Go Back   ADVrider > Bikes > Beasts > The British Invasion: Triumph Tigers
Old 10-15-2012, 11:25 AM   #14611
elan
Oddometer: 128
Speaking of oil changes. Did my first one at 6k miles (bought bike used). Probably easiest bike ever for an oil change! Just make sure you have 8mm (if I recall correctly) hex bit.
I did find two aluminum washers doubled up from previous change though. Not sure if it was the dealer or previous owner... Dealer wouldn't surprise me one bit.
elan screwed with this post 10-15-2012 at 11:25 AM Reason: spelling
elan is offline   Reply With Quote
Old 10-15-2012, 01:06 PM   #14612
viper770
viper770's Avatar
Oddometer: 578
Wicked
I have 17,000 miles on my 2012 tiger 800 xc and it does not burn oil
2012 YAMAHA WR250R
2013 KAWASAKI KLR650
"Take the long way home"
MY SPOT LOCATION http://share.findmespot.com/shared/f...vi71zS820h7TbU
viper770 is offline   Reply With Quote
Old 10-15-2012, 01:07 PM   #14613
Evomx971
Defrosting in NM
Evomx971's Avatar
Oddometer: 245
12,000 mile valve check, TB sync, and newest map
Just thought I'd share some recent maintenance results:
In general, I do all my own maintenance, but about 6 weeks ago I took my 2011 800XC in to get the latest map since I was two behind and still on the original Arrow-ABS map. The new map might run a little crisper than the one I was on and I think I've picked up a couple mpg running it. Although I also think I now have to let the bike warm up for just a few seconds more on cold (less than 50F) mornings than I used to. Doesn't die or anything, just not as "happy". Not a big deal.
I had planned to do my own valve check but once I got the cam cover off, I discovered I really didn't have a set of feeler guages that would get down in there and the exhaust spec is pretty small. Seems like it falls between sizes in most feeler guage sets. What feeler guages are you guys using to check your valves?
I went ahead and put new plugs in since I had them. The old plugs looked good (very clean) but I could visually see some minor wear on the electrodes so glad I replaced them.
Went ahead and had the local dealer do the valve check and the TB sync. They found all the valves just barely tight. That surprised me. I've read of some guys finding a few tight at the first check, but haven't noticed anyone else finding them "all" tight. They set them at the loose side of the spec. I didn't hear if they actually had to adjust the sync on the throttle bodies or not. $220 for the valve adjustment and TB sync. Cheaper than I thought it would be. Of course, I had to take off the skidplate when I got home and clean up oil that must have ran down the front of the motor (I think they pulled the cam cover with the bike on the sidestand for some reason). It has just the tiniest bit more valve noise than before which would be expected. Runs as good or better than it ever has.
They want me to bring it in to do the shifter return spring recall that affects my VIN... might drag my feet a bit on getting that done. Haven't heard anything about that being a high priority to get done.
Keep posting up your results as you do your valve checks... interested in what others are finding.
"In the end, it's not the years in your life that count. It's the life in your years." ~ A. Lincoln
'11 Triumph 800XC ABS / '94 Honda XR650L / '06 Yamaha YZ125
Thanks to my 2015 Sponsor: Motorex
What Next Wander Tour http://advrider.com/forums/showthread.php?t=853663
Evomx971 is online now   Reply With Quote
Old 10-15-2012, 01:20 PM   #14614
elan
Oddometer: 128
I don't know what the specs are off hand, but I had to order a decent set of feeler gauges a while back as most stuff locally was way too big. I think my smallest one is .05mm
Something like this: http://www.ebay.com/itm/Horex-German...70648484668%26
Old 10-15-2012, 01:27 PM   #14615
Evomx971
Defrosting in NM
Evomx971's Avatar
Oddometer: 245
Were you able to do yours with straight blade guages? Seems like it would have almost taken a guage with a 45-90 degree bend to get down to the valve tappet. Like with the set you sent, it goes from .30mm to .35mm to .40mm... off the top of my head, I was thinking the exhaust spec was like .325mm to .375mm. I'm probably being too cautious with the whole thing.
Old 10-15-2012, 01:40 PM   #14616
elan
Oddometer: 128
I actually haven't checked the Tiger yet. I was just speaking from other bikes. My CRF is pretty tight, but I'm able to get it in there. I think I read from others that a 45 or 90 degree bend in the gauge would help out though.
If the specs do get into the thousandths and my gauges didn't, I'd just measure to the nearest hundredth on the looser side of the spec. Besides, most shims are in .05mm increments aren't they?
