Old 10-20-2011, 08:06 PM   #1651
FJRJO
FJRJO's Avatar
Oddometer: 47
Thumb
Ok got it figured out. With the E/B harness you use the Aux lights leads and wire+ then - together and use them for the inputs on the dimmer.So excited that I ordered the Remote Dimmer tonight. Thanks everyone look forward to snapping some photos of the finished product, cut some zinc coated tubing for spacers to replace the nuts on the mount tightens up much better.Got to love this place and all the no how great minds all in one place.
FJRJO is offline   Reply With Quote
Old 10-21-2011, 06:20 AM   #1652
Ginger Beard
I have no soul
Ginger Beard's Avatar
Oddometer: 6,725
"I have great faith in fools; self-confidence my friends call it." ~Edgar Allen Poe~
My Scramster Build
3 weeks solo: Overland Expo East ,Barber Vintage Fest and beyond
Ginger Beard is offline   Reply With Quote
Old 10-21-2011, 08:37 AM   #1653
OaklandStrom
Oddometer: 1,612
Originally Posted by wishin4woods View Post
Hey FJRJO,
Here is a wiring diagram for a High Beam Bypass Dimmer install.
Where can I order the High Beam Bypass Dimmer?
OaklandStrom is offline   Reply With Quote
Old 10-21-2011, 08:45 AM   #1654
FJRJO
FJRJO's Avatar
Oddometer: 47
Question
ADVrider on this forum
Old 10-21-2011, 08:49 AM   #1655
Ginger Beard
I have no soul
Oddometer: 6,725
Hey Oaklandstrom,
You can order directly form our web store at www.advmonster.com
Here's a direct link to the HBB Dimmer
My Scramster Build
Old 10-21-2011, 08:55 AM   #1656
FJRJO
FJRJO's Avatar
Oddometer: 47
Thumb
What he said. Sorry about that be sure to use the code INMATE to get you 10% discount on the checkout page.
Old 10-21-2011, 09:34 AM   #1657
Ginger Beard
I have no soul
Oddometer: 6,725
My Scramster Build
Old 10-22-2011, 12:41 AM   #1658
OaklandStrom
Oddometer: 1,612
Hey Oaklandstrom,
I thought that might be it, but the picture doesn't match the schematic.
Where's the violet wire?
Honestly, I don't like the idea of a wireless dimmer. Can I set it to 50% and have it hit 100% when the high beams are on - then throw away the fob?
Old 10-22-2011, 12:44 AM   #1659
jussaral
Oddometer: 29
Yes i've done that, no problems at all Only issue is the size of the dimmer difficult to find a place for it in my BMW 800gs :-)
For normal riding the lights are +- 40 % of the full power
jussaral is online now   Reply With Quote
Old 10-22-2011, 02:15 AM   #1660
Sean-0
straya carnt
Sean-0's Avatar
Oddometer: 4,463
So gents the consensus is to run these at say 40 to 50% pwr most times then full pwr for high-beam situations yes?
as i will only run mine on high-beam as there wired in my headlight switch would this be ok for longevity ?
also you think if i make some sort of tube to fill between the brackets to remove the internal nuts is a better idea also ?
i have removed my rubber washers as directed , and i have them mounted on the side's of my fairing , i placed large washers inside the fairings to act as a plate for more support
Sean-0 is online now   Reply With Quote
Old 10-22-2011, 09:23 AM   #1661
OaklandStrom
Oddometer: 1,612
In the day, I want to be seen.
At night, I want to see.
I'll run them at 50% or so during the day so other people notice me more.
When my high beams are on, I want to light up the road. However, these are too bright to run at 100% all the time - if they are adjusted correctly.
LEDs have overheating problems, and big wattage dies like this tend to get hot. By pulsing them on/off quickly, the heat should stay down - which should lead to longer life. I'm saying this in general, and this isn't a comment about the longevity of this particular light.
Old 10-22-2011, 10:50 AM   #1662
Low594
Adventuring Creep
Low594's Avatar
Oddometer: 1,160
I run mine on low, all the time, day & night. I switch to high when i'm alone on a road at night and I never use the middle setting.
Low594 is offline   Reply With Quote
Old 10-22-2011, 11:39 AM   #1663
Hog Rider
The Professor
Hog Rider's Avatar
Oddometer: 1,455
I run mine on low in the day as a DRL, At night I use these on low in traffic and I toggle them as traffic dictates. But most of the time they are on low or high.
Hog Rider
IBA # 31325
AMA# 739943
Cobb
Etc..
http://carlstwowheeledadventures.blogspot.com
2006 Buell Ulysses, Current Rally Mount
1984 HD Electra Glide Classic
1977 BMW R 100/7 Cafe'
1982 Honda CBX Super Sport, Work in progress
Hog Rider is offline   Reply With Quote
Old 10-23-2011, 11:22 PM   #1664
JustinP
JustinP's Avatar
Oddometer: 1,995
I'm adding the simple push button switch for on/off, as well as the dimmer module with high beam control. Would the switch go before (Battery side) or after (light side) the dimmer?
JustinP is online now   Reply With Quote
Old 10-24-2011, 12:28 AM   #1665
heilong
Oddometer: 90
Both will work, but it makes more sense to put the switch before the dimmer. Are you connecting directly to the battery? If so, you will have to remember to always turn them off when you park the bike, otherwise you'll get a flat battery. Best to connect to switched power (that is on only when the ignition is on) - e.g. using an accessory relay.
BTW, the dimmer's control fob has an on/off button, besides the brightness control buttons. You might want to just use that, without an additional switch. I'm not sure how it inter-operates with the high beam function - gotta test it all on the bench, before you wire it up.
heilong is offline   Reply With Quote
Times are GMT -7.   It's 11:53 PM.
