Go Back   ADVrider > Fluff > Shiny Things
Thread Tools Rating: Thread Rating: 17 votes, 5.00 average. Display Modes
Old 08-21-2011, 07:32 AM   #106
vtwin OP
Air cooled runnin' mon
vtwin's Avatar
Oddometer: 7,728
Originally Posted by d mc gee View Post
Saw this today out on a ride. Looked really cool.
Nice! Not alot of panels around these days.
"Alles hat ein Ende--nur die Wurst, sie hat zwei"
Monroe.
"You only have too much fuel if you're on fire"
unknown
vtwin is offline   Reply With Quote
Old 08-21-2011, 07:36 AM   #107
vtwin OP
vtwin's Avatar
Oddometer: 7,728
Photo borrowed from another website. Very cool stuff here...
http://www.garagejournal.com/forum/showthread.php?t=51567
Monroe.
unknown
Old 08-24-2011, 06:28 PM   #108
vtwin OP
vtwin's Avatar
Oddometer: 7,728
Ok, tried out my new to me axle puller since nothing else will work. I've put so much pressure on the puller, it's distorting the saucer portion. Nut is loose, brakes not hanging up, emergency brake off and it moved about 3/8" and stopped. i'm literally standing on a breaker bar turning the center bolt, not go. maybe the blue wrench on the hub? right now, I've go pressure on it and hoping in the middle of the night I'll hear a pop and it will be free.
Yes, the saucer is on wrong in this picture.
Monroe.
unknown
Old 08-24-2011, 08:27 PM   #109
d mc gee
d mc gee's Avatar
Oddometer: 804
Did you try loosening the brake shoe adjuster?
If it wasn't for my graceful wife, my dumbass would be banned already
Doug Mc Gee
01 1150 GS
84 R100RS
74 XL350
d mc gee is offline   Reply With Quote
Old 08-24-2011, 08:36 PM   #110
Toadady
Push'n parts
Toadady's Avatar
Oddometer: 4,049
smack it with a hammer, right at the hub as close to the center as you can.
Get to work, millions on welfare are depending on you
Toadady is online now   Reply With Quote
Old 08-24-2011, 10:45 PM   #111
Roadracer_Al
louder, louder, louder!
Roadracer_Al's Avatar
Oddometer: 1,689
That's a nice looking puller.
You say that the drum moves 3/8? Shift it back and forth, working your way around the rim -- i.e. beat on it at 12:00, push it back on, beat on it at 1:00, push it back on, beat on it at 2:00, etc, etc.
If you still have no luck, it's possible that the drums are so worn out that they have a lip that it catching on the shoes. You'd need to back even further off the adjuster.
On one vehicle, I drifted the wheel studs out to get a *very* stuck drum off.
Are there any "jacking screws" or screw holes on the drum inside the wheel stud bolt circle? If not, you can add some once you get it off. They work great.
When they say Harleys are for 1%ers, I don't think they mean guys who sell crank and get in bar fights any more.
Roadracer_Al is offline   Reply With Quote
Old 08-25-2011, 02:20 AM   #112
cornercarver
cornercarver's Avatar
Oddometer: 18,536
From the thread title, I thought this was going to be a thread about telecommuting
cornercarver is offline   Reply With Quote
Old 08-25-2011, 09:35 AM   #113
IHWillys
IHWillys's Avatar
Oddometer: 266
Ah, a Willys thread. Perhaps I should post a pic here since my user name is due to a 1951 Willys wagon body I put on a '76 Scout chassis, thus the IHWillys online handle. Yeah, it's a mutt that's arguably more Scout than Willys but it is one of the possibilities resulting from having a Willys with a crap frame(someone torch cut the drivetrain out of it) and a Scout with no body(well, it had a partial floorpan, firewall and the windshield still there). I'm no master builder but this thing was uber reliable over the years I had it, hauled tons of rock out of the mountains(over 30 trips loaded to the point hitting the rear bumpstops even with helper springs) and was a decent camper vehicle too.
Ken
IHWillys is online now   Reply With Quote
Old 08-25-2011, 06:08 PM   #114
vtwin OP
vtwin's Avatar
Oddometer: 7,728
Ken
Nice, since it saves you from installing disc brakes from the Scout and then having to shim the axle for caster etc.
Monroe.
unknown
Old 08-25-2011, 06:11 PM   #115
vtwin OP
vtwin's Avatar
Oddometer: 7,728
the drum isn't hanging on the shoes as the drum rotates freely. I need to get ahold of an acetylene torch to heat the hub off. The axle is tapered and should have released the hub once I got it to move. Maybe the dpo smashed down the woodruff key and it's jamming on that.
Monroe.
unknown
Old 08-26-2011, 11:30 PM   #116
larryboy
Chopper Rider
larryboy's Avatar
Oddometer: 15,221
No lip on the drum? If it moved it's free, lip inside the drum from wear might be snagging the shoe keeping the drum from coming off.
Old 08-27-2011, 06:41 AM   #117
H96669
A proud pragmatist.
H96669's Avatar
Oddometer: 4,744
If that's what it is....cut the two "nails" holding the brake shoes in place from the back, everything should fall off.
It has been a long time since I played with one of them pullers...40 years but.....how can I forget!
Have tools, will travel!
Old 08-27-2011, 07:47 AM   #118
vtwin OP
vtwin's Avatar
Oddometer: 7,728
Not much of a lip as when I rotate the drum, it barely contacts the shoes. I can see a gap between the drum and the backing plate, usually there would be an overlap. So It's moved some. i'll try to take a better picture. The puller is starting to distort from all the effort, time for the blue wrench, which unfortunately is only Map gas, no oxy.
Monroe.
unknown
Old 08-27-2011, 07:49 AM   #119
vtwin OP
vtwin's Avatar
Oddometer: 7,728
I'll see if I can get the hold downs off and I can probably unbolt the wheel cylinders as I've got new ones anyway. Only thing left would be the lower portion of the backing plate holding the shoes on as they are fixed. Will take some better pictures today.
Monroe.
unknown
Old 09-02-2011, 03:03 PM   #120
wyowillys46
Hau Ruck!
wyowillys46's Avatar
Oddometer: 2,115
Some recent day trips.
Stupid camera blew the lighting.
"I swear to god, it's like I live in a trailer of common sense, and stare out the window at a tornado of stupidity." -Roscowgo
wyowillys46 is offline   Reply With Quote
Thread Tools
Times are GMT -7.   It's 11:51 AM.
