Old 07-30-2010, 11:53 AM   #1
LaurelPerryOnLand OP
Oddometer: 3,478
VARIO Case(s) Falling Off?
Photobucket
Here's a little something EXTRA that I did to prevent my cases from falling off.
DRILL a small hole through the OUTSIDE latch and the INSIDE base and insert an R CLIP through both.
Latching mechanism can't OPEN even under the toughest conditions.
Hope this helps.
LaurelPerryOnLand is offline   Reply With Quote
Old 07-30-2010, 12:01 PM   #2
sh2515
sh2515's Avatar
Oddometer: 210
good tip, didn't know there was a problem, new to this gs milarky
Why is it that when my wife starts something, I end up doing it for her. Why is it when I through the ball for my dog, I fetch it for him.
sh2515 is offline   Reply With Quote
Old 07-30-2010, 12:03 PM   #3
pavement pounder
Dirt is the spice of life
pavement pounder's Avatar
Oddometer: 744
My son has unlatched this a few times with his boots somehow but it has never seemed like they were going to fall off. In order for that to happen, I would need to snap 2 bungy cords, have the tent and duffle bag fall off, the yellow button would have to be pressed, the handle lifted, red button raised, raise the other red lever (the one that is hard to raise in the first place) then hit a big ass bump for the case to lift off it's mounts (3 mounts) perfectly squarely and simultaneously in order for the case to fall off. Unlikely that the planets would ever align that way but...
It's a cool idea. I think I might do it.
The road to paradise is UN-paved!
go for it! Life's too short to think twice!
Charlie B. (The other Boorman)
Trans-Lab 2010 - James Bay 2011 - Shenandoah to Deal's Gap 2011
pavement pounder is offline   Reply With Quote
Old 07-30-2010, 01:27 PM   #4
Oddometer: 3,478
Human Error before planet alignment
Or...you would simply have to be HUMAN and NOT properly latched the vario to the 'mushroom' bolt...as I (don't tell anybody) did yesterday and LOST my RH Vario! One big bump and Mr. Vario jumped ship (totally without my awareness).
Old 07-30-2010, 02:47 PM   #5
Tin Gizel
LEGALIZE FREEDOM
Tin Gizel's Avatar
Oddometer: 128
when i bought my slightly used GS, it was missing this mushroom bolt....i foolishly thought it was for security reasons.
they don't stay on well without that bolt......
sans moto
Tin Gizel is offline   Reply With Quote
Old 07-31-2010, 11:20 AM   #6
David_Moen
David_Moen's Avatar
Oddometer: 1,276
Another tip, spend a few minutes adjusting the height of the mushroom bolt so that when you snap the latch into the locked position it seats nice and tight. Then use some blue locktite on the mushroom bolts. When I first got mine, the would loosen up over time and the bags would move around a little bit. I could see how that situation would lead to loosing them.
Also, if you have the Vario top case, a medium sized silicone bumper pad (sold for keeping cupboard doors from banging shut) stuck to the mounting plate just aft of where the case engages with the base plate on either side will keep it from rattling.
2013 KTM 350EXC-F, 2005 BMW R200GS, 1984 Kawasaki GPz 750
David_Moen is offline   Reply With Quote
Times are GMT -7.   It's 05:28 PM.
