07-29-2010, 12:42 AM
#16 | |
Perpetual ponderer
Oddometer: 1,663
Every ride's an adventure if you can't ride for crap http://www.dragtimes.com/Ducati-Mons...lip-10329.html |
07-30-2010, 06:43 AM
#17 |
Nobody Home
Disclaimer: I have no experience with car tires on a motorcycle/scooter.
That said, has anyone considered the weight difference? A car tire is going to weigh more, due to its construction, than a motorcycle/scooter tire. That's more un-sprung weight which means your forks/shocks are going to work harder (or be worked above their intended threshold). I'm inclined to stay with less un-sprung weight and something that's constructed with the bike/scoot in mind. Just my $0.02.
There are some simple thruths......and dogs know what they are - Joseph Duemer Andy holds the lead. And he will, all the way to the Highway. Today is his day. |
07-30-2010, 07:55 PM
#18 | |
Oddometer: 390
Yeah, me too. I dunno, at $50~ a tire I can't justify swapping to a car tire for longevity reasons.
2001 Honda Reflex ABS |
07-30-2010, 09:21 PM
#19 | |
Oddometer: 82
The lower the PSI on the darkside tire, the more shock is absorbed. |
07-30-2010, 11:04 PM
#20 | |
Perpetual ponderer
Oddometer: 1,663
I'm going to put one on the Vmax, the bias ply tyres make things "interesting" , and as much as that's fun mostly, it would be nice to not slip around everywhere around corners.On ModernVespa 1 bloke has used one on the back of a 250GTS, coz he's doing 900miles a month commuting , so I rekn that's a good reason.
07-31-2010, 10:40 AM
#21 | |
Nobody Home
But, aren't you now putting more heat into the tire due to the lower PSI (to absorb shock)? And, aren't you forgoing some efficiency (i.e. mpg) with the lower pressure? There's another "dark side" thread with an "under scoot" video. The person that posted the video states the (car) tire is at 40 PSI (so it has some 'crown'). That's 11 PSI more than my rear tire's suggested operating pressure and I would think that would transfer more shock to the scoot, not less. Maybe I'm not getting it?
07-31-2010, 05:49 PM
#22 |
iscoot
Oddometer: 43
Local MC writer talked about this recently and made an interesting point: if using a car tire for the rear is so great, why don't they recommend using it in the FRONT also?
![]() Left Coast, Kalifornia 2009 Yamaha Tmax 2004 Aprilia Atlantic 200 RIP |
07-31-2010, 07:01 PM
#23 | |
I'm that other guy
Oddometer: 2,083
Darksiders are also fans of running rear tires on the front (mounted backwards - as far as rotational direction) because they work well, and last longer. Car tire on the front? Well... that's just stupid.
If a hammer don't fix it, then it's an electrical problem. |
08-03-2010, 02:18 PM
#24 |
Here...Hold my Beer.
Oddometer: 2,374
08-03-2010, 02:20 PM
#25 |
Oddometer: 2,374
08-03-2010, 04:42 PM
#26 | |
Oddometer: 1,119
08-04-2010, 05:10 AM
#27 |
Oddometer: 2,079
2010 Buell Ulysses 1984 Suzuki GR650 "Tempter" |
08-04-2010, 06:33 AM
#28 | |
Perpetual ponderer
Oddometer: 1,663
08-04-2010, 09:46 AM
#29 |
Oddometer: 507
So, if I understand correctly, the main reason people do this is because car tires last longer. In other words, they are willing to increase the risk of riding a motorcycle, which is already risky enough, to save a few bucks.
Of course I'm assuming that car tires don't work as well on a motorcycle as tires specifically designed for motorcycles would work, and by that I mean that they don't handle as well in all conditions as motorcycle tires would, such as when you might have to stop quickly on a wet road while going around a turn. It seems to me as if the decision to use car tires is alot like making the decision to ride non-ATGATT. It saves money, and as long as you can convince yourself that everything always goes according to plan, and you'll never wish you had a bit of added safety net, you will be happy, right up to the moment you crash. And the fact that you haven't crashed yet doesn't mean you haven't reduced your safety. I would love to see a magazine or the like pick up on this idea and do some objective comparisons of motorcycle tires and car tires on motorcycles. |
08-04-2010, 09:57 AM
#30 | |
Perpetual ponderer
Oddometer: 1,663
Even better would be a pic of the tyre over on a 25deg angle riding over a clear panel, with the camera under it, so I could SEE that the contact patch is LARGER than a normal MC tyre, rather than just figuring it out via pictures of the tyre from different angles and working out sqr area....... Still going to try it out though, because the alternative for ME in MY situation with how I RIDE, is paying twice as much for tyres that last 1/10 the time, and only give crap handling while they're at it.
