Go Back   ADVrider > Bikes > Beasts > The British Invasion: Triumph Tigers
Old 10-23-2012, 09:44 AM   #14716
y0y02369
y0y02369's Avatar
Oddometer: 1,187
Eek ABS good or bad
How's everyone liking the ABS option on this bike? Seems like not many people like it...
y0y02369 is offline   Reply With Quote
Old 10-23-2012, 09:50 AM   #14717
Yossarian™
Deputy Cultural Attaché
Yossarian™'s Avatar
Oddometer: 9,638
I'm surprised by that. I find the ABS to be very good.
It's not intrusive; I can leave it on when riding off pavement and it's not given me any nasty surprises so far. It works well when it does kick in.
If it's down to a vote then I'm giving it a positive.
Old 10-23-2012, 09:52 AM   #14718
browneye
PIN IT & BANG GEARS
browneye's Avatar
Oddometer: 5,324
In a word, fantastic. Works seamlessly. Just got back from a 3-day 625 mile trip with about a hundred miles of dirt roads. Never switched it off, never bothered me. More and more riders are finding that unless the terrain is really steep or they're trying to trailride the damn thing, the ABS works just fine on loose surfaces.
I have talked to GS riders that always switch theirs off, so I am gathering that the Triumph abs unit must work exceptionally well.
I hear my rear tire chattering all the time but never bothers, only assures.
EDIT: BTW, I think all the bikes shipped to NA have ABS, so it's probably a moot point. Also btw, it's easy to switch off at the instrument panel, a little fiddly with the menus 'till you learn where everything is and how to get there, but nothing too complicated.
Chris Brown - "The Browneye"
"Without Motorcycles, People Live Very Boring Lives." - Malcolm Smith
Camp Nelson 2014 RRLaguna Seca 2012 RRSequoia 3-Day CampoutThanksgiving 2012
browneye is offline   Reply With Quote
Old 10-23-2012, 09:57 AM   #14719
Mercury264
Once you go Triple...
Mercury264's Avatar
Oddometer: 22,078
The ABS works very very well. Personally, I'd just rather NOT have it as it's just added complexity I don't want or need but when it works, it works very well.
'12 Tiger 800XC
'07 TE510
'02 Sprint ST
'99 XR650L
'99 Speed Triple
Old 10-23-2012, 09:59 AM   #14720
Mercury264
Mercury264's Avatar
Oddometer: 22,078
I think all the bikes that ship now and have for while, have ABS. I believe some of the early ones did not have ABS. When I ordered my bike (May 2011 IIRC) I was told I had no choice.
'12 Tiger 800XC
'07 TE510
'02 Sprint ST
'99 XR650L
'99 Speed Triple
Old 10-23-2012, 10:49 AM   #14721
jphish
Oddometer: 617
Only issue for me was once, going down a steep hill on loose dirt - appeared to be almost no braking. But 99% of time ABS stays on, regardless of roads - works great. Did get a rock stuck in ABS ring - CEL light was on - had it 'cleared' & offending rock removed passing thru Reno - Nice Triumph dealer there - took it in right away. Now I know what to look for if it happens again.
jphish is offline   Reply With Quote
Old 10-23-2012, 10:59 AM   #14722
jphish
Oddometer: 617
PS: I ride in rain a good portion of the year in the great "Northwet" - it has saved me several times on fast stops to avoid idiot 'left turners' that dont SEE motorcycles. As long as front wheel is straight - tiger stops quick & true, with no propensity for a high or low side event. I think ABS is a huge leap forward in motorcycle safety.
Old 10-23-2012, 10:59 AM   #14723
bross
Where we riding to?
bross's Avatar
Oddometer: 4,524
I totally agree, the ABS works very well on or off road. Have never turned mine off and never felt the need. My wife and I went on a 4 day dual sport ride and it included LOTS of steep, loose, rocky climbs and descents and I never once felt the ABS do anything but slow and stop the bike predictably. Too many people have been conditioned for too many years to expect scary, dangerous ABS systems from BMW on loose surfaces. Yamaha have an excellent ABS system on the Tenere and the system on the Tiger just works. I don't even think about anymore, I just ride.
It was the ABS's fault, really
bross screwed with this post 10-23-2012 at 11:06 AM
Old 10-23-2012, 11:02 AM   #14724
henkew
Oddometer: 70
Givi Luggage, Keys, Lock Barrels, and Hot Babes
I have a Trekker 33, Trekker 46, and an E55 (I am considering getting a Trekker 52 to replace the E55). I would like to replace the lock barrels so all boxes are keyed the same. The problem the Trekker 46 has a new style lock and the other two boxes use the old style. All cases were purchases in the past year.
