Go Back   ADVrider > Riding > Regional forums > Pacific Northwet - Where it's green. And wet.
Old 08-07-2010, 04:10 PM   #61
teamchaos
That should work!!
teamchaos's Avatar
Oddometer: 119
Originally Posted by richard.bessey
Missed/forgot about this AGAIN! I have a good excuse though, I was riding out by Umapine.
Hopefully I will remember next time!
The Watering Hole, in Umapine, has great hamburgers. Maybe we should meet there next!
Nothing good ever happens after you say "Hold my beer and watch this."
My ride reports:
Troy, OR
Glacier National Park
Dayton, WA
teamchaos is offline   Reply With Quote
Old 08-07-2010, 06:59 PM   #62
Smithee
F650 Beemerider
Smithee's Avatar
Oddometer: 269
I'm hoping I figured out my running rich problem.
Took a nice, head-clearing ride in the mountains with some friends on the V-Star today. We ate at the cafe at Spout Springs (better breakfast places available). When I got back, the temps weren't too bad so I decided to tackle the carbs. Pulled the tank and dug into the carbs. Diaphragms look good. No tears or pin holes. I dropped the needle one notch on the right carb. Put that carb back together.
Pulled the top off the left carb and removed the diaphragm slide and needle assembly. THE NEEDLE WAS SEIZED UP. For whatever reason (spring jammed?) the needle was not sliding freely. I pulled the spring and popped the needle up with pressure from my finger. I'm thinking this has to be the problem. We shall see. In any event, I dropped the needle one notch.
I haven't closed things up yet. Question is, in light of the stuck slide, should I just leave the needle clip settings where they were or leave them as I set them, dropped one notch? Worst case scenario, I'll run a little lean and have to dig back in and restore the needle clip positions.
~Smithee
'07 BMWf650gs
'08 Victory Vision
'05 Yamaha V-Star Classic "Ultra Star" (for sale, make an offer)
Spot Track SmugMug Photos
Smithee is offline   Reply With Quote
Old 08-07-2010, 08:03 PM   #63
teamchaos
That should work!!
teamchaos's Avatar
Oddometer: 119
With my dirt bikes I always error on the side of running on the rich side.
Glad to hear you might have it figured out.
My ride reports:
Troy, OR
Dayton, WA
Old 08-07-2010, 08:44 PM   #64
Smithee
F650 Beemerider
Smithee's Avatar
Oddometer: 269
We shall see. I agree, err on the side of rich. Assuming the stuck needle is the problem, I may end up lean, but that's easy enough to fix by repositioning the needles. A 60 minute or less operation, now that I've done it once.
~Smithee
'07 BMWf650gs
'08 Victory Vision
Old 08-07-2010, 09:23 PM   #65
rjmorel
Dual Sporticus
Oddometer: 293
Id say give it a try like you have them and ride up in elevation like you were when it ran bad and see how it acts. Like you say you can always put them back where they were. Too lean would probably pop on deceleration like the KLR and DR 650's do when they come lean from the factory set to meet emitions. Fix is to raise the needle up 1-2 notches or put a shim under the circlip if it's not adjustable to raise it up.
Also was the needle stuck in the opened up throttle position or down in the idle position? If stuck in the opened up throttle position then thats definitely going to run rich as it would be pulling lots of fuel out even though you are idling , putting around at slow speed I think.
GreatNortoni , have a great time this coming week on your solo trip through Oregon. We'll be thinking of you for safe passage and wished we were all there riding with you. rj
Dream Ride :I dream everytime I ride , even around town. There top that one.
Ride the world, we'll do Mars next year
2012 Honda NC700x (Dual Sporticus) shaken ,not stirred
rjmorel is offline   Reply With Quote
Old 08-07-2010, 10:44 PM   #66
richard.bessey OP
Hard Rider
richard.bessey's Avatar
Oddometer: 514
Try it
Personally, I would try it and see if it makes any difference.
As stated before, I like to run on the rich side personally.
Another option, after market exhaust.
