Old 08-04-2010, 03:43 PM   #1
stou OP
stou's Avatar
Oddometer: 350
Possible to change wheel size on a 990R?
I just look in my owner's manual and it's indicate how to see the wheel size on the speedometer, but I didn't found something about changing the wheels size. I have a set of 19/17 and the stock wheels 21/18 and really wish I can change it. I saw that it is possible on a 950 and on the regular 990.
I saw some instruction on threads saying:
Turn key on
Press Mode until the F display comes on Press and hold both the Mode and
Set buttons for ~ 10 seconds.
The current wheel size will appear on the display Press Mode and it will
toggle between 21, 19 Select 19 Press the set button.
But on the R, the Mode button switch between ODO, Trip1, Trip2, Temp... can't display the F Mode....
Any idea?
2010 KTM Adventure 990R - 2012 Ossa TR280i
'87 Honda TLR 200 - '72 Honda CB350K4 - '72 Honda CD175
http://www.stoudesign.com
Montreal to Moab 2008: http://www.advrider.com/forums/showthread.php?t=343166
stou screwed with this post 08-13-2010 at 05:49 PM
stou is offline   Reply With Quote
Old 08-13-2010, 05:52 PM   #2
stou OP
stou's Avatar
Oddometer: 350
There's nobody who has managed to change the wheel size on the 990R speedometer ?
Old 08-13-2010, 07:12 PM   #3
Chuckracer
Jerkus Maximus
Chuckracer's Avatar
Oddometer: 8,467
You are probably the only one here WITH an R WITH 19/17 wheels.
2012 KTM 990 Adventure
Chuckracer is offline   Reply With Quote
Old 08-13-2010, 07:58 PM   #4
Visigothic
Visigothic's Avatar
Oddometer: 186
new wheels
I thought about this also. Having a set of motard wheels would make this the ultimate dual sport. Im not sure if its possible or practical. Thoughts?
Visigothic is offline   Reply With Quote
Old 08-14-2010, 06:51 PM   #5
stou OP
stou's Avatar
Oddometer: 350
I installed a set of Dunlop D607 on the 17/19 set and will install a D606/D908 combo on the 18/21 set.
The 17/19 set are amazing on the street and the twisties. It's almost like a sport bike. And the 18/21 set will be perfect for the off road.
I ride almost 2 hours a day in the city to get and get back from work. It's a lot more interesting to do it with the D607 than a D908. Also the off road tire wear too fast in the city. So I put them only when I know I will ride off road.
But with the 17/19m there around 10 kmh more from around 90 and 120 kmh and something like 5 or 6 kmh more around 50 and 70. The speedometer is alway indicate more kmh than I really go and in the end, this put more km on the odometer than what I really do.
I really need to find how to change the wheel size on this model!
Old 02-20-2011, 08:23 AM   #6
stou OP
stou's Avatar
Oddometer: 350
On the Caponord thread, we start to discuss about the wheel size setting for the 990R.
http://www.advrider.com/forums/showt...1#post15234851
Since I don't want to polute the Caponord thread, I put a link on this thread to continue the discussion about how to adjust the wheel size on the 990R.
I remove the dash of my 990R to look at the connector and the different wire color.
In the Caponord thread, Factory post this info:
Originally Posted by factory View Post
990R dash is the same as the 690, you need to cut a wire to the back of the dash that locks the wheel size. You can then adjust wheel size using the mode and set buttons. I did it on my 690 and worked well.
These are the notes I kept, this is the procedure once you have cut the wire:
*Turn key to "on" and with the meter set to "Trip 1", press and hold "Mode" for 10 sec.
Length xxxx (the 17" circumference) will show up (flashing), press "mode" to increase and "set" to decrease the circumference.
The correct setting for 21" should be 2205.
*Press "mode" and "set" simultanously to set it.
You will need to search the big 690 thread the find which wire to cut, I recall there are pics.
Then Guv posted this info:
Originally Posted by -GUV- View Post
Originally Posted by Sobiloff
I read this procedure elsewhere and haven't tried it myself, but I figured I'd pass it on in case you're adventurous enough to try it:
*Remove old Odometer and the connector.
*Cut the wire for pin 18 (should be Brown/Grey for 690E) on the connector.
*Install Odometer
The only thing that the "pin 18" do is lock the Odo from adjusting wheelsize.
This looks like it?
Then I found that in the 690 threadfest:
http://www.advrider.com/forums/showthread.php?p=9716738
Originally Posted by The Deanster View Post
How to change the wheel size in the speedometer on the 2009 KTM 690 Enduro R. (ok enough keywords)
After finding information on how to disconnect a wire to enable the wheel size setting mode for the 690 E in this thread:
http://www.advrider.com/forums/showthread.php?t=387959
I was determined to figure out how to do it on my R. I need to correct for using the SMC wheels.
I DID IT!! Here's how:
It was by disconnecting the pink wire. I unplugged the 8 pin connector and it worked. I tried each wire one at a time until on the last wire it worked.
I am pulling the pink wire from the connector in the speedometer and covering the pin with shrink tubing. (gently lift tab on side of conn that holds the pin)
---Procedure---
1. Disconnect the pink wire inside or outside of speedo (or just temporarily unplug the 8 pin connector).
2. Press MODE button to enter TRIP 1 or TRIP 2.
3. Press and hold MODE button until LENGTH appears.
4. Adjust to circumference (in mm) of front tire using the 2 buttons.
5. Press and hold both buttons to enter value.
Done!
