Old 08-03-2010, 07:33 AM   #46
HighTechCoonass
Living the Dream....
HighTechCoonass's Avatar
Oddometer: 2,490
Laugh excellent work...a true work of art!
could you make a mold out of the one you made... And make them for us for a good price??? great work!!!
NEW dash plates for your F800..here... lhttp://advrider.com/forums/showthread.php?t=1007140
HighTechCoonass is offline   Reply With Quote
Old 08-03-2010, 07:53 AM   #47
ebrabaek OP
Oddometer: 4,745
Yes....
It would be more expensive than most other bash guards.
great work!!!
Erling
Old 08-03-2010, 08:44 AM   #48
LewisNClark
LewisNClark's Avatar
Oddometer: 1,052
Great Project
Do you have any concerns with lack of ventilation (air holes) in the bash plate? (potentially overheating the engine, exh header pipes)
Is material too hard to cut/drill/etc holes in it now to disburse air through the bottom of the bash plate, or do you think it might be needed?
Also, do you think venting holes might weaken the bash plate?
Is taking the plastic oem bash plate and adding/gluing styofoam to the sides and ends worth even considering for making the mold (at least you'd have the mounting holes in the right place?
Thx
(I see why you suggested a bash place as a last project due to skill level needed !)
The Trip: http://www.advrider.com/forums/showt...ht=Lewis+Clark
Link to 4,000+ pictures of Lewis & Clark Trail:http://lewisandclark.smugmug.com/
LewisNClark screwed with this post 08-03-2010 at 12:23 PM
LewisNClark is offline   Reply With Quote
Old 08-03-2010, 09:22 AM   #49
bradatlarge
Insha'Allah
bradatlarge's Avatar
Oddometer: 12,241
This is fantastic, I'll likely never try to fab something out of CF but, I'm fascinated by the fact that you can do this, with what seems to be, ease.
You have been warned.
bradatlarge is offline   Reply With Quote
Old 08-03-2010, 10:01 AM   #50
TowPro
Lets ride
Oddometer: 3,198
Where do you buy the Kevlar and CF? Is it in a 36" bolt like standard materiel?
I am also in an area where I can't bake stuff in the sun, but we have an old electric kitchen oven we use for Powder coating, I could use that.
2015 KTM 690 Enduro R
2014 R1200GS - My Naked Street Touring Bike
2000 KTM LC4 640 E - currently up for adoption with 3200 miles
TowPro is offline   Reply With Quote
Old 08-03-2010, 04:05 PM   #51
ebrabaek OP
Oddometer: 4,745
Thx
...... It really is not that bad.......I think the biggest enemy here....aside from the post cure....is having patience....lot`s of it. During the time I made the foam mold....I could have made two set`s of airbox covers...... It was not difficult.....But at one panel at a time......takes just that....time. Other than that....no other skill level is needed. If you use the stock plate....you will have some issues with the fabric conforming over the grooves....etc. I think you would be better off by starting from scratch. I will drill some cooling holes, and drain holes. You will loose some integrity.....but not anything to be concerned about. As far as the mount holes.....You just hold up the bash plate where you want it.... then tap underneath with a rubber mallet to make a tiny mark...then drill it. Not hard at all.
Erling
Old 08-03-2010, 04:09 PM   #52
ebrabaek OP
Oddometer: 4,745
Erling
Old 08-03-2010, 04:14 PM   #53
TireIron
Oddometer: 8
Thumb
Totally Awesome
TireIron is offline   Reply With Quote
Old 08-03-2010, 04:17 PM   #54
ebrabaek OP
Oddometer: 4,745
I get it from here......50 or 60 inch with.....your choice.....
http://uscomposites.com/carbonpage.html
It really depends where it available....at a good price. I get the epoxy from here........ They have CF available at a good price as well.....
http://stores.ebay.com/Polymer-Products?_rdc=1
Oven is even better...... Id cook it for 6 hrs at 200 deg. F.no more since the foam will deteriorate above 275..... remember there will be hot spots in any oven.....and last thing you wanna see is your mold start to melt. That way it has enough strength. If you feel lucky.....fire it to 250 for 2 hrs....and your golden......
Erling
Old 08-03-2010, 05:00 PM   #55
Hedge36
Chasing parts.
Hedge36's Avatar
Oddometer: 45,541
So to speak
Hedge36 is offline   Reply With Quote
Old 08-03-2010, 05:49 PM   #56
TowPro
Lets ride
Oddometer: 3,198
this sounds like a project I might try this winter. I enjoy this kind of stuff, and it's really no different then working with fiberglass and cloth doing car or boat repairs. In fact it's easier because your working over a ridged mold instead over a hole in a fender.
It looks like a around $100.00 to get started for my first cloth and epoxy purchase, unless I layered Kevlar then I have another materiel purchase.
Why did you use layers of the two materials?
Old 08-03-2010, 08:44 PM   #57
ebrabaek OP
Oddometer: 4,745
That is a question I get a lot...........The two materials offer their own distinct property`s. The Kevlar has great abrasive and impact resistance. The latter one being offered but with displacement in the direction of the impact. Carbon Fiber offer very little abrasive resistance........But has enormous torsional stiffness. That will help to minimize the displacement of the Kevlar. So In short.....the combination in sandwiching the two materials makes for a greater combination than either material could offer alone.
Erling
Old 08-03-2010, 09:43 PM   #58
TastyPants
Harasshole
TastyPants's Avatar
Oddometer: 226
So how much do you think you actually spent on materials?
TastyPants is offline   Reply With Quote
Old 08-04-2010, 05:30 AM   #59
ebrabaek OP
Oddometer: 4,745
I would imagine that the fabric`s ran around $ 100..... Resin......$ 25......
Brush....roller.....gloves.....$ 5.....say about $ 130.... Remember...there are 7 layers in that piece.....
Erling
Old 08-04-2010, 05:53 AM   #60
space
a.k.a. Jake
space's Avatar
Oddometer: 2,622
Great stuff, Erling!
So how strong do you think the final product will be? If you high center the bike, will the bash plate be able to hold its weight without the epoxy cracking? Should it be able to take rock hits OK?
space is offline   Reply With Quote
Times are GMT -7.   It's 06:25 AM.
