Old 08-10-2010, 12:06 PM   #31
signit98
Nutcase... really!
signit98's Avatar
Oddometer: 809
Originally Posted by motorcyclemark
I really want these sprockets but am still on warranty. Whats your guys opinion ?
Don't ask, don't tell...
Ralf Wilkowski
Been there - already forgot about it...!
Follow my Journey, pursue insanity:
www.itwasnotme.com
signit98 is offline   Reply With Quote
Old 08-10-2010, 12:26 PM   #32
GotRoad?
Refugee
GotRoad?'s Avatar
Oddometer: 3
Might as well...
Might as well add my positive opinion about Lennie's sprockets; they were one of the better mods I've done to my 1100S. I found that the hardest part of the install was getting the old sprockets off...and yes, as suggested, above do use some monofilament line to keep the new sprockets from falling into never, neverland.
GotRoad? is offline   Reply With Quote
Old 08-10-2010, 12:54 PM   #33
motorcyclemark
motorcyclemark's Avatar
Oddometer: 167
I'm in for a group buy but do not want to wait for fall or winter. Looks like at most a half day of wrenching then ride. How many needed to get this thing rolling?
motorcyclemark is offline   Reply With Quote
Old 08-10-2010, 02:06 PM   #34
signit98
Nutcase... really!
signit98's Avatar
Oddometer: 809
I'd say 5 to 10 sets... to make it worthwhile.
It takes me about an hour or so, now that I have done a few sets. With all the plastics work and such, maybe 2.
Have a bit of tips and tricks on my website... under the 12GS
Ralf Wilkowski
www.itwasnotme.com
Old 08-10-2010, 11:39 PM   #35
Beezer
Oddometer: 5,926
mizwell do a group buy on left side chain tensioners too then
Beezer is offline   Reply With Quote
Old 08-11-2010, 11:04 AM   #36
Rapid Dog
bikes, booze, broads...
Rapid Dog's Avatar
Oddometer: 9,654
Thumb theywork
...Lennie's not even a friend of mine...
Oh gee, I thought we was all frens here...er, there.
Contact Lennie directly if you want here: Boxer Performance
BTW Nice pic and writeup Jason!
Regarding the question
Anonymous said...
Nice write up and thanks for sharing. A couple of questions...
Did you do the sprocket and booster plug at the same time?
If so, how do you know which one provided the most "noticeable if not dramatic" improvement?
I believe the plug will smooth out the bike by itself, the sprockets are going to give you the oompah-pah. I never new a heavy GS could pull the front wheel off the ground from a rolling start til I popped them babies in, no shit.
Note: be very methodical when doing the install...
'91 R100GSPD Derelict Deux , '81 R100RS Rattlecandy Red/'06 950 ADV Orangeboom/91 R100GSPD Derelict etc.
Rapid Dog is offline   Reply With Quote
Old 08-12-2010, 12:05 AM   #37
lennie
Oddometer: 181
Hello adventurers.
I have finally been accepted into the fold.
Interesting post you have here.
If anyone has any questions feel free to ask.
lennie is offline   Reply With Quote
Old 08-12-2010, 07:08 AM   #38
Rapid Dog
Rapid Dog's Avatar
Oddometer: 9,654
Thumb Da Man
...and welcome Lennie!
Hey, maybe we should coerce you into making an R12GS snorkle...
Old 08-12-2010, 09:44 AM   #39
motorcyclemark
Oddometer: 167
Lennie I have a question about how many rpm's your cam sprockets lower the powerband: http://www.powerfrkusa.net/cgi-bin/s...=1022BR12003BP States 823rpm http://www.powerfrkusa.net/news/lenn...ket-sprockets/ States 1187rpm
Which one is correct and why do the two contradict each other?
Old 08-12-2010, 09:57 AM   #40
J_White
should be working
Oddometer: 328
I'm curious about a group buy...
Wondering, for someone fairly mechanically inclined and familiar with
wrenching/timing other engines, how easy is it to get a tooth or three out of time when doing this? Obvious marks and procedure to follow?
Everything I've worked on with this bike so far has seemed simple enough
after doing it once, but a little nervous about getting it out of time.
I'm guessing these engines are running fairly close valve-to-piston
clearances, "interference" if something went wrong?
J_White is offline   Reply With Quote
Old 08-12-2010, 10:40 AM   #41
Hookalatch OP
Born Under Bad Sign
Hookalatch's Avatar
Oddometer: 404
Cam timing worries
Look at the excellent photos and descriptions from Jason (Jason Abbott) and Ralf (Signit98) to see you how to do the job. Links to those sites are in this thread. If you look at those and are still nervous you might want to get some help. If you have some mechanical ability and look at those sites you will probably feel like you can do it. I have not done it yet either. It sounds like the cam chain tensioners are the bigger challenge as long as you mark everything first and secure anything that can be dropped.
Chuck
Hookalatch is offline   Reply With Quote
Old 08-12-2010, 03:08 PM   #42
lennie
Oddometer: 181
motorcyclemark,
What you read on the powerfrkusa site are the findings and words of someone within that organisation based on any dyno testing they have done.
There is a difference in the cam timing between the GS/R and the RS/RT/S engines and the GS/R engines have a lower torque peak so that the amount of rpm change is less and the S/RS/RT engines have a higher torque peak and the cam timing change lowers the torque peak more rpms.
I hope this helps you understand the difference.
I developed these sprockets in 2000 and have sold over 200 sets to date.
Lennie
Old 08-12-2010, 06:14 PM   #43
Sergiok
Underwater Basketweaver
Sergiok's Avatar
Oddometer: 181
Well, I meant it in that my opinion of the sprockets are 100% impartial, but yeah, we're all friends there. ;)
Lennie, I have a feeling you may be selling more than just a couple hundred sets of these. I couldn't imagine riding a boxer without them.
'05 R1200GS
'08 HP2Sport
Sergiok is offline   Reply With Quote
Old 08-14-2010, 09:57 PM   #44
HunSolo
Mad Monk
Oddometer: 396
How low can they go?
I have always yearned for a real first gear on my '07 GS. Will the Lennie sprockets help here? Anybody got a better low gear alternative that is not a GSA...I've already got one ('06) of those.
HunSolo is offline   Reply With Quote
Old 08-15-2010, 06:39 PM   #45
pavement pounder
Dirt is the spice of life
pavement pounder's Avatar
Oddometer: 744
under identical conditions, will these sprockets change fuel economy, if so, what changes should we see?
The road to paradise is UN-paved!
go for it! Life's too short to think twice!
Charlie B. (The other Boorman)
Trans-Lab 2010 - James Bay 2011 - Shenandoah to Deal's Gap 2011
pavement pounder is offline   Reply With Quote
Times are GMT -7.   It's 04:30 PM.
