Old 08-30-2011, 05:13 PM   #1516
Hog Rider
The Professor
Hog Rider's Avatar
Oddometer: 1,427
Originally Posted by rdguy View Post
Just out of curiousity, where are they cracking?
Glenn
Let me show you .....
I have it on very good information that the replacement brackets are holding up much better !
Hog Rider
IBA # 31325
AMA# 739943
Cobb
Etc..
http://carlstwowheeledadventures.blogspot.com
2006 Buell Ulysses, Current Rally Mount
1984 HD Electra Glide Classic
1977 BMW R 100/7 Cafe'
1982 Honda CBX Super Sport, Work in progress
Hog Rider is offline   Reply With Quote
Old 08-30-2011, 05:14 PM   #1517
SteelB12
SteelB12's Avatar
Oddometer: 2,705
OAKLANDSTROM: The detail that I need is showing which wire from the lights willl go into the relay, which wire runs from relay to the switch and which terminal on the relay gets power and which is ground. I have never installed anything with a relay that didn't have a diagram to follow.
I want to wire them to get power all the time (like the low beam), but with a switch
2003 Suzuki Bandit 1200S
2009 KLR650
SteelB12 is online now   Reply With Quote
Old 08-30-2011, 05:42 PM   #1518
subybaja
subybaja's Avatar
Oddometer: 2,889
one wire to 12v+
one wire to 12v -
If it doesn't light up, swap the wires.
This. Light Emitting Diode = one-way gate. Hook them up backwards, nothing will pass.
Google 'relay diagram'.
We had part of a Slinky. But I straightened it.
subybaja screwed with this post 08-30-2011 at 05:47 PM
subybaja is offline   Reply With Quote
Old 08-30-2011, 07:26 PM   #1519
eSONG
eSONG's Avatar
Oddometer: 435
Did the lights vibrate at all where they were mounted?
eSONG is offline   Reply With Quote
Old 08-30-2011, 07:39 PM   #1520
Hog Rider
The Professor
Hog Rider's Avatar
Oddometer: 1,427
No ...
I had 2 other lights mounted up on my windshield mounts also, They never had a mount failure issue or any vibration issues.
I had 2 sets of lower mounts fail.
Hog Rider
IBA # 31325
AMA# 739943
Cobb
Etc..
Old 08-30-2011, 08:05 PM   #1521
eSONG
eSONG's Avatar
Oddometer: 435
No ...
what do you think it is about the lower mount position that's causing it to fail?
Old 08-30-2011, 10:00 PM   #1522
OaklandStrom
Oddometer: 1,612
It's a Buell. Have you ever seen one idle?
OaklandStrom is offline   Reply With Quote
Old 08-30-2011, 10:04 PM   #1523
OaklandStrom
Oddometer: 1,612
Originally Posted by subybaja View Post
Nice diagram.
You have 2 options:
1) Hook them directly to the battery and put a switch in the middle. No relay required - however, you can leave them on and kill your battery.
2) Wire them like the above diagram. Make sure that the wire that says "IGN or battery power" is connected to something that only comes on when the bike is on (like the headlight or tail light wire).
The relay just acts like a remote switch. It won't send power to the lights unless it is getting power from the headlight wire (or whatever you use). You can't kill your battery, as the lights will turn off when you shut the bike off.
Old 08-31-2011, 12:04 AM   #1524
SteelB12
SteelB12's Avatar
Oddometer: 2,705
Sweet diagram. Just what I need. Thanks!
2009 KLR650
Old 08-31-2011, 02:44 AM   #1525
FL Pepper
OMGWTFFTW
FL Pepper's Avatar
Oddometer: 1,507
Observe Polarity When Wiring LED Lights
The white wire should be attached to positive 12 volts. The black wire is ground. Try not to wire them up backwards.
2008 Yamaha WR250R
2001 Westfield Celebration
New ADVmonster Website
Central Sandbox Tag-O-Rama Maps
FL Pepper is offline   Reply With Quote
Old 08-31-2011, 03:40 AM   #1526
Hog Rider
The Professor
Hog Rider's Avatar
Oddometer: 1,427
Could be, The upper lamps have some dampening from the cowl.
To correct a prior statement, The lamps did not vibrate, The whole bike vibrates
Hog Rider
IBA # 31325
AMA# 739943
Cobb
Etc..
Old 08-31-2011, 06:01 AM   #1527
Sunday Rider
Adventurer Wanabe
Sunday Rider's Avatar
Oddometer: 768
Did you bend them (s/s mounts) at all to get the angle you needed?
Or do you think it was the vibrations that did it?
'97 Honda ST1100
Sunday Rider is offline   Reply With Quote
Old 08-31-2011, 07:29 AM   #1528
cccbarkbuster
cccbarkbuster's Avatar
Oddometer: 215
You got the only ones! your bike has so many on it there`s not enough left for mine. Last day of August and still no brackets for me. Next weeks trip is looking grim for getting the lights back on
The older I get the faster I was
surviving over 40yrs adventures on 2 wheels
08 Kawasaki klx450r
08 Buell Uly XB12xt
78 BMW R100rs (sold 3/13/11)
04 KTM200exc 09 Kawasaki Versys(daughters)
cccbarkbuster is offline   Reply With Quote
Old 08-31-2011, 07:50 AM   #1529
Unstable Rider
Fart and run
Unstable Rider's Avatar
Oddometer: 2,498
LED failed
My pair of lights is just about one year old. I just had one side or one of the two lights fail- she's totally dark for no particular reason.
It was one of the second models perhaps, the one's where you have three posistions of intensity in the lights,
what's the procedure to get a replacement? warranty ?
It's also the end of August, and I would like to upgrade to the heavier brackets.
Thanks- I have been a big fan and supporter of these lights as they had certainly served well until just lately. Check my previous posts, happy as a clam till just now.
-“Ah, you're wasting you're time. They can't track us over rocks.
Tell them that.......... --Who are those guys?”
~Butch Cassidy
Unstable Rider is offline   Reply With Quote
Old 08-31-2011, 04:33 PM   #1530
kaosrider
kaosrider's Avatar
Oddometer: 869
DRZ 400 Mounting
I have not searched the entire 100 pages for this so I thought I would post up if no one else had... Sorry if it is 205.
I got my new lights and then struggled to find a place to mount. Solution was to use the front turn signal mounts and relocate turn signals.
I got some small led turn signals and mounted them in my hand guards, above
The brackets for the turn signal are made exactly for these lights, with the wire going through the same hole used for turn signals. It was cool how suzuki designed these brackets for these lights knowing we would want to change them out like this in the future.
The led turn signals are little lastic lights with plastic nuts. Simple to replace if I break them. The big bonus was they use much less blinker fluid.
Now time to go out for a night ride in the woods
kaosrider is offline   Reply With Quote
Times are GMT -7.   It's 09:15 AM.
