08-31-2011, 03:36 PM
#1531 | |
Oddometer: 429
also, did they come with the handle bar mount? |
08-31-2011, 05:04 PM
#1532 |
The Professor
Oddometer: 1,180
I did not bend the mounts to get my lights aligned. The two times I had failures, (4 Brackets in total) they were mounted as you see on the bike. They both failed after extended rough back road riding( 20 Hours nonstop). And I found out after the last set I had a bad front engine mount, So the vibration at that point was bordering on severe. On the second set I was checking the lights every 300 miles for cracks. I think once the crack starts, it just snaps off. Just add me running my bike very aggressively over rough surfaces to the mix.
Hog Rider IBA # 31325 AMA# 739943 Cobb Etc.. http://carlstwowheeledadventures.blogspot.com 2006 Buell Ulysses, Current Rally Mount 1984 HD Electra Glide Classic 1977 BMW R 100/7 Cafe' 1982 Honda CBX Super Sport, Work in progress |
08-31-2011, 05:20 PM
#1533 |
Unbunch yer panties!
Oddometer: 1,105
KTM 990, 2010.
Blackdog Cycle Works mount, needed a little work to fit: http://www.advrider.com/forums/showp...0&postcount=19 ![]() Stock low beam: ![]() Stock High Beam (underexposed somewhat by point n shoot camera-it's not quite THIS bad...) : ![]() Plus model 24 flood and model 30 spots: ![]() THAT'LL do! Beam patterns. Note: Shot with point n shoot, brightness is not relative image to image. Distance: ~80 feet. Stock High beam only: ![]() Stock High Beam plus Model 30 spot: ![]() Stock High beam, model 24 flood, and model 30 spot combined: ![]() The right way to do this would be to go out with a manual camera on a tripod and use consistent settings image-to-image, but I had the point n shoot and a wall.... ![]() Steve
When in doubt, PIN IT! It may not help, but it'll sure end the suspense... Wretched Exce$$ See ADVr's around the world-ADV spotwalla page Riding Wretched Wretched Passes Bad decisions make good stories. |
08-31-2011, 05:25 PM
#1534 | |
The Professor
Oddometer: 1,180
I rode them hard for over 7000 miles in the last 3 weeks, I did a Lower Lakes 1000 to shake the bike down and then I did the Beast in the East rally where I put over 5000 miles on them in 5 days plus commuting 1400 miles to the rally start and finish. If you are putting these your Buell, Consider them well tested.
08-31-2011, 06:17 PM
#1535 | |
Oddometer: 30
95 Nighthawk 750 93 Nighthawk 750 Living Life in the Wind |
08-31-2011, 07:08 PM
#1536 | |
OMGWTFFTW
Oddometer: 1,235
08-31-2011, 08:37 PM
#1537 |
Oddometer: 1,491
09-01-2011, 04:04 AM
#1538 | |
OMGWTFFTW
Oddometer: 1,235
The blinkers are bright!! The whole neighborhood will know where you are going.
09-01-2011, 04:33 AM
#1539 | |
Adventurer Wanabe
Oddometer: 399
How's your body doing...
'97 Honda ST1100 |
09-01-2011, 04:55 AM
#1540 | |
I Ride Ms Piggy
Oddometer: 1,798
viz |
09-01-2011, 11:50 AM
#1541 | |
Oddometer: 602
They did not come with the handle bar mount. If they did I would have probably not figured out how to use the turn signal brackets .I thought about the light with the turn signals only after, deciding to use the turn signal brackets otherwise I probably would have... |
09-01-2011, 03:39 PM
#1542 | |
The Professor
Oddometer: 1,180
I am planing a 7K week for next year ..... Butt Lite ....One reason I can do this is how good I can see at night, And these LED lamps make my nights a pleasure !
09-02-2011, 05:52 AM
#1543 |
Oddometer: 1,213
Thanks to that great diagram posted a couple pages ago, I was able to install these on my KLR.
![]() ![]() ![]() ![]() ![]() I am not happy with the rats nest of wire leading to the relay, but its out of the way so I will have to live with it for awhile. I went with two spots.
2003 Suzuki Bandit 1200S 2009 KLR650 |
09-02-2011, 09:43 AM
#1544 | |
breaking wind
Oddometer: 2,583
* 05FJR/74R90s * If we concentrated on the really important stuff in life, there'd be a shortage of motorcycles. |
09-02-2011, 03:36 PM
#1545 | |
Oddometer: 1,213
