08-20-2012, 07:08 AM
#14116 |
Tigers R great.
Whilst I understand your concerns, I reused the gasket fitted by the dealer to my 955Tig at its 36K service at both the 48K & the 60K services without it leaking. You just need to clean it up and add a smear of instant gasket around the relevant surfaces and all is good. I guess if it's damaged or feels as if it's hardened then replace it but mine has always felt flexible and OK to reuse. YMMV as always.
2002 Tiger955i in black, 68500 miles. 2012 Tiger800XC in black, 19000 miles. Bike history [(N) = bought new] :- YAS1, RD350B(N), XS750(N), XT500, XJ650(N), XJ900S(N), CBX750, XL185S, XR250RF, XR600, 600LC4, TDR250, R100GS, TS200R, Tiger955i(N), Scrambler900efi, Tiger800XC(N)... |
08-20-2012, 07:30 AM
#14117 | |
Oddometer: 92
08-20-2012, 08:41 AM
#14118 | |
Oddometer: 62
08-20-2012, 08:50 AM
#14119 | |
Let's Ride
Oddometer: 876
08-20-2012, 09:47 AM
#14120 |
Oddometer: 126
Marsh Tiger
If you do any tight technical stuff, slow crawling, or even get annoyed at slipping the clutch at stoplights, then get the 15t. It's not the be all end all, but it helps a lot, and makes the bike a lot more livable at really slow speeds. The penalty on the highway isn't bad. I don't notice it being any worse than it was before on the highway. I just did two round trips from CT to PA, mostly highway, cruising 70-85. The engine turns about 6000 at 85. If you're till concerned, take your bike on the highway and cruise for a bit in 4th or 5th, and see how much you mind the rpms. |
08-20-2012, 11:31 AM
#14121 | |
Oddometer: 92
Did some quick looking around and found this guy too: http://shop.pkys.com/blue-sea-system...2-volt-dc.aspx elan screwed with this post 08-20-2012 at 11:54 AM |
08-20-2012, 12:32 PM
#14122 |
Tigers R great.
Pre-load adjuster cover.
Now I admit this ain't going to be much help unless someone can recognise this part.....
![]() I've had it sitting in my "Odds&Sods" bin for years and can't remember where it came from. I think it's off of a speedo cable. A dirt cover. Possibly the gearbox end of the speedo drive off BMW R series. Like I say, I can't remember. But, it pushes over the pre-load adjuster and protects it from all the sh!t being thrown at it from the rear wheel.... ![]() That's with the adjuster fully screwed in but the shaft pushes out through the hole OK ![]() I hope that helps someone.
2002 Tiger955i in black, 68500 miles. 2012 Tiger800XC in black, 19000 miles. Bike history [(N) = bought new] :- YAS1, RD350B(N), XS750(N), XT500, XJ650(N), XJ900S(N), CBX750, XL185S, XR250RF, XR600, 600LC4, TDR250, R100GS, TS200R, Tiger955i(N), Scrambler900efi, Tiger800XC(N)... blacktiger screwed with this post 08-20-2012 at 01:19 PM |
08-20-2012, 12:44 PM
#14123 | |
Once you go Triple...
Oddometer: 20,416
![]() I am pretty sure I have something similar to that lying around.
'12 Tiger 800XC '07 TE510 '02 Sprint ST '99 XR650L '99 Speed Triple |
08-20-2012, 01:26 PM
#14124 | |
Tigers R great.
CLUTCH/BRAKE CABLE RUBBER SLEEVE (H/BAR END) ........ Pt # 61146 on this page.... http://www.motobins.co.uk/bmw-parts....20valve%20Twin under "Control Cables".
2002 Tiger955i in black, 68500 miles. 2012 Tiger800XC in black, 19000 miles. Bike history [(N) = bought new] :- YAS1, RD350B(N), XS750(N), XT500, XJ650(N), XJ900S(N), CBX750, XL185S, XR250RF, XR600, 600LC4, TDR250, R100GS, TS200R, Tiger955i(N), Scrambler900efi, Tiger800XC(N)... blacktiger screwed with this post 08-20-2012 at 01:31 PM |
08-20-2012, 01:41 PM
#14125 |
Just another FF!
Oddometer: 1,190
Sort of looks like a distributor cap plug wire boot.
I like beer |
08-20-2012, 01:46 PM
#14126 |
Shaken, Not Stirred
Oddometer: 2,357
^^^^^ +1
"A free people ought not only to be armed and disciplined, but they should have sufficient arms and ammunition to maintain a status of independence from any who might attempt to abuse them, which would include their own government." -- George Washington |
08-20-2012, 04:30 PM
#14127 | |
Oddometer: 497
I'm just looking for a little help with slow speeds off road. Slipping the clutch gets old. I think the bike will run fine at highway speed with the 15T, but I wanted to ask just confirm my research. Thanks for the reply. |
08-20-2012, 06:44 PM
#14128 |
PIN IT & BANG GEARS
Oddometer: 2,510
Fuel Capacity? Range?
So, what's the deal with this fuel tank? Each tank I get down under 20 miles to empty on the guage and then it won't even take 4 gallons. I thought the tank was 5? So is there really a half gallon or so unusable? How far will it go when it says zero miles left?
And my fuel consumption shows 38.6, has since new. And the speedo reads at least 3mph fast. That means my consumption is really about 40 I guess. Have not measured gps miles over a fill up. Sheesh!!
Chris Brown - "The Browneye" ![]() http://www.stewardsofthesequoia.org/ • Grand Canyon Adventure Ride 2012 Laguna Seca 2012 RR • Sequoia 3-Day Campout • Thanksgiving 2012 |
08-20-2012, 07:06 PM
#14129 | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
armchair asshole
Oddometer: 2,558
08-20-2012, 09:34 PM
#14130 | |
Busted butt
Oddometer: 425
This shouldn't be a problem for 98% of the users, though. |
