Go Back   ADVrider > Bikes > Beasts > British Beasts: Triumph Tigers
Old 09-09-2012, 12:53 PM   #14191
SMIFFXC
SMIFFXC's Avatar
Oddometer: 137
Originally Posted by JustKip View Post
The stock handguards don't offer much in the way of weather protection, and I haven't found any "spoilers" or extensions for the factory ones.
The bike has a Kaoko throttle lock installed and I was wondering if there are any other handguards (Barkbusters, touratech, etc) that will work with the Koako and give better protection in a blizzard?
I too am using 1050 guards w/Koako throttle lock. Works great, much better protection.
SMIFFXC is offline   Reply With Quote
Old 09-09-2012, 12:53 PM   #14192
KildareMan
KildareMan's Avatar
Oddometer: 681
Get barkbusters
Sent from my Tiger 800
KildareMan is offline   Reply With Quote
Old 09-09-2012, 01:09 PM   #14193
cug
Oddometer: 4,935
Originally Posted by KildareMan View Post
Get barkbusters
I use Barkbuster Storm and I'm very happy with them. But I don't use a throttle lock, just can't get over the mechanism and what could happen with my clumsiness. For more comfort on longer trips I use a cramp buster.
cug is offline   Reply With Quote
Old 09-09-2012, 01:11 PM   #14194
JustKip
JustKip's Avatar
Oddometer: 4,619
Get barkbusters
That was my first choice, but the Kaoko instructions say it won't work with Barkbusters
JustKip is offline   Reply With Quote
Old 09-09-2012, 01:40 PM   #14195
Chinookmark
Oddometer: 278
Originally Posted by cug View Post
i use barkbuster storm and i'm very happy with them. But i don't use a throttle lock, just can't get over the mechanism and what could happen with my clumsiness. For more comfort on longer trips i use a cramp buster.
+1
Chinookmark is offline   Reply With Quote
Old 09-09-2012, 06:46 PM   #14196
ducnut
Oddometer: 3,320
I used Palmer Products extensions, on my 1050. They're a pretty generic item that'll probably fit anything.
'09 Triumph Tiger1050
'96 Ducati 900SS
'02 Suzuki SV650S (hers)
ducnut is offline   Reply With Quote
Old 09-09-2012, 08:12 PM   #14197
JustKip
JustKip's Avatar
Oddometer: 4,619
Palmer Products!
Thanks, for something completely unrelated. THEY make the over the pillion seat luggage rack I've been looking for, for 4 months
Old 09-10-2012, 12:51 AM   #14198
Just Dan
Bugger, Burnt toast
Just Dan's Avatar
Oddometer: 1,894
I have Kaoko with bark busters. The Kaoko part number you are looking for Tig100.
13' kawasaki W800, Yep the twin
13' Skyteam Ace 125 BIG BORE
81' BMW R100 CS
Old bikers don't get old by accident.
Just Dan is offline   Reply With Quote
Old 09-10-2012, 01:01 AM   #14199
blacktiger
Tigers R great.
blacktiger's Avatar
Oddometer: 3,814
Originally Posted by swimmer View Post
Has it been confirmed the Explorer guards will fit an 800? I I know the 1050s do with use of a different bar end thing (or some different part).
Explorer bars are pretty much the same as the 800 just a slightly different bend so the guard should bolt straight on.
The 1050 ones will also bolt straight on although they are slightly longer/wider so to get them on without bending the guard some longer bar ends are preferable.
Originally Posted by levain View Post
Seems if you would consider swapping the hand guards, one should go with ones that will actually protect the levers? They aren't only for offroad. I snapped a clutch lever on Uly doing something anyone could do. Proper hand guards would've kept me from having to ride home 150 miles with 1.5" of lever
I've clouted my 1050 ones pretty hard and, it turns out, they're very robust.
3 black Tigers. 955i+800XC+800XC=113000 miles of fun.
blacktiger screwed with this post 09-10-2012 at 01:08 AM
blacktiger is offline   Reply With Quote
Old 09-10-2012, 05:49 AM   #14200
markbvt
Location: Georgia, Vermont (that's one town, not two states)
Oddometer: 2,738
Originally Posted by spewler View Post
markbvt, how do you like the DrySpec bags, how long have you had them, and how are they holding up? I bought the Twisted Throttle tail bag in June of 2011 and it is already starting to fall apart.
I got mine for this trip, and both have held up great. The webbing loops have a tendency to pull out their stitching if you put too much tension on them, so to hold the smaller bag on top of the larger one I attached the straps to the solid strap loops intended for the top carry handle. Worked perfectly.
--mark
'11 Triumph Tiger 800 XC / '03 Honda XR650L / '01 Triumph Bonneville cafe
My ride reports: Missile silos, Labrador, twisties, and more
Bennington Triumph Bash, May 29-31, 2015
markbvt is offline   Reply With Quote
Old 09-10-2012, 07:05 AM   #14201
ducnut
Oddometer: 3,320
Palmer Products!
Cool!
I was digging that rack, too. Sorta' BMW R80GS-ish.
'96 Ducati 900SS
Old 09-10-2012, 07:45 AM   #14202
cug
Oddometer: 4,935
Also check out the Jesse Luggage passenger seat rack / compartment. Though I'm not 100% certain whether I like that sharp edge just around my lower back.
Old 09-10-2012, 08:50 AM   #14203
swimmer
armchair asshole
swimmer's Avatar
Oddometer: 4,730
Strange thing is they makes extensions for the 1050 and 1200 but not 800. I sent them an email asking about extenders for the 800 just in case they have something but it's not on their website. Looks like they make some useful stuff.
I have some plastic material that I was going to make my own extensions with but I'd rather buy some if they are pretty cheap.
swimmer is offline   Reply With Quote
Old 09-10-2012, 12:00 PM   #14204
swimmer
armchair asshole
swimmer's Avatar
Oddometer: 4,730
They said the 800's guards were too complicated for extensions and they weren't sure if the Explorer guards were fit as they might be too big and hit screen at full lock.
Old 09-10-2012, 01:41 PM   #14205
ducnut
Oddometer: 3,320
The 1050 dimensions are 65mm wide by 235mm long. They have a taper at the outer ends with the inner being straight. The material is pliable enough to cut with a utility knife. It's unfortunate their site pics aren't very good.
Explorer 1200 pic gives an idea of the material and general shape.
'96 Ducati 900SS
Times are GMT -7.   It's 12:58 PM.