Work Hard, Play Hard, Ride Hard
1994 XT 350 - The dirt machine
1992 TDM 850 - The street ride
1988 TW 200 - Wifes Ride
richard.bessey is offline   Reply With Quote
Old 08-08-2010, 09:31 AM   #67
dhally
Hammerhead
dhally's Avatar
Oddometer: 2,275
I've found that my bikes run best for the range of elevations around here a little leaner than the "conventional wisdom" on advrider, but a little richer than factory settings. If the bike was factory stock when you started, it seems unlikely that leaner would be better considering the elevations.
WR250R
Sherco 300i
Tiger 800 - FOR SALE
dhally is offline   Reply With Quote
Old 08-08-2010, 11:09 AM   #68
Smithee
F650 Beemerider
Smithee's Avatar
Oddometer: 269
Bike is not factory stock. A prior owner did a Canisteriectomy (removal of charcoal canister that causes some problems). Also appears to have mucked around with the airbox, as the vacuum outlet on the right carb that should run to the airbox is capped (along with the one that had been hooked to the canister).
Tank back on and it starts and idles well. I'll take her out for a ride and see what I think. I have new plugs in so we'll see if they get carboned up.
~Smithee
'07 BMWf650gs
'08 Victory Vision
Old 08-08-2010, 11:55 AM   #69
greatnortoni
Oddometer: 432
Off to see the wizard
I am leaving for a little week long trip around parts of Oregon (the vast waste land as my lady friend puts it), so if there will be a meeting of us ADV hooligans this week I will miss it, just have to catch up with you all the following week.
Here's to wearing out the knobbies!
greatnortoni
greatnortoni is offline   Reply With Quote
Old 08-08-2010, 12:55 PM   #70
Smithee
F650 Beemerider
Smithee's Avatar
Oddometer: 269
greatnortoni
Enjoy!
~Smithee
'07 BMWf650gs
'08 Victory Vision
Old 08-08-2010, 04:53 PM   #71
Smithee
F650 Beemerider
Smithee's Avatar
Oddometer: 269
F650 Running Rich
Well, it's getting better. I got the carbs back together and popped in a new set of plugs this morning. Bike runs well. I decided to try it at altitude and took the pavement up to Tollgate. Rode pretty hard on the way up. My buddy behind me said it is still putting out some black smoke when I get on it, but not as much as before. I didn't have any of the stumbling issues I did last weekend, and the bike started right up without any problems when it was time to head back down. Filled up at the Co-Op when I got back to town. 3.5 gallons for 120 miles. 17 of those miles were pre-carb fix. Long and short, I got a mileage improvement of at least 24% over what I had before. Not bad but not totally satisfactory.
Next step is to replace the stock plug covers. I may still need to put in a more restrictive main jet but before I do that I want to dig into the airbox to see if prior owners mucked anything up in there.
~Smithee
'07 BMWf650gs
'08 Victory Vision
Old 08-08-2010, 09:51 PM   #72
teamchaos
That should work!!
teamchaos's Avatar
Oddometer: 119
Smithee,
I have 4 carbs for you to work on next. Just think, double the fun!!
My ride reports:
Troy, OR
Dayton, WA
Old 08-09-2010, 12:08 PM   #73
rjmorel
Dual Sporticus
Oddometer: 293
OK, I know I whimped out on a ride report and pics of the Gorge Rally so here is a link to the pro photog's pics that they took all for days . Way better then my abilities. does this get me off the hook Caos ??? rj
rjmorel screwed with this post 08-09-2010 at 02:28 PM
Old 08-10-2010, 07:58 PM   #74
teamchaos
That should work!!
teamchaos's Avatar
Oddometer: 119
It's has been so long since you promised a ride report, I had forgotten all about it.
My ride reports:
Troy, OR
Dayton, WA
Old 08-11-2010, 09:48 AM   #75
rjmorel
Dual Sporticus
Oddometer: 293
Good , now I'm really off the hook. rj
Times are GMT -7.   It's 04:34 PM.
