Go Back   ADVrider > Bikes > Beasts > British Beasts: Triumph Tigers
Old 11-05-2012, 06:53 AM   #14851
fullmonte
Reformed Kneedragger
fullmonte's Avatar
Oddometer: 5,398
My tank pad has come loose. Actually, its completely off now. What kind of goop do you guys recommend for reattaching it so it stays in place?
"If you are looking for the typical ride to a restaurant, eat tacos, hold the middle finger over the food, stop and take a picture of a gravel road type ride, you probably won't be interested." - dlrides
"A guy I know was the lead researcher for the University of Utah federally funded study of cellphone and texting use while driving. He found that your twice as dangerous as a drunk while using your cell phone and I think it was up to six times worse if the driver was texting."-dakardad
fullmonte is offline   Reply With Quote
Old 11-05-2012, 10:42 AM   #14852
Snapper
Snapper's Avatar
Oddometer: 2,512
Originally Posted by Yossarian™ View Post
It LOOKS backward, but when you think about it, when does the tire need maximum traction and water shedding ability? Under braking! That's why so many front tires have "backward looking" tread.
+1, primary purpose of rear is to accelerate, and front to decelerate, so tread blocks will always appear opposite, when the patterns are same or similar.
Lateral G Junkie
Fear Deer
Snapper is offline   Reply With Quote
Old 11-05-2012, 01:14 PM   #14853
ducnut
Oddometer: 3,320
Silicone should do the trick---the kind that comes in a tube.
'09 Triumph Tiger1050
'96 Ducati 900SS
'02 Suzuki SV650S (hers)
ducnut is offline   Reply With Quote
Old 11-05-2012, 01:19 PM   #14854
Dubl-A
SuckerDucker
Dubl-A's Avatar
Oddometer: 1,808
Try some outdoor double-sided tape. That crap is really hard to remove once applied.
Keep your $0.02 if it ain't going towards the bill
Dubl-A is offline   Reply With Quote
Old 11-05-2012, 03:10 PM   #14855
Kawidad
Kawidad's Avatar
Oddometer: 4,965
Originally Posted by dubl-a View Post
try some outdoor double-sided tape. That crap is really hard to remove once applied.
+1
Quis custodiet ipsos custodes? - Juvenal
(Who watches the watchers)
Kawidad is online now   Reply With Quote
Old 11-06-2012, 03:02 AM   #14856
blacktiger
Tigers R great.
blacktiger's Avatar
Oddometer: 3,867
Whilst I agree with your first bit, I disagree with the second, red bit.
Lets clear up one thing first. I'm not talking about tyre carcass construction here as I agree that the construction of the tyre needs to be opposite front and rear. I'm talking tread pattern which has nothing to do with construction but has everything to do with water dispersion.
The tyres are rolling the same way so the dispersion of water is the same front and rear. If the tread pattern is arrow shaped the point of the arrow needs to touch the road first so that as the tyre rolls the water is forced outwards away from the centre.
Avon http://www.avon-tyres.co.uk/motorcycle agree with me. All their tyres are pictured as if they're rolling away from you. That agrees with my logic on the subject. I've no idea why some others do it the other way round.
3 - 1 black Tigers. 955i+800XC (sold)+800XC=113000 miles of fun.
blacktiger screwed with this post 11-06-2012 at 03:21 AM
blacktiger is offline   Reply With Quote
Old 11-06-2012, 07:02 AM   #14857
ducnut
Oddometer: 3,320
A motorcycle tire puts down an elongated, oval contact patch. A car puts down one that is rectangular. A motorcycle's contact patch naturally disperses water, as it travels through a puddle. Whereas, a car tire will not; it needs grooves to disperse the water. Wet surface traction has more to do with the rubber compound (high silica content) than it does tread pattern, to a point. Only when water gets to a point do the grooves really come into play. If you watch any roadracing, you'll see the guys can go remarkably fast, on slicks, in the wet. What really affects them is that race (slicks, DOT race, etc) tires need a lot of heat, to make them properly work. Water cools them and is partly what causes the loss of traction. Conversely, a rain tire is really soft and designed to work at a cooler tread temp. Therefore, they simply fall apart on dry pavement. Obviously, there are a ton of variables, but, this is the gist of it.
