Go Back   ADVrider > Bikes > Beasts > The British Invasion: Triumph Tigers
Old 10-29-2012, 02:47 PM   #14776
cug
Oddometer: 4,863
Originally Posted by browneye View Post
If it was indeed the weight of the muffler (insignificant in the big scheme of things) then you would be leaning left to balance it and it would pull left, not right.
It's countersteering the bike ...
cug is online now   Reply With Quote
Old 10-29-2012, 03:15 PM   #14777
rustynut2
Oddometer: 481
My klr did this pull to one side. The rear wheel wasn't tracking straight. Small adjustments to the rear end, ride and see, adjust again. I wouldn't touch the front spokes yet.
Work harder, millions on welfare depend on you.
12 T800XC
09 KLR 650
rustynut2 is online now   Reply With Quote
Old 10-29-2012, 04:24 PM   #14778
bluesman
Oddometer: 3,330
Originally Posted by Rob Dirt View Post
No, but I was told the LV is less than half the weight of the stock muffler. The stock muffler would make a good boat anchor.
Total weight of stock is 5.89 kg
Total weight of LeoVince Aluminium is 3.52
Total weight of LeoVince Carbon (I have one! Yesss!) 3.17 kg
http://www.leovince.com/en/catalog-t...i_e_2011/14229
http://www.leovince.com/en/catalog-t...i_e_2011/14230
By no means stock muffler is too heavy comparing to most I handled in my experience. More to it - it is rather smart design with combined labyrinth/straight through combo. But bulky and noise not nice.
But Leo is brilliant - sounds great, looks good and don't affect bike power negatively (according to dyno runs I saw). And it is VERY well made and not too expensive.
bluesman is offline   Reply With Quote
Old 10-29-2012, 09:47 PM   #14779
frytown
Oddometer: 75
To those that have experienced the pulling to the right:
Are you all sure it's not simply uneven tire wear? Fronts always wear more on the right than the left so, perhaps, after time, start pulling that way since the road to tread delta ends up being steeper.
Just a thought.
Oh, and the LV Carbon can feels quite a bit lighter than stock, but I don't think it qualifies as less than half. Maybe 2/3 the stock weight? Not sure since I didn't weigh it before putting it on.
I will say it improved bottom end grunt and sounds infinitely better....!
frytown is offline   Reply With Quote
Old 10-29-2012, 09:55 PM   #14780
Xcountry-Rider
Oddometer: 912
California Tiger Owners Check in Thread
I started a thread for Cali Tiger riders to check in. How many Tigers riders on the left coast do we have on here?
http://advrider.com/forums/showthread.php?t=837127
Xcountry-Rider is offline   Reply With Quote
Old 10-30-2012, 12:37 AM   #14781
pilot3
Oddometer: 408
In search of a brighter brake light
So as much as I like this bike, I have been disappointed with the rear tail/brake light, mainly because it is not as bright as other bikes, specifically most Japanese bikes that use clusters of rear facing diodes. The Tiger uses side facing diodes in the light array which are then reflected rearward to illuminate from behind. Being LED, we cannot increase the brightness so what's a Tiger owner to do?
Here are the markers from behind on an overcast day-
And now the brake lights-
I searched out a waterproof LED array which has a pulse trigger lead (not cheap). Then with a bit more searching, I located the factory wiring plugs and, after a bit of wiring, built this--
The black plugs are a direct match to the Triumph factory plugs, so all that is necessary is to unplug the rear light assembly, insert this in between, and plug them in.
The light is slim and narrow enough and fits just perfectly into the notch above the light assembly and below the rear rack. It is adhered in place with 3M dual side waterproof adhesive.
The light array acts as a tail light just as the original does when it is powered on. When the brakes are applied, the light emits a brief series of pulses and then stays on bright. Let me just say, the brake lights are super bright, even in the sunlight.
Tail lights alone with LED array-
And with the brake lights applied-
Here is a video link to the application of the brakes. It is out of focus due to the flash and brightness of the LED's-
I've though about making more should there be a demand, but at the very least I just wanted to share the light improvement.
Cheers,
p3
***MOVED TO VENDORS***
There were requests for more of these so I started a thread in Vendors (thanks GB for the guidance). Please go there to ask your questions and place your orders.