Just read this on: http://www.tiger800.co.uk/index.php?topic=3072.0
Checked valve lash last week. 12,100 miles on Odo.
Intake were perfect, exhaust were right at the bottom of the range. I did not have the right shims so buttoned it back up and will bring to mid-range next time I get a chance.
BTW, Shims are of the 7.48 diameter variety.
Job was not difficult, just follow the manual. The only quirky part is that once the cam shafts are in, and before tightening up the camshaft ladder (hold down mont) you really want to put tension on the cam-chain. The book mentions putting tension on it, just not during the early part of the buttoning up phase. If you don't put tension on it, the chain "can" sorta bunch up between the cam gears at top requiring you to pull the camshaft ladder again. Other than that, the manual is excellent. Oh, and you really want narrower feeler gauges as the exhaust shims are tough to get to and the thick feeler gauges (.325 to .375 mm) don't bend very well if they are of the 1/2 wide variety. Even bent they are a pain to get a good reading. I picked up some 1/4 inch wide ones and they work great.
Old 10-15-2012, 01:41 PM   #14617
Rob Dirt
More or less in line
Rob Dirt's Avatar
Oddometer: 2,567
You will be kicking yourself if that spring breaks. Why risk ruining a ride? Just let them change it out. They will NOT dump the oil or anything else that should discourage you from getting the new spring. It would suck to try & ride home with the shifter stuck.
Heart of Dixie
Rob Dirt is offline   Reply With Quote
Old 10-15-2012, 01:46 PM   #14618
Evomx971
Defrosting in NM
Evomx971's Avatar
Oddometer: 245
Good point. Although, in general, when letting a shop work on my stuff, a little dumped oil is the least of my worries.
Old 10-15-2012, 01:53 PM   #14619
elan
Oddometer: 128
haha, Amen. I'm the same way. I'm actually waiting for a call back from my local shop to get this done as well. I wasn't sure if they had to dump oil or not, but they also confirmed they didn't.
Old 10-15-2012, 02:25 PM   #14620
Yossarian™
Deputy Cultural Attaché
Yossarian™'s Avatar
Oddometer: 9,655
New ECU maps
I see that as of last week, there are some new ECU maps on TuneECU.com.
I'm currently running 20635 on my XC ABS (standard silencer) and am wondering if anyone knows what the difference is in the new 20653 tune.
If you have it, have you loaded it on your Tiger yet?
Old 10-16-2012, 09:03 AM   #14621
Mercury264
Once you go Triple...
Mercury264's Avatar
Oddometer: 22,142
Originally Posted by Mercury264 View Post
I should have added that I am due to go on a trip to Maine in a week or so that will involve some highway (to get there) and then a fair bit of dirt roads etc. and I'm sure some mud along the way. I put another Battlewing on the rear since I needed a new tire and I was going on a trip to Montreal, 2-up with no chance of dirt.
On the recommendation of an inmate here, I have ordered a VRM163 so I'll give that a shot with the Mefo Explorer on the front. I was all set to get a Mefo for the rear until I realized they don't do a 17"
'12 Tiger 800XC
'07 TE510
'02 Sprint ST
'99 XR650L
'99 Speed Triple
Old 10-16-2012, 12:49 PM   #14622
KildareMan
KildareMan's Avatar
Oddometer: 653
I've loaded the non abs on mine - 20654. In comparison I could see no difference with the previous tune - 20636. However that doesn't mean much as most of the tune is locked down so that we the users can not see it.
Only difference I noticed so far is the fuel gauge registering full within 300m of filling up.
KildareMan is offline   Reply With Quote
Old 10-16-2012, 02:44 PM   #14623
bluesman
Oddometer: 3,327
What you mean they do not do 17"???? I ran rear 17" Mefo Explorer on my DR800 for about 2000 km.
Here it is
bluesman is offline   Reply With Quote
Old 10-16-2012, 03:09 PM   #14624
Mercury264
Mercury264's Avatar
Oddometer: 22,142
Here it is
My bad, I wasn't clear. They don't do a Super Explorer in 17" and the biggest Explorer rear is (IIRC) 130 ?
'12 Tiger 800XC
'07 TE510
'02 Sprint ST
'99 XR650L
'99 Speed Triple
Old 10-16-2012, 04:10 PM   #14625
bluesman
Oddometer: 3,327
Ah! I see.
I did not like those tyres to be honest. They were OK for very dry and no sand and dry tarmac...but in wet they were horrible. This is why I sold them...
Times are GMT -7.   It's 10:13 AM.
