-15-2012, 12:02 PM   #13977
SMIFFXC
SMIFFXC's Avatar
Oddometer: 138
+1 on this. Front feels a bit out of sorts. Very loud too, sings going down paved roads.
Old 08-15-2012, 01:11 PM   #13978
Sedir
Oddometer: 13
Gotta a pic for those of us that are visualizationally challenged?
Sedir is offline   Reply With Quote
Old 08-15-2012, 01:30 PM   #13979
FuzzyDunlop
Oddometer: 283
+1 on the TKC 80 / K60 combo. Good grip on and off road.
FuzzyDunlop is offline   Reply With Quote
Old 08-15-2012, 01:51 PM   #13980
Rabbot
Rabbot's Avatar
Oddometer: 564
The only problem, if you want to call it that is, you will go through two fronts for every rear. I am amazed at how well the k60 scout rear tire holds up. I've got 3000 miles on mine and it looks nearly new. In the past I have not gotten more then 1200 miles out of a Metzler Karroo, and 700 out of a TKC 80 rear X2. TKC 80 fronts go about 2500.
Times are GMT -7.   It's 04:15 PM.