Here is the Vendors link: http://advrider.com/forums/showthrea...5#post19943845
p3
pilot3 screwed with this post 10-31-2012 at 09:28 PM Reason: added photos-move to vendors
pilot3 is offline   Reply With Quote
Old 10-30-2012, 06:07 AM   #14782
motonut
Old Guy
Oddometer: 62
Rear LEDs
p3
Very nice modification!
I too was not satisfied with my Tiger's rear lighting. I added an off the shelf, inexpensive and BRIGHT! LED tail/brake light and located it below the OEM light after lowering the license tag a bit. Overall, I'm totally happy with my mod but it ain't as purdy as yours!
Where did you source your plugs?
motonut is offline   Reply With Quote
Old 10-30-2012, 07:41 AM   #14783
doxbike
Oddometer: 273
Rear LEDS
Hey Pilot 3, put me down for one if you decide to make some more
doxbike is offline   Reply With Quote
Old 10-30-2012, 07:50 AM   #14784
Yossarian™
Deputy Cultural Attaché
Yossarian™'s Avatar
Oddometer: 9,656
+1
I think you may have just discovered a market for your well-designed accessory.
It looks better and fits more nicely than hyper-lites or other current aftermarket solutions.
Old 10-30-2012, 08:39 AM   #14785
swimmer
armchair asshole
swimmer's Avatar
Oddometer: 4,581
Originally Posted by Yossarian™ View Post
+1
+1 if the price is reasonable.
swimmer is online now   Reply With Quote
Old 10-30-2012, 09:31 AM   #14786
NaDSoB
Another asshole on a KLR
NaDSoB's Avatar
Oddometer: 364
Build it and they will come!
Great job!!!!
I'm in, too! Hope you can deliver soon!
Rob
"Tire tracks and broken hearts, that's all we're leaving behind.
It doesn't matter what we're losing, it only matters what we're going to find!"
Meat Loaf from "A Kiss Is A Terrible Thing To Waste", Lyrics by Jim Steinman
NaDSoB is offline   Reply With Quote
Old 10-30-2012, 09:37 AM   #14787
swimmer
armchair asshole
swimmer's Avatar
Oddometer: 4,581
And if you decide not to make the light kit perhaps you could give us a list of suppliers and part numbers that you used so that we could make our own without having to source all the parts all over again.
Old 10-30-2012, 11:57 AM   #14788
bigtallguy
Sasquatch Jr.
bigtallguy's Avatar
Oddometer: 254
I'm interested too, any idea on price?
Don't take life too seriously. You'll never get out of it alive.
bigtallguy is offline   Reply With Quote
Old 10-30-2012, 12:06 PM   #14789
fullmonte
Reformed Kneedragger
fullmonte's Avatar
Oddometer: 5,264
Originally Posted by The Breeze View Post
The weight of the muffler seems to make a lot of sense. The stock can is pretty damn heavy hanging of the right side of the bike. May have a new/lighter can in my future
Pm me if you are interested in a Leo Vince pipe. Does not fit with HT racks.
"If you are looking for the typical ride to a restaurant, eat tacos, hold the middle finger over the food, stop and take a picture of a gravel road type ride, you probably won't be interested." - dlrides
"A guy I know was the lead researcher for the University of Utah federally funded study of cellphone and texting use while driving. He found that your twice as dangerous as a drunk while using your cell phone and I think it was up to six times worse if the driver was texting."-dakardad
fullmonte is online now   Reply With Quote
Old 10-30-2012, 03:07 PM   #14790
browneye
PIN IT & BANG GEARS
browneye's Avatar
Oddometer: 5,639
Happy Trails Pannier Racks
Ah...another victim. I had to return my LV can. Pissed me right the fuck off.
They could have easily designed the rack to attach to any number of points on the frame, but instead they chose right where the muffler headpipe passes and the LV headpipe won't clear it. They said they are too busy to re-design it. I still may dump them and go with something else. I hate stock (quiet) cans.
Chris Brown - "The Browneye"
"Without Motorcycles, People Live Very Boring Lives." - Malcolm Smith
Camp Nelson 2014 RRLaguna Seca 2012 RRSequoia 3-Day CampoutThanksgiving 2012
browneye is offline   Reply With Quote
Times are GMT -7.   It's 09:54 AM.
