Old 07-29-2010, 07:15 AM   #1
wintonio OP
last of the Dum Dum Daze
wintonio's Avatar
Oddometer: 1,654
Honda CH150 - High speed rhythmic vibration happening
Hello. Yesterday I had the opportunity to open up the fairly new to me CH150 Elite.
When I got a bit above 45mph, a cyclical, rhythmic vibration started happening. The faster I went, the faster the rhythm and tempo of the vibration went.
I know I need to replace the engine hanger bushings, because they rattle, but any other ideas? I am sure it could use a new drive belt, but the one on there isn't splitting or cracking, just a bit dry.
What say you, master scooter mechanics?
wintonio is offline   Reply With Quote
Old 07-30-2010, 02:14 PM   #2
BurgerFriesDrink
BurgerFriesDrink's Avatar
Oddometer: 188
Start with the cheaper items. New drive belt is never a bad idea. Check your roller weights for uneven wear.
Then move on to more $$. Variator, clutch & bell, etc.
BurgerFriesDrink is offline   Reply With Quote
Old 07-30-2010, 02:50 PM   #3
brockster
Despair & Repair Garage
brockster's Avatar
Oddometer: 2,042
Wheel balances?
2001 HD XL1200S
1977 Vespa + 1985 Honda Elite
CB550K project.
Man whoever came up with Ronald McDonald was dropping some serious acid.
." - SpoonKiller / tiotalruckus.com
brockster is offline   Reply With Quote
Old 07-30-2010, 06:52 PM   #4
Coopdway
Curiouser
Coopdway's Avatar
Oddometer: 708
Lumpy tire not revealed with casual inspection?
Doug
Frontenac, MN
Chauncey likes to watch.......I like to ride
Coop's Corner
Coopdway is offline   Reply With Quote
Old 07-30-2010, 08:24 PM   #5
S/W
S/W's Avatar
Oddometer: 396
vibration
Try finding roads with a varied road surface. If the noise goes away on very smooth roads, it;s probably a wheel bearing, or tire. Otherwise, anything that can move or rotate, could be suspect. Try braking slightly at speed to see if that changes the sound, if the brakes are sticking or there is a rusty rotor, this could cause a noise.
If the bike has been idle for a long time, this could have caused the belt to take a set. This is a good place to look after other easier checks.
S/W is offline   Reply With Quote
Times are GMT -7.   It's 08:37 AM.
