Thread Tools Rating: Thread Rating: 8 votes, 5.00 average. Display Modes
Old 05-26-2012, 05:22 AM   #166
ddavidv
Thrifty not cheap
ddavidv's Avatar
Oddometer: 1,157
We got the 5 speed (neither of us can stand most automatics, and the CVT is worse). The stick used to only come with the 2.4, or maybe it's the 4x4...either way, the 2.0 isn't really common in the older ones from what shopping I did. And yes, ours is 4x4. It's mostly been slogging back and forth to work; still haven't had it on a good, long trip.
'04 Wee Strom
'89 KLR 650 (sold)
I write books!
http://www.amazon.com/David-Wittling...ntt_dp_epwbk_0
ddavidv is offline   Reply With Quote
Old 11-30-2012, 11:10 AM   #167
azcycle
Chihuahua Wrangler
azcycle's Avatar
Oddometer: 703
A small update here. For the past 6-months, there has been a "whine" that varies with throttle/speed. It's getting louder, and in doing some research, all Patriot owners with the CVT who have heard this whine have had their transmission kick the bucket. It also "bucked" quite alarmingly while climbing the local mountain twisties. I've got 85k on my 2007 and purchased it 6-months before Jeep started their lifetime drivetrain warranty. I will most likely limit miles on it, and trade it in come January before it implodes.
While the Jeep has been mostly problem free up to this point, I'm going back to Ford.
1981 BMW r65 - Photos
azcycle is offline   Reply With Quote
Old 11-30-2012, 01:33 PM   #168
jackd OP
Oddometer: 3,041
Original poster here. Well I'm sorry to hear about your CVT problems - good plan to trade it off in the new year.
I no longer have the RAV4 in my stable - the spouse and I parted ways and she got to keep it..... From my guess, it would seem to have been trouble free since it was purchased in 2010. My only complaint about it was the gas pedal - in the time that I drove it, I almost had 3 instances where my foot contacted the gas pedal as well as the brake pedal - the resultant near runaway each time was very concerning. I figured out that the RAV4 gas pedal is situated at the same height as the brake pedal and it is very easy to contact both if you aren't careful with your foot placement - and my feet are only a size 10. My Caravan has the gas pedal set back below the brake pedal so it is impossible to actuate both controls at the same time. All in all, the RAV4 cockpit is small - especially the foot wells. So Chrysler has the edge on safety in the foot control area.
I'll be looking for a replacement vehicle for myself down the road and I wonder what they'll be offering when the time comes. CVT's in everything? Or something worse.....
Old 11-30-2012, 02:48 PM   #169
PhiSig1071
What's ******width?
PhiSig1071's Avatar
Oddometer: 2,470
Diesel CX5 or Escape.
Which one of you FF's was it?...FOUNDER!
Entia non sunt multiplicanda praeter necessitatem
PhiSig1071 is online now   Reply With Quote
Old 11-30-2012, 03:01 PM   #170
jackd OP
Oddometer: 3,041
It will never be a Ford. CX5 - Mazda? I might even consider a CRV or some other Toyota product.
Old 11-30-2012, 03:09 PM   #171
PhiSig1071
What's ******width?
PhiSig1071's Avatar
Oddometer: 2,470
We looked at the CX5 and came very close to buying one. Ultimately a bad experience with the dealer and the low tow rating meant we went with the Toyota. If they had the diesel available we would have certainly gotten it.
Old 11-30-2012, 03:48 PM   #172
jackd OP
Oddometer: 3,041
Which Toyota?
Old 11-30-2012, 04:15 PM   #173
PhiSig1071
What's ******width?
PhiSig1071's Avatar
Oddometer: 2,470
Which Toyota?
'12 Rav4 V6. 3500lbs tow rating, 26mpg highway.
Old 02-04-2013, 02:31 PM   #174
azcycle
Chihuahua Wrangler
azcycle's Avatar
Oddometer: 703
Another update. The whine was getting worse and a new sound was added that made the Patriot sound like a diesel at idle. It was so loud that people would turn and look when I pulled into parking spots. I took it to the local dealership for an oil change and had them isolate the clatter. Turns out it was the alternator beginning to self-destruct.
In doing some research, I found this fairly common. Dealership quoted me $680 to replace the alternator. Eff that. Found out how to do it myself, and bought a high-output alternator from the local parts store for $240. Four hours later and after lots of curses thrown at whomever designed this thing (accompanied by banged up knuckles) I got the alternator changed out.
Had to remove passenger front tire, inner fender splash shield, huge plastic mud guard underneath, drop and relocate the AC compressor, and remove one serpentine pulley. Then the alternator could drop down and out under the front bumper. I really miss working on old cars!
Started the Pat up and ..... it was quiet. No loud whining or clatter! So while I'm still suspicious about the remaining life in the CVT, it was not the cause of the whine.
Old 02-04-2013, 02:39 PM   #175
Bueller
Cashin?
Bueller's Avatar
Oddometer: 17,276
I'm sure the dealer's alternator cost more than the one you bought, but considering the amount of time it took you to change it the total quote including labor doesn't seem to have been too far off.
"Bueller, you're an island of sense in a sea of bullshit" - swimmer
"bueller, you ARE an island of reason in a sea of bullshit" - quasigentrified
Bueller is offline   Reply With Quote
Old 02-04-2013, 02:47 PM   #176
azcycle
Chihuahua Wrangler
azcycle's Avatar
Oddometer: 703
Actually, the dealer's alternator was also in the $240 range so I just saved a ton of labor and learned a bit about my Jeep. It wasn't a technically tough job... just lots of removing/unbolting other "stuff" just to get to the alternator.
Old 02-04-2013, 02:54 PM   #177
Bueller
Cashin?
Bueller's Avatar
Oddometer: 17,276
Being in Tucson I'm going to guess the dealer is about $100 - $110 per flat rate hour. Sounds about right.
Thread Tools
Times are GMT -7.   It's 05:35 PM.
