Go Back   ADVrider > Fluff > Shiny Things
Thread Tools Rating: Thread Rating: 152 votes, 4.97 average. Display Modes
Old 05-07-2014, 03:12 PM   #1306
MeanMoe
one really mean cat
MeanMoe's Avatar
Oddometer: 2,908
Originally Posted by BlueLghtning View Post
I hadn't seen this one linked before - http://themindunleashed.org/2014/04/...igh-costs.html
Nice setup but I don't like the idea of having to crawl over someone to get into, or out of the bedroom.
Crawling on hands and knees doesn't work either.
MeanMoe is offline   Reply With Quote
Old 05-07-2014, 03:18 PM   #1307
Hay Ewe
Just a Wannabe
Hay Ewe's Avatar
Oddometer: 3,000
Depends on who you are crawling over? but after the third night it might get a bit old
I kinda like this one, if I was on my own. I see these small set ups and think I would go spare when I need my own space some times.
Hay Ewe
Moments before you die, your life will flash before your eyes - make sure the film is worth watching - my Grandad
Don't go gentle into the long final good night from which no man has yet returned.
Moose Antlers need love too.
Hay Ewe is offline   Reply With Quote
Old 05-07-2014, 08:30 PM   #1308
BlueLghtning
Riding is my passion
BlueLghtning's Avatar
Oddometer: 5,403
True, but it would probably work just as well with the bed turned the other way and you just had to crawl out towards the foot of the bed?
BlueLghtning - Follow me on my SPOT Messenger
Mine: KTM 650 ADV (Katuki), 09 DL650, 08 Husky TE610, 08 WR250R
Hers: 07 Ninja 650R, 13 CRF250L
Smugmug Pics - Save $5 <-- Click Here
BlueLghtning is offline   Reply With Quote
Old 05-08-2014, 12:24 AM   #1309
DriveShaft
Oddometer: 4,530
Stumbling down a ladder at 3am to get to your crapper gets old faster than crawling over your gf, in my experience. But if I was honest w/ myself, I could tolerate it most of the time, unless I were drunk off my ass.
He openly admits in his blog that he doesn't have a good answer to how to handle water service or sewer lines, since he's planning on in-board holding tanks and garden hose water supply, heat tape to keep those things patent in winter months. Going to be difficult to actually do that w/ shower drain to consider. In truth the tanks will sit under chassis like a normal rv, w/ heat tape and heat pads to the exit port. Have fun dumping your frozen lines. I wonder if he's going to bother w/ a proper septic leach field. Nah, better to have to dump 30 gallons every other day.
Fully sealed foamed in construction. He expounds upon the need to install a ventilation fan, bcs his box is sealed up tight, w/ significant moisture generators (shower, propane, and 3 bodies). Great...One well ventilated corner of the house forcing air exchange to handle moisture control. Not what I'd call well thought out.
DriveShaft screwed with this post 05-08-2014 at 12:44 AM
DriveShaft is offline   Reply With Quote
Old 05-08-2014, 03:29 PM   #1310
spagthorpe
spagthorpe's Avatar
Oddometer: 14,748
In truth, you don't have to do much with shower, sink and laundry water. When I lived in the mountains, we used biodegradable products and just ran it all down a hose into the yard where it was split to water things. The property at the time had a very old and very marginal septic system, and it couldn't handle normal use. The occasional toilet flush was about it.
spagthorpe is offline   Reply With Quote
Old 05-08-2014, 07:01 PM   #1311
12ARX
12ARX's Avatar
Oddometer: 1,498
Tiny enough?
http://viralcircus.com/ive-seen-peop...te-brilliance/
Current Ride:
09 DR650SE
12ARX is offline   Reply With Quote
Old 05-08-2014, 07:25 PM   #1312
viajero
Too old to be a nOOb
Oddometer: 2,442
Originally Posted by 12ARX View Post
That's fucking awesome.
viajero is offline   Reply With Quote
Old 05-08-2014, 07:27 PM   #1313
Manuel Garcia O'Kely
Back at last
Manuel Garcia O'Kely's Avatar
Oddometer: 13,586
The bedroom needs a bit more thought, but I think this one is better than most in design and execution, I like the outdoor propane porch and storage.
