Thread Tools Rating: Thread Rating: 10 votes, 5.00 average. Display Modes
Old 09-02-2011, 06:15 PM   #121
vtwin OP
Air cooled runnin' mon
vtwin's Avatar
Oddometer: 7,373
Originally Posted by wyowillys46 View Post
Some recent day trips.
Stupid camera blew the lighting.
"Alles hat ein Ende--nur die Wurst, sie hat zwei"
Monroe.
"You only have too much fuel if you're on fire"
unknown
vtwin is offline   Reply With Quote
Old 09-02-2011, 06:19 PM   #122
vtwin OP
vtwin's Avatar
Oddometer: 7,373
Ok, seems the Willys requires a heavy hand! I decided I'd had enough of
this dilly-dallying and really have a go at the left rear drum/hub. I
switched positions on the puller after using my IR244 to tighten the hub nut
and
then loosen it again. Then using my Mapp Gas torch, blasted the hub with
heat until it got cherry red and grease was draining out. Then I went to town
on the puller and using my substanial 160lbs on a breaker bar, two
revolutions of the puller and (like Emeril) BAM!, it finally freed itself from
it's
death grip. I think I'll go relax now.
Here is the offending part...
It was on so tight that when it finally broke free, this happened to the right side!
The right side axle shot out. I didn't know until this morning while getting something, wth?
Monroe.
unknown
vtwin screwed with this post 09-03-2011 at 01:10 PM
Old 10-15-2011, 09:38 PM   #123
vtwin OP
vtwin's Avatar
Oddometer: 7,373
Progress...
After sitting for two years with me and sitting for 10 years before that.
Monroe.
unknown
Old 10-17-2011, 11:59 PM   #124
FishHunt
slow poking...
FishHunt's Avatar
Oddometer: 1,340
I saw this Willys setting at an overlook on the Blue Ridge Parkway this past Sunday. It had 1960 Virginia tags. I'd like to have one like this setting in the driveway.
<>< Fish
V-Strom 650 Averaging 100 Smiles per gallon
Be good and you will be lonesome - Mark Twain
____________________________________
FishHunt is offline   Reply With Quote
Old 10-18-2011, 08:55 AM   #125
ssm
ssm's Avatar
Oddometer: 322
Not mine. Saw this while riding around the Catskills over Columbus Day weekend....that's my bike in the first picture.
ssm is offline   Reply With Quote
Old 10-18-2011, 08:32 PM   #126
vtwin OP
vtwin's Avatar
Oddometer: 7,373
Built on a Blazer chassis.
Monroe.
unknown
Old 10-23-2011, 06:30 PM   #127
vtwin OP
vtwin's Avatar
Oddometer: 7,373
Progress is slow, but steady and in the right direction. Since going to the dual master circuit, problem arose to how to get the brake lights working. The old system used a pressure switch. Those familiar with british cars know these things are common. Since I didn't want to use that type, a recommended one is a universal brake switch as used by hot rodders. Sold by Summitt and such.
Since I'm lazy and cheap, I decided that there must be a better way. Enter the motorcycle! Someone on a mailing list I'm on was parting out a bike and I got the rear brake switch from him, a plunger type. Uses a spring that attaches to the rear brake pedal and once pulled, activates the switch, really simple. So I made up a bracket to mount it.
I had this one laying around and hogged out the top hole so the switch could mount up.
Ok, that bracket was too short and the angle too extreme for it to last a long time. So I found an alternator adjustment bracket that was longer.
A little drilling and fitting and voila!
And it even works! This is temporary until I can get some sort of locking tab on the bracket to keep it from spinning and dropping down. Or maybe I'll get really lazy and just run another longer bolt above the mounting one and it will keep it from spinning down.
Monroe.
unknown
vtwin screwed with this post 10-23-2011 at 06:35 PM
Old 12-17-2011, 04:08 PM   #128
vtwin OP
vtwin's Avatar
Oddometer: 7,373
Due to family coming over for the holidays, I had to move the Willys. So, for it's maiden voyage of "ran when parked" some 12 years ago, I present this....
This before I adjusted to clutch to get rid of the grinding into gear.
Monroe.
unknown
Old 01-16-2012, 02:34 PM   #129
vtwin OP
vtwin's Avatar
Oddometer: 7,373
Got a good price on these tires, but I may have overdone it. They look like cartoon balloon tires now.
Tires are a bit hard to get for these rims, 5 x 5.5. Replaced the 7.00 x 16 with 235/85 x 16, wow!
Monroe.
unknown
Old 01-16-2012, 05:25 PM   #130
AKjeff
AKjeff's Avatar
Oddometer: 5,137
How did I miss this
I still remember the first drive in mine, I was having so much fun I went around the block twice.
"We can choose to know better or choose to be bitter." OldRoadToad
AKjeff is offline   Reply With Quote
Old 01-17-2012, 01:14 AM   #131
aquadog
Dude Buddha
Oddometer: 654
Subscribed. How could I have missed this? I have three 4x4 Willys All-Steel Wagons awaiting attention. Back later.
aquadog is offline   Reply With Quote
Old 01-29-2012, 03:14 PM   #132
vtwin OP
vtwin's Avatar
Oddometer: 7,373
Finally rounded up enough 235/85 x 16s and had them mounted. Boy they sure make the truck look like a Tonka Toy.
This guy worked hard and smart on my wheels. He scraped clean the mating surfaces for both the beads and the valve stems since the wheels were running tubes before.
Steering was alot lighter feeling than I thought it would be, especailly since it has armstrong power assist. And it rides like, well an old truck. Will be ordering a set of leaf spring bushings since they are non existant.
Monroe.
unknown
vtwin screwed with this post 01-30-2012 at 06:09 PM
Old 03-06-2012, 07:34 PM   #133
vtwin OP
vtwin's Avatar
Oddometer: 7,373
Saw this today. Looks like it moved not too long ago.
This was parked near it....
Monroe.
unknown
Old 03-09-2012, 11:15 AM   #134
H96669
A proud pragmatist.
H96669's Avatar
Oddometer: 4,536
One here, a 63 with original paint/ lettering, PTO winch. "Province of British Columbia".
Couldn't get closer was on crutches no jumping ditches but all the undercarriage had been painted so probably a lot of mechanical work already done. $4,500.00 too rich for me these days.
Have tools, will travel!
Old 03-09-2012, 06:49 PM   #135
vtwin OP
vtwin's Avatar
Oddometer: 7,373
Wow, pricey.
Monroe.
unknown
Thread Tools
Times are GMT -7.   It's 10:12 PM.
