Old 08-03-2010, 03:03 PM   #1
Hookalatch OP
Born Under Bad Sign
Hookalatch's Avatar
Oddometer: 395
Lennie's Camshaft Sprockets
I have searched and read all the past posts about advancing camshaft timing by using sprockets from Lennies or other sources. Everything seems pretty positive. Anyone using these have any new feedback? Reasons to avoid making this change? I can really use more low end grunt off-road. I have a booster plug on order and the sprockets sound like a good addition too.
Chuck
Hookalatch is online now   Reply With Quote
Old 08-03-2010, 03:33 PM   #2
Sergiok
Underwater Basketweaver
Sergiok's Avatar
Oddometer: 181
Chuck
New feedback... no... still love them though! Once you put them in you'll never look back.
'05 R1200GS
'08 HP2Sport
Sergiok is offline   Reply With Quote
Old 08-03-2010, 06:39 PM   #3
CarSalesman
Oddometer: 383
I got them on my 2007 GS a month ago. The difference can be felt, but I wouldn't spend $500 (with labor) to do it again. If you can handle the labor yourself, might be worth it. The engine is useable about 500 rpm lower than before. I find myself running one gear higher without thinking about it. You can feel a difference pulling away from a stop. I hardly ever run the GS engine to redline, so can't confirm if the top end is reduced.
CarSalesman is offline   Reply With Quote
Old 08-03-2010, 06:49 PM   #4
signit98
Nutcase... really!
signit98's Avatar
Oddometer: 805
Put in 4 sets in several bikes now (mine and other's)... all of them bettered each respective bikes performance where it counts.
You basically shift the Torque range about 1K RPM lower across the board... the bike is more responsive and with my mods of adding the techlusion/wunderlich/dobeck/whatevertheyarecalled and eliminating the cat, it offers about 96Hp on the rear wheel. Not bad for an '05.
Ralf Wilkowski
Been there - already forgot about it...!
Follow my Journey, pursue insanity:
www.itwasnotme.com
signit98 is offline   Reply With Quote
Old 08-03-2010, 09:07 PM   #5
Beezer
Oddometer: 5,786
I really don't think it makes much difference at the very bottom end, but no doubt the mid range is better. I also think it runs smoother.
All in all, Lennie's gears = good... dropping Lennie's gear inside the engine... not so much. If you lose you grip while installing, the gear rolls right into the crankcase. Then you pull the head and go fishing. Pretty easy install though.
Beezer is offline   Reply With Quote
Old 08-03-2010, 09:55 PM   #6
signit98
Nutcase... really!
signit98's Avatar
Oddometer: 805
That is why you secure them with fishing line until they are seated and the screw is back in...
Ralf Wilkowski
www.itwasnotme.com
Old 08-03-2010, 11:27 PM   #7
Dan Căta
Dan Căta's Avatar
Oddometer: 1,656
Can someone please provide a source for buying those?
Dan Căta is offline   Reply With Quote
Old 08-04-2010, 12:40 AM   #8
Rick Lee
Rick Lee's Avatar
Oddometer: 1,252
www.powerfrkusa.net
He also has a lot of threads on the Pelican R1100S and R1200S board. I have the Power FRK in my S, but want to sell it, so I'll hold off until my next GS for Lennie's sprockets.
'06 K1200R
'96 993 C2
Rick Lee is offline   Reply With Quote
Old 08-04-2010, 01:00 AM   #9
Dan Căta
Dan Căta's Avatar
Oddometer: 1,656
"These high-end CNC machined sprockets will advance the cam timing 9 degrees."
Can that be also obtained by fiddling with the HES plate too? :)
Old 08-04-2010, 01:09 AM   #10
Steptoe
steptoe
Steptoe's Avatar
Oddometer: 2,609
One is cam timing, the other is ignition timing.
www.gsshop.biz
Steptoe is offline   Reply With Quote
Old 08-04-2010, 01:11 AM   #11
Dan Căta
Dan Căta's Avatar
Oddometer: 1,656
Steptoe, since you are a guru for BMW motorcycles, would you put these on your bike if you would find 500$ laying around the street one day? :)
Old 08-04-2010, 03:40 AM   #12
Steptoe
steptoe
Steptoe's Avatar
Oddometer: 2,609
guru
For what it's worth I'd need to ride a bike with them fitted before i could form an opinion. Otherwise it'll just be guessing.
www.gsshop.biz
Old 08-04-2010, 03:48 AM   #13
Dan Căta
Dan Căta's Avatar
Oddometer: 1,656
Enough with the modesty!
Old 08-04-2010, 04:05 AM   #14
Bokrijder
Soyez sans que peur
Oddometer: 319
Any comments on MPG taking a hit? I've got the 850R FD on my GS, cam gears should make it a pulling bear for slow rough work. FD change made no real loss in MPG, as a side note.
MJStone
Bokrijder is offline   Reply With Quote
Old 08-04-2010, 07:01 AM   #15
signit98
Nutcase... really!
signit98's Avatar
Oddometer: 805
Gas mileage will stay the same or better... as for the source, I can provide a direct contact, if needed. The contact listed above is Foster R & D... good luck with that.
Ralf Wilkowski
www.itwasnotme.com
Times are GMT -7.   It's 03:49 PM.