Never ascribe to Evil that which is more resonably explained by Ignorance and Stupidity
There's casting, then there's running into the stream with a baseball bat trying to club the fish to death. - Jim Moore
Manuel Garcia O'Kely is offline   Reply With Quote
Old 05-09-2014, 03:25 AM   #1314
Mister T
Waste Mgmt Consult
Mister T's Avatar
Oddometer: 453
I think my house moves a tiny bit almost every day. It sure creaks and pops and groans a lot.
No One Gets Left Behind - Once a Marine, always a Marine. Ooh Rah!
Mister T is offline   Reply With Quote
Old 05-09-2014, 09:21 AM   #1315
RockyRaccoon
Found:Gideon's Bible
RockyRaccoon's Avatar
Oddometer: 63,702
Here's an interesting site that might be useful as a source of ideas for those looking at building a little house.
http://accessorydwellings.org/
It's only a scratch.
“It is a far, far better thing to have a firm anchor in nonsense than to put out on the troubled seas of thought.” -- John Kenneth Galbraith
RockyRaccoon is offline   Reply With Quote
Old 05-09-2014, 11:09 AM   #1316
DriveShaft
Oddometer: 4,530
If all you're putting down the drain is shampoo and Ivory Soap, that's great. You can make a great hobby out of grey water management. But that's not all you're going to be putting down your primary residence's drain. Sometimes, you actually need to clean your oven. Sometimes you actually have solids/chemicals/crap in there that are a pain in the ass to filter out, and yet not what you want to water your tomatoes with. It happens. Even it it only happens 5% of the days that you use it...5% of full time living, that's still 55 days out of the year that your less-than-substantial waste-water management solution is a headache for you. That's a lousy service level to shoot for. Architects and designers should really be required to do service level math on the shit they design. If the little house movement is about being zen with your environment, one thing I think is pretty important to factor in is the fact that such a notion is aspirational. You're gonna fail at it...some of the time. Want success? Design for your aspirations. But plan for failure.
Old 05-09-2014, 05:32 PM   #1317
spagthorpe
spagthorpe's Avatar
Oddometer: 14,748
Actually, we never put any chemicals down our drains. Or solids. I can't think of a case where it was needed. If we had anything nasty, it went in the garbage and was picked up by waste management. Anything that fell into the chemical catagory, which was usually motor vehicle related, went to the local recycling station. I don't think it was that difficult of a lifestyle.
Old 05-09-2014, 05:47 PM   #1318
WestTXDR
Oddometer: 164
http://www.harvestingrainwater.com/g...nd-detergents/
Here's a good primer on greywater friendly soaps.
Darrell
2009 Suzuki DR650SE, Black
2008 Suzuki DR200SE, Black, Wife's bike
2002 BMW R1150RT Silver
IBA#22317
KE5EXE
WestTXDR is offline   Reply With Quote
Old 05-10-2014, 06:30 PM   #1319
PaddedHat
Oddometer: 732
This whole idea of ship ladders, no guard rails etc. prevalent in most of these micro homes, is flat out stupid. Trendy, but guaranteed to end up with an unhappy ending if you spend enough time temping fate. I recall a few years back when a local headed up to his remote hunting cabin, by himself, for a quiet weekend. When he didn't show up by Monday morning, the family asked for a welfare check. The state police found him dead at the bottom of the loft ladder, with a broken neck. The coroner determined that he had became disoriented, and walked off the edge of the unguarded loft in the middle of the night.
It's a bit hard to believe that the hipster aesthetic shown in most of these faux houses is worth dying for?
PaddedHat is offline   Reply With Quote
Old 05-11-2014, 06:38 PM   #1320
DriveShaft
Oddometer: 4,530
Ya, maybe I'm making a bigger deal out of it than I ought to. It isn't how I'd handle things, if I were designing for myself, in my area. I know when you head upstate, it's a little more commonplace to have stores stock for septics. Personally, if I were to make a semi-permanent rv my ambition, i'd be installing a proper waste dump connection somewhere, have a blackwater tank and make the composting toilet the *alternate* toilet. That way I don't *have to* compost, and I don't *have to* dump, but I have alternatives.
Thread Tools
Times are GMT -7.   It's 02:58 AM.