As for your conclusion on Avon's tires, based on their website, you're incorrect. For whatever reason, their pictures show incorrect orientation. I've run, and sold, a variety of Avon tires, over the last 14 years. Their fronts definitely run opposite of the rears. As mentioned, tread grooves, almost always, run with the forces applied to the tire. If not, you'll get tread tearing, that'll begin, coming off those grooves.
'96 Ducati 900SS
Old 11-07-2012, 02:02 AM   #14858
blacktiger
Tigers R great.
blacktiger's Avatar
Oddometer: 3,867
Then you've been fitting them the wrong way round!
I think you need another look because I've run Avons a lot, here in the UK, and their tread pattern always caught my eye by running in the direction of my logic.
This one's in my garage at the moment. Distanzia front.
Old 11-07-2012, 04:18 AM   #14859
advtenn
advtenn's Avatar
Oddometer: 1,373
The Avon Gripsters look backwards when installed properly. They are to be installed per the directional arrow. I've run a couple of sets.
bikes guns and shine
"My body thinks my brains gone crazy" ..........Corky McMillian
advtenn is offline   Reply With Quote
Old 11-07-2012, 06:13 AM   #14860
ducnut
Oddometer: 3,320
Let me recant and say "many Avon front patterns run opposite of the rear".
I've not installed a set of Distanzias. I have installed all the Azaro/Storm (AV35/36-45/46-55/56), Cobra, and nearly all their sportbike series. And, all those fronts ran opposite. I removed a set of Gripsters and the front was opposite.
I can assure you, all my installs go on per their directional arrow.
'96 Ducati 900SS
Old 11-07-2012, 07:42 AM   #14861
blacktiger
Tigers R great.
blacktiger's Avatar
Oddometer: 3,867
It seems strange to me that different manufacturers have different ideas.
Old 11-07-2012, 07:43 AM   #14862
blacktiger
Tigers R great.
blacktiger's Avatar
Oddometer: 3,867
And now for something completely different..
So my pre-filter has been on for 6000 miles and I felt it was too dirty and I needed to clean it. I struggled to get it off as you can't really get a good hold of it from the outside.
So, as I had some other small jobs to do since getting back from Sardinia, I took off the tank and airbox lid to poke it out from the inside.
I was greeted with a very clean looking "clean" side of the DNA filter.....
Also a nice clean "dirty" side too.....
There is some dust in there which I suspect is being sucked in through the drain hole.
So I could then poke out the pre-filter with a screwdriver...
Boy it was filthy. Compare that to the first photo I took on instal......
+ I'll have to do something about it sitting on wires and a lug on the frame as it'll wear through in time....
I just glad to see that the pre-filter is doing its job so well. Makes me wonder if I actually need an airfilter in there at all since the pre-filter is doing all the work.
blacktiger screwed with this post 11-07-2012 at 07:49 AM
Old 11-07-2012, 08:16 AM   #14863
browneye
PIN IT & BANG GEARS
browneye's Avatar
Oddometer: 6,242
Good stuff.
Yeah, I found the pre-filter a bitch to work with unless you could gain access from inside the airbox. Mine has only been on for a thousand miles, maybe.
My immediate thought is that the paper filter in an inaccessbile airbox is a poor design for a bike that goes offroad. Surely not like any other 'dirt bike'. Alas...it is what it is.
Chris Brown - "The Browneye"
"Without Motorcycles, People Live Very Boring Lives." - Malcolm Smith
Camp Nelson 2014 RRLaguna Seca 2012 RRSequoia 3-Day CampoutThanksgiving 2012
browneye is online now   Reply With Quote
Old 11-07-2012, 09:07 AM   #14864
live2ridetahoe
RN
live2ridetahoe's Avatar
Oddometer: 1,482
Your results with the prefilter are impressive. Definitely thinking of one before my OBDR/WABDR trip next fall....
JG
live2ridetahoe is offline   Reply With Quote
Old 11-07-2012, 10:25 AM   #14865
Yankee Dog
Yankee Dog's Avatar
Oddometer: 1,997
Make you wonder if it is making your engine run rich.
2005 Ural
2005 BMW F650GS
2012 Triumph Tiger 800xc
Yankee Dog is online now   Reply With Quote
Times are GMT -7.   It's 08:17 AM.
