Old 08-25-2010, 09:00 AM   #91
motorcyclemark
motorcyclemark's Avatar
Oddometer: 165
Originally Posted by signit98
I hope you did not order these for an R12 motor... they won't work. BOTH sprockets need to have the extra hole for the R12 engine.
If anyone needs help and is in my vicinity, just hit me up... or I try to do my best via email...
These appear to be the same sprockets I received as well, and yes they were ordered for a R1200. So why will they not work for R1200 and what is the purpose of the extra hole?
motorcyclemark is offline   Reply With Quote
Old 08-25-2010, 09:37 AM   #92
Kilo Sierra
Kilo Sierra's Avatar
Oddometer: 189
Lennie,
Sent you an email.
ks
Kilo Sierra is offline   Reply With Quote
Old 08-25-2010, 10:20 AM   #93
TrainedChimp
Consistently wrong
TrainedChimp's Avatar
Oddometer: 185
I ordered these for an 1150.
"Fools congregate."
TrainedChimp is offline   Reply With Quote
Old 08-25-2010, 10:47 AM   #94
motorcyclemark
Oddometer: 165
After talking to Foster performance, I was assured that these were the correct sprockets for the R1200. The extra hole is for the cam sensor which is only on the right side cylinder. So much for the response if you ordered these for the R1200 they will not work.
Old 08-25-2010, 11:51 AM   #95
Rapid Dog
bikes, booze, broads...
Rapid Dog's Avatar
Oddometer: 9,572
Originally Posted by Sergiok
There's tons of info on that other board...
Thanks, I knew there was more out there somewhere...
Originally Posted by motorcyclemark
So much for the response...
These internets are fun...
'91 R100GSPD Derelict Deux , '81 R100RS Rattlecandy Red/'06 950 ADV Orangeboom/91 R100GSPD Derelict etc.
Rapid Dog is offline   Reply With Quote
Old 08-25-2010, 12:25 PM   #96
signit98
Nutcase... really!
signit98's Avatar
Oddometer: 817
Perfect, the R12 engines need the extra holes in BOTH sprockets... one is for the paddle wheel that helps with the breathing and the other side for the knock-sensor...
Ralf Wilkowski
Been there - already forgot about it...!
Follow my Journey, pursue insanity:
www.itwasnotme.com
signit98 is offline   Reply With Quote
Old 08-25-2010, 12:29 PM   #97
signit98
Nutcase... really!
signit98's Avatar
Oddometer: 817
Well, good luck then... funny though when I helped a guy over here install them in his 12ST, in talking to him and explaining the situation with the breather wheel on the left cyclinder, Foster was very apologetic and sent e new set out the next day... WITH HOLES IN BOTH SPROCKETS>>.
Now, you are right, I could be wrong... after all, I have only installed 5 sets so far... that does not make me an expert by any means...
As a solution, you could always leave the paddle wheel out... I am sure BMW only installed that because they had a whole bunch of them laying around and needed to find a way to get rid of them. If your engine does not have the paddle wheel on the left side, you are fine and one sprocket with the hole drilled is ok... but, MANY R12 engines after '05 have the paddle wheel. Older engines have the wheel just sitting on top of the sprocket, the newer ones have a little pin on the wheel, that goes INTO the hole we are talking about.
Ralf Wilkowski
www.itwasnotme.com
signit98 screwed with this post 08-25-2010 at 12:37 PM
Old 08-25-2010, 01:43 PM   #98
mag00
Outa Control Dave
Oddometer: 423
Originally Posted by lennie
motorcyckemark,
Interesting you ordered a set from Foster R&D yet they tell me they are not making sales.
I wonder what is going on?
I ordered at set last week before I heard back from you.
2012 Ducati Multistrada
08 SE Ultra,
2012 Triumph explorer 1200
09 R1200GSA
IBA #25226
mag00 is offline   Reply With Quote
Old 08-25-2010, 02:15 PM   #99
Hookalatch OP
Born Under Bad Sign
Hookalatch's Avatar
Oddometer: 403
1 hole works fine for me
My 2007 GSA paddle wheel does not have any provision for attaching to the sprocket except for the bolt going thru the metal sleeve in wheel. As it happened, I got holes in both sprockets but the one on the left side does nothing. There is no need for the extra hole in the left side sprocket if your paddle wheel is like mine.
Chuck
Hookalatch is offline   Reply With Quote
Old 08-25-2010, 02:27 PM   #100
signit98
Nutcase... really!
signit98's Avatar
Oddometer: 817
Chuck
As I said... 2 of the three R12's I have done, needed the second hole... I hope it'll work for him. But there are always solutions...
Ralf Wilkowski
www.itwasnotme.com
Old 08-25-2010, 02:37 PM   #101
lennie
Oddometer: 181
More interesting information.
Trainedchimp,
Your sprockets are from the originals that I made for pre R1200 engines.
As a test for the R1200S and R1200GS, I drilled the one hole per set so that we could see what difference they made.
A couple of Pelican members volunteered and the feedback was good on the results but the hole was only needed for the knock sensor. Seems BMW have changed the paddle wheel.
Adventurrer,
Yes the drilling of the locating pin hole to 3 mm with a carbide bit will make the hole the correct size for a better fit taking all pressure off the spocket.
All sprockets are now drilled for the current batches I have so no further issue.
Mag00,
No worries.
Kilo,
I will get back to you.
I use a new email address but am loathe to publish as I am wary of spam email as I get hundreds per day at the Boxer Performance one.
To contact me direct use lenmor@activ.com.au and use cam sprockets in the subject, or even just BMW.
Regards,
Lennie
lennie screwed with this post 08-25-2010 at 02:44 PM
lennie is offline   Reply With Quote
Old 08-25-2010, 02:46 PM   #102
motorcyclemark
Oddometer: 165
I have not opened mine up as of yet however the part# for the ventilation flapper wheel http://www.ascycles.com/Illustrated_catalog/main.html#
shows it to be the same from 04 and up.
Old 08-25-2010, 02:48 PM   #103
Sergiok
Underwater Basketweaver
Sergiok's Avatar
Oddometer: 181
Slacker!
'05 R1200GS
'08 HP2Sport
Sergiok is offline   Reply With Quote
Old 08-25-2010, 02:59 PM   #104
mag00
Outa Control Dave
Oddometer: 423
Lennie
The set I got for my 09 r1200gsa only has 1 sprocket with 5 holes the other has 4 will these work or did I get duped by RFK?
08 SE Ultra,
09 R1200GSA
IBA #25226
Old 08-25-2010, 03:30 PM   #105
Hookalatch OP
Born Under Bad Sign
Hookalatch's Avatar
Oddometer: 403
Sprocket holes
Look at your stock left side sprocket. If it only has 4 evenly spaced holes you only need a 4 holer. My 2007 left side sprocket only has the 4 holes.
Chuck
Times are GMT -7.   It's 03:12 AM.
