07-30-2010, 04:36 PM
#1 |
Oddometer: 2,799
How to make your own Carbon Fiber/Kevlar Bash plate....
There are many great bash guards available to buy.......But I like the idea of a light weight....500-750 grams....carbon fiber/kevlar bash plate, that will out perform anything made of aluminum. The project will have two phases. Design and Build. During the design phase, I will be using polystyrene foam plates to construct a base mold. The build phase.....I will layup the fabrics along with the honeycomb material. In case you`ve missed it.....here is a thread on a easier project I just finished.......
http://www.advrider.com/forums/showthread.php?t=603891 A few things to note.... You will be designing your own plate here..... So plan accordingly..... ie....Coffee...espresso...sammiches...beer....wate r.... Whatever you desire.....have patience, and take your time, so not to get frustrated. First I went to the local hobby lobby and got two 1/2 inch and one 1 inch foam panels....... ![]() Then I measured the rough length that I wanted....... ![]() Then it is literally a matter of methodically adding one piece at a time..... ![]() ![]() Constantly putting it on the bike....verifying that all is well....... ![]() Then.....after 5 hrs of cut.....sand.....cut some more...... Glue....( 3m contact glue).....cut some more.......Drink espresso..... Then it finally looks like this........ ![]() ![]() ![]() ![]() ![]() ![]() That took a while...... But I thought I`d ask for your input..... Something missing.....to add.....etc.... Before I start the second phase........ Erling |
07-30-2010, 04:45 PM
#2 |
Harasshole
Oddometer: 216
Nice I was looking forward to this. What about strategically placed holes for oil changes etc? Maybe thats in the next phase... |
07-30-2010, 04:51 PM
#3 |
Hmmm that looks like a foam bash plate.
Good work mate, looking forward to the results.
07-30-2010, 05:43 PM
#4 | |
Oddometer: 2,799
Erling |
07-30-2010, 05:45 PM
#5 | |
Oddometer: 2,799
![]() ...... Yeppers..... The tough part is over...... If approved......The foam will be covered in the next few days.....But I`m sure there will be more trimming needed.....Erling |
07-30-2010, 10:58 PM
#6 |
Harasshole
Oddometer: 216
Hey ebrabaek, can you post a list of supplies like you did in the other thread (or just say same stuff)? I am going to place some orders this weekend. Picking up my Foam too so I can start playing
07-31-2010, 06:44 AM
#7 | |
Oddometer: 2,799
Erling |
07-31-2010, 08:00 AM
#8 |
Oddometer: 2,799
Testing the foam......
So I made a test batch on a foam plate......just to see how the foam holds up to the heat in post cure........ First waxed with the wax in the right top corner.... Then release film in top left.......
![]() Then two layers of CF.....with the High teemp. epoxy....step one.....cure for 2 hrs at 80 deg..... Then heat lamp at say 200...... we shall see..... ![]() Erling |
07-31-2010, 09:51 AM
#9 |
Oddometer: 493
07-31-2010, 11:11 AM
#10 |
***42***
Oddometer: 777
Mike ![]() -------------------------------------------- |
07-31-2010, 02:07 PM
#11 |
Oddometer: 2,799
Heat testing is done.....
I try to stick with 2 main epoxy applications for simplicity. This one.....
http://cgi.ebay.com/EPOXY-RESIN-CRYS...item483544bccc And this one................. http://cgi.ebay.com/EPOXY-RESIN-HIGH...item483836807f First one is one of the clearest transparent epoxy I have ever used. That is what was used in the CF cover in my other thread. It is extremely strong......and I have used it in applications up to 250 deg. F. with great results. It was my first choice, since it is extremely simple.... Mix...pour...your done. But as I started working on the foam mold..... I got concerned about the heat generated in the proximity to the header, and catalytic converter. Perhaps it is dumbfounded..... But I decided to use the high epoxy instead. It can handle temps of up til 400 deg.F. The trouble is that it need post curing heat treatment. I found that I can " cheat" the post cure schedule.... by leaving it in the sun in the hot desert..... for 4 hrs......That will yield around 200 deg.F. I also have found in earlier testing that once cured.....The max hte ( high temp) pox is stiffer and stronger than the max. clr. So results of the heat foam test........ After 1 hr in the sun...... 180 deg.F.............. No stress on the foam.... ![]() Then....under the heat lamp.......and at 290 deg. F. the foam began giving...... ![]() That is good news....... So I plan on 4 hrs in the sun.......then to elevate that up to 250 with the heat lamp for a few hrs. Then it was on to the cast.......Smoothing out the corners......Since Composites don`t like sharp curves. There where a few gaps in between the foam, and the four holes I drilled for the lower mounts...... I filled them with this great stuff. Ever played with play dough..... Modelervoks.... For you fellow scandinavians... ![]() Then you gather the Honeycomb material........ ![]() Cut 3 strings......and put them in the desired position....... ![]() Mark`em....... ![]() Cut a v notch channel, and fill the very botom with the emc......... ![]() Mold is now ready for it`s first and only cast........ After 4 layers of parafilm..... ![]() There are a few things to note here........ It is properly not a necessity to use the honey comb construction. The impact protection necessary does not come from the honeycomb layup. That does just make this piece tremendously stiff, and I though I`d show it....and as of how to. But if it intimidates you.......Just skip that step. I created the cast with 1/2 inch clearance to the cat, and 3/4 to the header. I believe that if you bring that out to 1 1/4 inch.... you will be ok to use the max clr ( low temp epoxy)..... But only way to know.... Is to cast one..... Ahhhhhh.... the labor of love......To spend two days .....although not continuously..... to create something that will be destroyed.......is sort of a funny thing. Even with the release agent...( parafilm).... I`m sure that when yanking the piece of the cast.... the foam will disintegrate....... I always wait overnight with bigger projects...... Just to let it sit......perhaps I forgot something..... Something can be done better.....etc... So until tomorrow....... ![]() ![]() Erling |
07-31-2010, 02:08 PM
#12 |
tool whore
Oddometer: 190
Holy Crap. Amazing. I've built a sea kayak with glass; and this looks very similar. I've always wondered how hard it'd be to work with carbon fiber, where to get the supplies, etc.
Thanks for showing us how to do this! This has me thinking again about those top-loading panniers that hook up to existing vario lugs again.
Omnis vestri substructio es servus ad nobis '09 BMW F800GS '09 Kawasaki KLX250S '05 Yamaha TTR230 |
07-31-2010, 02:32 PM
#13 | |
Oddometer: 2,799
Erling |
07-31-2010, 03:44 PM
#14 |
The Salt
Oddometer: 3,026
~ BMWF800GS ~ "Not all those who wander are lost" |
08-01-2010, 02:18 AM
#15 |
Oddometer: 30
It's posts like this when I'm reminded how lazy I am and accepting of things wrapped in plastic...
"I'm good enough, I'm smart enough, and, doggonit, people like me!" Interesting stuff, standing by
'10 F800GS '10 Royal Enfield Electra (G5) '96 Honda NTV 650 Always choose a hobby you can still do when you're 80!
