Old 07-29-2010, 10:28 AM   #1
Pablo83 OP
Sleep, Wrench, Ride
Pablo83's Avatar
Oddometer: 4,802
Pablo's Transalp
I remember seeing a new Transalp in the Honda Dealership when I was in high school. It looked alien; I didn't know what someone would use that type of bike for. That was in Louisiana where back country exploring is done on an air boat. After moving to the mountain states I began to realize why someone would want this type of bike.
Trevor (MountainsAndRivers) from Telluride saw I had an NX650 and contacted me wanting to know if I wanted a free Transalp. Of course I do, Duh?!
It was in rough shape:
Build Index:
Other builds
Pablo83 screwed with this post 03-09-2011 at 07:46 AM
Pablo83 is online now   Reply With Quote
Old 07-29-2010, 10:29 AM   #2
PacificPT
Oddometer: 982
This sounds interesting!
2000 KLR650
There's roads and there's roads and they call, can't you hear it? Roads of the earth and roads of the spirit. The best roads of all are the ones that aren't certain. One of those is where you'll find me till they drop the big curtain. Bruce Cockburn
PacificPT is offline   Reply With Quote
Old 07-29-2010, 11:21 AM   #3
Pablo83 OP
Sleep, Wrench, Ride
Pablo83's Avatar
Oddometer: 4,802
The story is that the last registered owner was a know abuser of motorcycles. He sold it to someone in non-running condition and then moved to Panama to open a bar. The new owner never got it running or registered and then had to move out of his house into an apartment where he did not have room for it.
Trevor noticed the abandoned bike and knew the owner so he gave him a call and asked about the bike. It was free to whoever wanted it. Trevor contacted me about it and was nice enough to drive it here when he came in to attend the MonkeyButt ride. Trevor's the man.
Old 07-29-2010, 03:36 PM   #4
Pablo83 OP
Sleep, Wrench, Ride
Pablo83's Avatar
Oddometer: 4,802
The bike came with a box of body panels and parts.
Old 07-29-2010, 04:08 PM   #5
Pablo83 OP
Sleep, Wrench, Ride
Pablo83's Avatar
Oddometer: 4,802
I think there are one or two good panels on the bike. The bike would really cost a fortune to restore. I don’t have a title yet and it looks doubtful that I’ll be able to get one from the previous owner. I don’t know the condition of the engine. The starter was removed and the back wheel was locked up.
Right now, the bike's too complete for me to part out, so here's the current idea...I love the look of flat-track bikes.
I've thought about making one with a couple different thumpers I had, but the projects never took off. Of all the flat trackers I've seen I think the V twins look the best and now I have a chain-drive, V twin engine bike that's perfect for a project bike.
Old 07-29-2010, 04:10 PM   #6
Pablo83 OP
Sleep, Wrench, Ride
Pablo83's Avatar
Oddometer: 4,802
Here's my inspiration
Here's what I have:
Old 07-29-2010, 04:21 PM   #7
Pablo83 OP
Sleep, Wrench, Ride
Pablo83's Avatar
Oddometer: 4,802
The bike I'd like to build would be street legal so I'll need a front fender and headlight. This will detract from the overall look of the bike a bit, but if done right, it will still look cool.
One element of the V twin flat tracker I really like is the carb setup. The way the stock heads are setup, putting both carbs on the same side of the bike would require extensive intake plumbing for the rear cylinder. I don't plan to sacrifice performance for looks, so I've been thinking about other options. The best option would be to fit a second front cylinder head to the rear cylinder of the bike (if this is even possible). Then I could easily install carbs in the same configuration as the race bike. I understand this is what is done on flat track Harleys.
So the first two items on my to-do list are to start the paperwork for getting a title, and disassemble the engine to see if the front head will mount to the rear cylinder.
Pablo83 screwed with this post 07-29-2010 at 10:30 PM
Old 07-29-2010, 04:26 PM   #8
B DIRT
B DIRT's Avatar
Location: your moms house startn a small fire in her panties
Oddometer: 1,376
definitely IN on this one
2002 XR650R (plated), 2000 XR650R (trophy), 1990 Transalp, 2002 CR125R (woods weapon), 1977 CT90, 2009 Big Red
B DIRT is offline   Reply With Quote
Old 07-29-2010, 04:29 PM   #9
Pablo83 OP
Sleep, Wrench, Ride
Pablo83's Avatar
Oddometer: 4,802
Originally Posted by pablo83
The best option would be to fit a second front cylinder head to the rear cylinder of the bike ...
Well I've 86ed that idea pretty quick. I just looked at the parts fiche to compare front and rear cams on the bike. It's clear from the fiche that the front cylinder timing chain is to the left of the cylinder, while the rear is to the right, so the front head will not fit on the rear cylinder.
Old 07-29-2010, 04:34 PM   #10
locorider
Loco, pero no estúpido!
locorider's Avatar
Oddometer: 2,484
Pablo: There is enough expertise available at the Show your Transalp Modification thread. If you have technical question it might be answered there. Also most transalpers post there so we might be able to help with parts and experiences!
Good luck with your project!
Carlos
Carlos locorider
From Puerto Rico to Georgia and beyond...
Old 07-29-2010, 04:39 PM   #11
Pablo83 OP
Sleep, Wrench, Ride
Pablo83's Avatar
Oddometer: 4,802
Carlos
Thanks. I found that thread and started to browse through it shorty after I got the bike. I'm sure it will come in handy at some point.
Old 07-29-2010, 07:04 PM   #12
Pablo83 OP
Sleep, Wrench, Ride
Pablo83's Avatar
Oddometer: 4,802
So this is what the bike looks like now.
The stock bike has a double backbone frame which allow room for the air intake system above the engine. The carbs will be moved to the side of the bike (probably one on each side). I plan on replacing the double backbone with a single round tube. This will allow for a much smaller looking tank. Unless I can find a tank for cheap, I'll probably be making my own. The backbone and the tank will probably require the most work in this project.
Pablo83 screwed with this post 07-29-2010 at 10:32 PM
Old 07-29-2010, 08:10 PM   #13
B DIRT
B DIRT's Avatar
Oddometer: 1,376
[QUOTE=pablo83]So this is what the bike looks like now.
Old 07-29-2010, 08:19 PM   #14
Pablo83 OP
Sleep, Wrench, Ride
Pablo83's Avatar
Oddometer: 4,802
Originally Posted by B DIRT
Why the long face? I see progress already.
If you can see through all the dirt, I think this is a great looking engine. If you look at Japanese V-twins from the 80's, most of them are hideous (see Yamaha Virago). It's too bad Honda covered most of this one up with fairings.
Old 07-29-2010, 09:48 PM   #15
Pablo83 OP
Sleep, Wrench, Ride
Pablo83's Avatar
Oddometer: 4,802
This bike is a natural flat tracker. I stripped off everything I don't want and attached a muffler and air cleaner for visual reference. The pipe and filter are for another project so they will not end up on this bike, but I'm guessing the final product will be similar.
Man this bike is dirty. One positive point about not being able to use the front head on both cylinders is I really like the stock pipe routing.
The rear subframe is going to have to be modified as well. It's just way too big.
Unfortunately that's all the updates I'll have for quite a while. I have a policy of not spending any money on a bike that I don't have a title for. I did verify with the local sheriffs office that the bike has not been reported as stolen, so I felt comfortable stripping it down, but the buildup will have to wait for the paperwork to be completed.
Times are GMT -7.   It's 08:37 AM.