The old 3 lock replacement kit is Givi part number Z228 ($30). The new style lock is part number SL 103 (but not available in the USA). The new locks are longer and use a more secure key. The two are not interchangeable without an adapter.
I have been told that I can buy the new style lock and use it on an older one by adding part Z640R. This is essentially an adapter that will allow you to mount the longer, newer lock into the old style case. The only problem with this is that SL-103 sets are not available in the USA.
I have also been told the older style lock set will work on any of the cases by some sales reps, but others have told me they will not work with or without an adapter.
Ideally, using the lock barrels that came with my XC would be the way to go and my motorcycle key would then fit the luggage. But the Triumph barrel is too long. I wonder if the Givi adapter for their longer barrels (part number Z650R) could be used to mount the Triumph lock barrels.
Has anyone out there had luggage with different GIVI lock styles and how did you resolve it?
Also, has anyone by chance tested part Z650R with the Triumph lock barrels or attempted to mount the triumph barrels in the givi luggage using another workaround?
PS: Hot Babes dig matching lock sets so they can easily find their stuff.
henkew is offline   Reply With Quote
Old 10-23-2012, 11:22 AM   #14725
Yossarian™
Yossarian™'s Avatar
Oddometer: 9,638
Your post got me thinking. I did not know there were two styles of lock barrels.
I purchased a TRK33N and TRK46N earlier this year. They were separately keyed, but I used a Givi 2-lock set and replaced the originals with the new barrels and now both cases are keyed identically.
I have a set of E360 cases that are color-matched to my ZZR; they are identically keyed also.
Then, lastly, I have a Traffic II case that has its own key pattern.
I had always figured I could cross-key the Traffic II to either of the side case sets with a 3-lock system, but now I'm not so sure. The thought of cross-keying all five cases had also been in my head, but I'm not certain how one could buy two sets of 3 lock barrels and be able to make sure they were identical.
Old 10-23-2012, 11:23 AM   #14726
cug
Oddometer: 4,858
You are falling for the typical Internet trap: the three guys in the world that don't like the ABS on the Tiger are vocal like hell on every single forum that'll let them in writing dozens of rants while thousands and thousands of happy customers never even think twice about it.
cug is offline   Reply With Quote
Old 10-23-2012, 12:44 PM   #14727
Simon Smith
Simon Smith's Avatar
Oddometer: 192
You don't even know the ABS is there unless you get yourself into the situation that you need it. Works far better than the so called superior system used on most cars, which don't seem to have any "feel" to them at all.
So yes, I would say that 99% of the people don't complain about it because they simply forget that it's there.
'11 Triumph Tiger 800XC,
Simon Smith is offline   Reply With Quote
Old 10-23-2012, 01:22 PM   #14728
blacktiger
Tigers R great.
blacktiger's Avatar
Oddometer: 3,703
ABS? Wassat?
2002 black Tiger955i, 72000 miles and counting.
2012 black Tiger800XC, The other British Land Rover. 40000 miles and counting.
2013 black Tiger800XC, The other British Land Rover. 500 miles and counting.
blacktiger is offline   Reply With Quote
Old 10-23-2012, 03:13 PM   #14729
turboICE
Oddometer: 63
The ABS works very well and I think most that have given it a chance on loose descents have been surprised by how unintrusive and usable it was. On wet asphalt it is flawless. It maybe the best implementation of ABS I have ever experienced on any vehicle. Its sensitivity and response has always been expected rather than unexpected.
I actually don't recall much in the way of complaints about how it works at all. I think the complaints that have been aired have related to it being more complex to disable than it needed to be for those that want to disable it for loose surface riding, rather than anything wrong with the ABS itself.
turboICE is offline   Reply With Quote
Old 10-23-2012, 07:36 PM   #14730
Xcountry-Rider
Oddometer: 912
+1 I agree i talked about the ABS in my 25K review i did on my blog. The ABS is so much better than the BMW ABS and i think most of us are riding off road with it on. Something the beemers never do. It lets you in put just enough to do a little slide before kicking in and straightening you out. It actually allows me to control the bike the way i like off road. I see no reason to ever disable it in my opinion.
Xcountry-Rider is offline   Reply With Quote
Times are GMT -7.   It's 11:08 AM.
