Old 09-12-2010, 11:10 AM   #151
AKjeff
AKjeff's Avatar
Oddometer: 5,254
I love the frame work and mods.
"We can choose to know better or choose to be bitter." OldRoadToad
AKjeff is offline   Reply With Quote
Old 09-12-2010, 01:38 PM   #152
anonny
What could go wrong?
anonny's Avatar
Oddometer: 5,644
This build is tickling my fancy, would love to do an old Goose.
Kawasaki H1 build thread
71- 450 Honda CL re & re
anonny is offline   Reply With Quote
Old 09-12-2010, 02:21 PM   #153
Loadedagain OP
making chips
Loadedagain's Avatar
Oddometer: 26,732
Originally Posted by Jinx
Well, as feared, this project has ground to a bloody halt...get on with it, Laddie
i know i'm a slow bastard, but i'll try my best to get it done a wee bit more efficiently ... the nickel sure would be cool... doesn't lend itself too well to future modifications though. i'm leaning toward a snazzy silver colour done in powder coat (with a quart of enamel to help my habit of welding on fresh paint).
oh... added the support tubes up front this morning.
** iba - 22936 *** Alcan5000 - 2006, 2008, 2012, 2014 ***
Stenhouse Racing - Specializing in KTM Upgrades
custom cnc service available to suit your specific needs.
Loadedagain is offline   Reply With Quote
Old 09-12-2010, 07:23 PM   #154
Nessman
Cluttered Minimalist
Nessman's Avatar
Oddometer: 1,778
Eventually I'll get around to dis-integrating my brakes. When I do I'll make a bracket from this pattern to mount a rear MC under the swingarm.
The "center" punches in the two big holes are 1.9" apart for scale reference. It bends on the crease.
'07 Bandit 1250ABS
'78 XS650 with patina
Huge piles of Guzzi that aren't motorcycle shaped.
Nessman is offline   Reply With Quote
Old 09-12-2010, 09:53 PM   #155
Jinx
Call me Renzo
Jinx's Avatar
Oddometer: 10,838
I hope you are as happy with the way this is going as your audience is
PS - Ain't straight tubes wonderful things?
- Jinx
"You remind me of the monkey with the jerk-off button, starving to death at the switch." - Chopperman
"I didn't know how many assholes it was going to take to piss me off, but I knew how many they were going to use" - collaboratori
Jinx is offline   Reply With Quote
Old 09-12-2010, 10:01 PM   #156
Misery Goat
Positating the negative
Misery Goat's Avatar
Oddometer: 75,186
Damn, nice work, Colin.
"So what you gonna do when the novelty is gone.."-- Joy Division
Same as it ever was
My Wanderlust
Misery Goat is offline   Reply With Quote
Old 09-13-2010, 01:34 AM   #157
Hawk Medicine
Coyote's Brother
Oddometer: 3,304
God....
I hope you saved that fairing. You're gonna want it later!
Hawkdude
Hate rots the pocket that carries it.
Hawk Medicine is offline   Reply With Quote
Old 09-13-2010, 01:54 PM   #158
Loadedagain OP
making chips
Oddometer: 26,732
funny you say that. i really am enjoying this project. this thing is going to be really cool when it's done... i hope. there are some concerns about getting specific parts in time. unfortunately that stuff is out of my hands.
someone on another forum asked me how i go about making some of the parts i put on the bike. it's a little more than a bandsaw and file! i made up the trans/engine mount this morning. here's how i did it
1) after dreaming up what i wanted to do in my head and on a cocktail napkin i drew it up in autocad. i know... there are way cool 3d programs that are so much more efficient... simple 2 dimensional parts get simple 2 dimensional drawings.
2) once it's drawn i overlay a cutting path, which you can see in the blue and red lines. the blue is the main cut pat, the red is a second "release" path as i am going to hold the metal in a vise and don't want to just chop it out of its holder right away.
once that's done i have a little piece of software that writes the code. the code is refereed to as "g-code" and is a simple linear instruction set - g0 means go straight as fast as you can to a coordinate x and y. g1 is linear cutting speed, g2 is a clockwise circle, etc, etc... m codes are motor codes. m3 and m8 turn the spindle and coolant on. for those in the know just ignore 12fpm! i didn't say i was fast!
once we have the code a piece of aluminum goes into the milling machine vise. set zero in x, y, and z and run the program... oh yeah. make sure you have the right cutting tool in the mill. nothing sucks more than programming for a 3.8 mill and running the program with a 1/2". i love machining my vise!
and we're off!
machine the trans end, then some pockets, then the engine end... then slip in a centre drill to mark the holes... then my favorite part. releasing the part from the pieces holding it in! i aint gonna show you that shit show. here it is just before...
then toss the bad boy up in the drill press and poke the holes through where the cnc c-drilled them and we're done! all it needs is finishing. it could be polished, or annodized, or painted... i dig annodizing in matte colours so i'll bead blast it later, then send it out to the annodizer with a bunch of other stuff
then it's time for a trial fit on the bike! here is that chunk of aluminum in its new home for the first time! cool. it actually fits! will weld some bosses on the top cross bar later to hold it vertically.
Old 09-13-2010, 02:08 PM   #159
Nessman
Nessman's Avatar
Oddometer: 1,778
'07 Bandit 1250ABS
Old 09-13-2010, 03:08 PM   #160
crazydrummerdude
Wacky Bongo Boy
crazydrummerdude's Avatar
Oddometer: 7,633
Why would you take a CNC'ed part to a drill press? Program those holes in, too!
Also, if you used a bigger piece of stock (so the vice wont collapse), you might be able to come back by with an endmill and just drop the part out of the bottom. Actually, that's exactly what I did with the last thing I CNC'ed.
/armchair quarterback
crazydrummerdude is offline   Reply With Quote
Old 09-13-2010, 03:12 PM   #161
Loadedagain OP
making chips
Oddometer: 26,732
i know i know... no tool changer so the time it'd take to change to a drill when it was already c-drilled? drill press i go! ... a smart guy could have made the part in less than an hour with a jig saw and drill press.
Old 09-13-2010, 05:47 PM   #162
radguzzi
The Journey is the Reward
radguzzi's Avatar
Oddometer: 5,762
Wow...
And it is difficult to get me speechless.
Most excellent work Loaded...
________________________
Guzzis and Others...
Member: AMA - USCRA - MGNOC
radguzzi is offline   Reply With Quote
Old 09-13-2010, 07:04 PM   #163
fishkens
Further...
Oddometer: 5,149
Neato. Like I said, thanks for the educatin'.
Keep up the great work.
Forging ahead, down a false trail.
fishkens is offline   Reply With Quote
Old 09-13-2010, 09:53 PM   #164
kbasa
Colnago!
kbasa's Avatar
Oddometer: 69,636
{pedantic asshole}
I'd put a radius on those edges.
IMHO.
Fuck Cancer. Ride bikes. - dave + tina
kbasa is offline   Reply With Quote
Old 09-13-2010, 09:59 PM   #165
Loadedagain OP
making chips
Oddometer: 26,732
Originally Posted by kbasa
{pedantic asshole}
settle down buttercup. they'll be softer once the part is bead blasted.
Times are GMT -7.   It's 01:43 AM.
