Go Back   ADVrider > Bikes > Beasts > The British Invasion: Triumph Tigers
Old 10-21-2012, 04:32 PM   #14686
The Jerk
Bring us some fresh wine!
The Jerk's Avatar
Oddometer: 2,614
No, not really. You got bad info.
If you didn't do anything else other than push the pistons back to fit new pads, ABS doesn't enter into the equation.
More likely you accidentally tweaked or otherwise fucked up one of the ABS wheel speed sensors while you were doing the brakes. Check em out and get back to us.
Originally Posted by Mercury264 View Post
Really ? Damn, all I did was push the pistons in I didn't crack any lines or anything.
I knew ABS was going to be a total PIA
2000 Kawasaki W650
The Jerk is online now   Reply With Quote
Old 10-21-2012, 04:50 PM   #14687
Mercury264
Once you go Triple...
Mercury264's Avatar
Oddometer: 22,065
Double checked the sensors etc. this afternoon and I don't see anything obvious - all I did was push the pistons back in so I'm not sure how the sensors would be affected. I wonder if disconnecting the battery has anything to do with it ?
As I mentioned, the brakes appear to work just fine - manual actually says that if the light doesn't go off after reaching 6MPH, then the brakes revert to being non-ABS so if that's the case I'm not too concerned...
'12 Tiger 800XC
'07 TE510
'02 Sprint ST
'99 XR650L
'99 Speed Triple
Mercury264 is online now   Reply With Quote
Old 10-21-2012, 04:52 PM   #14688
Mercury264
Mercury264's Avatar
Oddometer: 22,065
Originally Posted by motosickle2000 View Post
You should check your ABS sensors - maybe you bumped something loose. I doubt that your ABS needs bleeding - I have changed my front and rear pads and have had no such problem.
Have you noticed that you only get about 5Kmiles from your rear pads? I use my rear brakes quite a lot, but it seems I should be getting better mileage. I found when I put on EBC pads, the rears are wearing much better, but the fronts look like they will only go 5K.
I am trying some sintered pads I bought on Ebay. $18 shipped for a full set (both calipers) of pads.
My rear pads lasted 9K which does seem to be pretty poor to me - I don't think I ride with the rear brakes on or anything stupid like that so I'm really not sure what the issue is. I fitted EBC HH pads so we'll see how they go.
'12 Tiger 800XC
'07 TE510
'02 Sprint ST
'99 XR650L
'99 Speed Triple
Old 10-21-2012, 04:59 PM   #14689
motosickle2000
Oddometer: 187
All of my mileage is in-town, short trips - so I am probably harder on brakes than most. I don't drag my rear brake either. The EBC HHs that I put on the rear look like they will go at least 10Kmi, but the fronts probably will not make 5Kmi. I got 8Kmi out of my OEM front pads. I'll let you know how the Ebay brakes work out.
motosickle2000 is offline   Reply With Quote
Old 10-21-2012, 06:05 PM   #14690
the_babaji
the_babaji's Avatar
Oddometer: 245
Is there not two fuses for the ABS system? It's a long shot, but have a look at them.
the_babaji is offline   Reply With Quote
Old 10-21-2012, 11:17 PM   #14691
Ducken
Ducken's Avatar
Oddometer: 107
Rear Tire Sealing Failure
Checked my XC's tire pressure today. Front tire down 1 pound, rear tire....0 PSI. Sealed my rear rim 150 miles ago, a few short runs followed by a 105 mile off road adventure ride last weekend. Used the Seal All x2 / Goop x1 individual spoke sealing method detailed somewhere here earlier. Pulled the wheel, checked with soapy water, leaking from two spoke holes. Dismounted the tire, visible adhesion failures on three spokes, the third one just hadn't leaked yet. Reinstalled the rim band and the tube. Retry again maybe later this winter, but I did prep the rim thoroughly with alcohol. Oh well.
If anyone made a tubeless rim and spoke kit that I could lace to my stock XC hubs for maybe $250 (per wheel) I'd be interested. I've only seen complete wheels, for big bucks(2 to 3 grand). Have I missed anything? Ken
Ducken is offline   Reply With Quote
Old 10-21-2012, 11:26 PM   #14692
live2ridetahoe
RN
live2ridetahoe's Avatar
Oddometer: 1,436
The new KTM 1090 whatever has tubeless wheels. It would be interesting to see if our hubs would fit to that rim...
On the other hand, one could send their hub to Woody's Wheelworks. They powder coated my hubs on my KTM and made tubeless wheels for my 950 Adventure. I never, ever, had a problem with those wheels until the day I sold the bike for a new kitchen....
JG
live2ridetahoe is offline   Reply With Quote
Old 10-22-2012, 02:49 AM   #14693
Adventure boy
Adventure boy's Avatar
Oddometer: 510
Originally Posted by bluesman View Post
Is that comfort seat really that good? I kinda hesitating to buy one...but...? What do you think?
ive only done about 200 miles on it but it seems quite nice can feel the differance
Live a little Love a little Ride a lot
Adventure boy is offline   Reply With Quote
Old 10-22-2012, 06:27 AM   #14694
fbj913
I ride
fbj913's Avatar
Oddometer: 2,353
Send it to woody wheel works.
fbj913 is online now   Reply With Quote
Old 10-22-2012, 08:12 AM   #14695
Mercury264
Mercury264's Avatar
Oddometer: 22,065
Checked both and they are fine.
'12 Tiger 800XC
'07 TE510
'02 Sprint ST
'99 XR650L
'99 Speed Triple
Old 10-22-2012, 08:40 AM   #14696
Mercury264
Mercury264's Avatar
Oddometer: 22,065
So I am officially nominating myself for dumb-ass of the year
In my defense...this is my first bike with ABS....
Turns out there is a single ABS ring on the front wheel (obviously) and currently, that ABS ring on the wheel is on the opposite side to where the sensor is
So....I guess I need to take the wheel off, remove the tire and put it on the right way and re-install the front wheel in the CORRECT position.
Did I mention I'm a dumb-ass
'12 Tiger 800XC
'07 TE510
'02 Sprint ST
'99 XR650L
'99 Speed Triple
Old 10-22-2012, 08:44 AM   #14697
Yossarian™
Deputy Cultural Attaché
Yossarian™'s Avatar
Oddometer: 9,638
My guess is that this is a lesson learned, and a mistake you won't repeat.
Old 10-22-2012, 08:46 AM   #14698
fbj913
I ride
fbj913's Avatar
Oddometer: 2,353
that totally something i would do. but now you did it for me so i wont.
Old 10-22-2012, 08:46 AM   #14699
Mercury264
Mercury264's Avatar
Oddometer: 22,065
Nope. I see it as a public service announcement - I'm all about helping others
I'm actually relieved that's all it is (hopefully )
'12 Tiger 800XC
'07 TE510
'02 Sprint ST
'99 XR650L
'99 Speed Triple
Old 10-22-2012, 08:51 AM   #14700
fbj913
I ride
fbj913's Avatar
Oddometer: 2,353
You actually just made me realize that there is a way to turn your abs off permanently... Not a bad idea for a long adventure ride! Just turn the front wheel around (and obviously switch the direction of the tire)
Times are GMT -7.   It's 07:40 AM.