This is great! I can change it whenever I want.
Hope this helps anyone swapping wheels like me.
I tried uploading pics but keep getting an error, sorry.
All this info make sense but I stil have a problem. I remove the dash of my 990R to see the connector. It's a 32 pins conector and there's no pink or brown/grey wire.
How I can locate the pin 18 from the connector? I don't have the electric diagram and I don't want to mess something in my cluster.
Any idea?
Old 02-20-2011, 08:27 AM   #7
stou OP
stou's Avatar
Oddometer: 350
Here's picture of the 990R dash and pictures of the two sides of the 32 pin connector.
Old 02-26-2011, 01:18 PM   #8
stou OP
stou's Avatar
Oddometer: 350
I finally found the wire to disconnect!!! On the 990R, it's the brown/black wire.
I tried to disconnect what the could be 18 pin wire with no luck. Since there's no pink and no brown/grey wire, I tried the purple, it doesn't work. Finally, it was the brown/black one.
So to adjust the wheel size on a 2010 990R Adventure,
1- press MODE to go to TRIP 1
2- Hold the MODE key for around 10 sec
3- It will show actual wheel size. Use the MODE key to increase the wheel size and the SET key to decrease it
4- Hold the MODE and SET key to exit
The default size on the 990R is 22.05 for the 21" wheel. I did some research on ADV and it look like the size for a 19" is 20.00. I can't ride because of the snow here so I can't confirm that this is the good size.
Can someone can confirm that 20.00 is the right size for 19" wheel?
Old 03-02-2011, 04:02 PM   #9
shawty950
shawty950's Avatar
Oddometer: 243
Older dashes
Just went thru my 07 dash...(i have 17"s as well as the 21/18) and change quite often.
The old speedos have the Inch and the other circumference in mm's
21" - 2205 mm
19" - 2040 mm
17" - 1882 mm
I just confirmed with a tape that the rolling circumference of my 21" front is within half a cm of being 2.205 m
Shawty
shawty950 is offline   Reply With Quote
Old 03-06-2011, 03:18 PM   #10
carmima
All Orange :-)
carmima's Avatar
Oddometer: 2,954
Thumb Awesome info
Thanks so much for this info
I just had a set of SM wheels made for my 2010 990A I went for 17" x 17" instead of the 19" x 17".
I also have the issue of the ABS light coming on after riding approx 1klm as the wheel speed on the front is now not in sync being 4" smaller than standard
It'd be nice if by changing the wheel size in the ODO, it might tell the ECU that the difference in wheel speed is ok - does that make sense??
Anyway, even if it doesn't sort the ABS issue, it'll be nice to have the speed display correctly
Thanks again for doing the research
carmima is offline   Reply With Quote
Old 03-07-2011, 09:41 PM   #11
carmima
All Orange :-)
carmima's Avatar
Oddometer: 2,954
For those who want to do this change with a 2010 990 Adventure standard ABS model...I can confirm that the instructions for the 'R' model as listed earlier are the same for the standard ABS model.
I just removed that Brown/Black wire and now I can change the 'size value' of the front wheel
Old 03-08-2011, 06:37 AM   #12
stou OP
stou's Avatar
Oddometer: 350
21" - 2205 mm
19" - 2040 mm
17" - 1882 mm
Shawty
Thanks for that info Shawty!
Old 09-17-2011, 12:38 PM   #13
rmct
Oddometer: 12
Brown/black wire works for a 2011 990 Adventure w/ABS - but it has to be the brown/black wire at the instrument panel (there is another brown/black wire with much easier access - makes it handy when you need to repair it - just saying)
rmct is offline   Reply With Quote
Old 03-10-2012, 04:14 PM   #14
CenzoDuc848
Oddometer: 1
Calibrate speedo
Dear all,
I recently super moto'd my 690 Enduro R (2011 model) and soon found out that the speedo needed calibrating so I tralled the internet and found so many forums saying to cut either a grey/brown wire or a pink wire.
Well I took my bike to my dealer as they offered to do it for free after speaking to KTM Austria who advised them the same thing that has been seen on these forums, well I am sorry toi say that it failed to recalibrate, but I have done it today myself and I am here to tell you there is no need to cut any wires and it only took me 5 minutes to sort it..
Take the light mask off.
Coming out of the instrument panel are a load of wires going to various blocks.
The block you want has 8 wires going into it and one of these is pink. (colour may change but deffo an 8 pin block on a 2011 690 Enduro R
Disconnect the block.
Turn the ignition on
ensure display shows trip 1
Hold mode down for 10 seconds
the word length will show on the clock and a 4 digit number something like 2205 this is the circumference of the 21" wheel with tyre.
using the trip reset switch will decrease this number 1 digit at a time
You need it to read 1870
then press mode and reset buttons together
turn ignition off, plug your connector back in, refit light mask and job done with no cutting.
It's better to burn out than to fade away!
CenzoDuc848 is offline   Reply With Quote
Old 06-27-2012, 11:21 AM   #15
wpbarlow
Oddometer: 11,258
Bumping this so it's easy to find on my phone
wpbarlow is offline   Reply With Quote
Times are GMT -7.   It's 11:51 PM.
