Old 10-24-2011, 06:02 AM   #1666
Ginger Beard
I have no soul
Ginger Beard's Avatar
Oddometer: 6,854
Originally Posted by JustinP View Post
I'm adding the simple push button switch for on/off, as well as the dimmer module with high beam control. Would the switch go before (Battery side) or after (light side) the dimmer?
Place the switch between the battery and dimmer.
As stated , wiring the power leads for dimmer to a keyed power source will help lower the risk of draining the battery but if you don't "see" that you left these lights on you may have more of a problem than just a dead battery.
Ginger Beard is online now   Reply With Quote
Old 10-25-2011, 08:01 PM   #1667
FJRJO
FJRJO's Avatar
Oddometer: 47
No led
Got my remote dimmer in 3 days there was no led indicator that I thought was part of the package deal.
FJRJO is offline   Reply With Quote
Old 10-25-2011, 10:42 PM   #1668
heilong
Oddometer: 90
Why did you think it's included? When I ordered a dimmer, I didn't notice any package deals like that, bought the LED indicators separately.
heilong is offline   Reply With Quote
Old 10-26-2011, 06:03 AM   #1669
sanjoh OP
Purveyor of Light
sanjoh's Avatar
Oddometer: 5,367
There is an led on the remote fob that flashes when a button is pushed. Just above the large arrow key.
ADVmonster...BLOG....Dirt Ninja Build...TAT 08
Old 10-26-2011, 07:43 AM   #1670
MN_Smurf
Capt_Confusion
MN_Smurf's Avatar
Oddometer: 2,765
Originally Posted by OaklandStrom View Post
I thought that might be it, but the picture doesn't match the schematic.
Where's the violet wire?
Honestly, I don't like the idea of a wireless dimmer. Can I set it to 50% and have it hit 100% when the high beams are on - then throw away the fob?
The picture of the dimmer module is the older one that didn't have the high beam bypass. That's the one I have....once I have the brightness is set where I want it, I throw the fob in one of my jacket pockets and forget which one it's in. The way you want to use it should work fine. I plan on upgrading to the new dimmer sometime here in the off season and will use it the same way.
'09 Kawi Versys
"A life is like a garden. Perfect moments can be had, but not preserved, except in memory. LLAP" - Leonard Nimoy
MN_Smurf is offline   Reply With Quote
Old 10-26-2011, 08:28 AM   #1671
FJRJO
FJRJO's Avatar
Oddometer: 47
Thumb Ok
OK misunderstood the post when the the dimmer with high beam feature was introduced. Everyone was ask what options would you want with the dimmer to indicate the lights where on or off,and once decided from input it would be included with the dimmer. Did I dream this? Its no big deal, I am pleased with the dimmer but wanted to clear this up.
Old 10-26-2011, 09:49 AM   #1672
sanjoh OP
Purveyor of Light
sanjoh's Avatar
Oddometer: 5,367
There is a panel mount led indicator available here
If put in line with your LED aux lights the panel led will be on when the lights are on. As an additional bonus the indicator led will glow brighter when you increase the output to your lights from the dimmer and vise versa.
Old 10-26-2011, 01:55 PM   #1673
FJRJO
FJRJO's Avatar
Oddometer: 47
Bluhduh
Originally Posted by sanjoh View Post
ADVmonster is set to release our wireless dimmer with the high beam bypass.
Hit the high beams and your LED lights go to full power, independent of the dimmer.
You still get all the benefits of the wireless dimmer
We are considering an add on led indicator to let you know when the lights are on.
If you had this led, where would you mount it?
Panel mount
Integrated with a switch
goop mount
other?
"We are considering an add on led indicator to let you know when the lights are on."
This is what made me think the led would be included. I have looked at it on your web site and would have ordered it but this is why I didnt.
Old 10-28-2011, 12:08 PM   #1674
heilong
Oddometer: 90
I'm Russian, but in my understanding of English, "add on" means something not included, something available as an optional accessory.
Old 10-28-2011, 12:20 PM   #1675
Mambo Dave
Backyard Adventurer
Mambo Dave's Avatar
Oddometer: 5,864
+1, I'm pretty sure that's the way I would have read it.
If it had read "We are considering adding on an led indicator" then it would have been different.
"After reading through this thread I've come to the conclusion
that more people cruise the internet looking for reasons why
X bike won't work in Y scenario rather than actually riding
their motorcycles
RyanR
Mambo Dave is offline   Reply With Quote
Old 10-29-2011, 07:43 PM   #1676
viz
I Ride Ms Piggy
viz's Avatar
Oddometer: 1,813
Need some collective wisdom here:
Have revamped my lighting system with new lights (again).
Curly one (for me) - the digital voltmeter - instructions on the box say Red +, Black -, Blue + Signal. Got me beat how that works, with my limited electronics knowledge. What I have done is connected the voltmeter to the + & - of the *battery* side of the dimmer and connect the blue signal wire to the + red wire on the *lights* side of the dimmer. However when I activate the lights and vary the power output via the dimmer the voltage remains the same so I am assuming it is reading the battery voltage at 12.2v regardless on how weak I have the lights. Everything else works. Just can't get the voltmeter sorted.
Anyone? Sanjoh? (have emailed this question privately as well, but thought that it would be a good idea to put it out there in case anyone else has a problem)
viz
Pig In The City - 2010 BMW R1200 GSA Adventure
Webmaster BMW Touring Club of NSW
viz is offline   Reply With Quote
Old 10-29-2011, 08:15 PM   #1677
Nero
Nero's Avatar
Oddometer: 245
PWM dimmer
The dimmer is a PWM, Pulse Width Modulator. It doesn't reduce the voltage like a potentiometer but it basically cycles or "pulses" the voltage. So you are always going to see your 12v. Hope that's good enough for ya.
Nero
Nero is online now   Reply With Quote
Old 10-30-2011, 01:08 AM   #1678
heilong
Oddometer: 90
If you search ebay for "panel led volt meter" or "panel lcd volt meter", you will find there are two kinds of voltmeter - the first kind have just two wires, they measure the voltage that's also supplying them with power. The other kind has two wires for powering the voltmeter itself, and the other two wires that can measure voltage in a completely different circuit. The second kind usually accepts a narrow range of voltage for power (e.g. 9-12V), but can measure a much wider range on the load (e.g. 0-200V). The voltmeter sold by ADVMonster is of the second kind, with the power/signal grounds connected together inside. If you just want to monitor your electrical system's voltage, it makes sense to just connect the blue wire to the red one. As have been said, you can't measure the PWM dimmer's output power using a voltmeter. If you connect a small panel-mount LED in parallel with your lights, the LED's brightness will be some indicator of the dimmer's setting. All this uncertainty about the current power levels, plus the dimmer size, led me to make my own dimmers. I've bought the ADVMonster's dimmer but then decided to not use them, due to the size and not liking the remote control very much. I've got some 12V 8A dimmers in plastic enclosures from ebay, ditched the enclosures, changed the potentiometers to sealed panel-mount ones, connected the pots to the dimmers by soldering longer wires to them, and sealed the dimmers using small plastic enclosures and special silicone compound for sealing PCBs etc. It's somewhat flexible when cured, totally waterproof and should protect both from moisture and vibration. The dimmer modules are at least half the size of the remote-controlled ones (maybe even less), with external disconnectable rotary pots that one can mount on a panel. The high beam bypass function is handled by an additional (replaceable) sealed relay that is external to the dimmer and is integrated into the bike's wiring. The same dimmer can also be used for heated grips or clothing (if they don't exceed the 8A rating). I've made three such dimmers - one for the lights, one for heated grips, and a spare one. My wiring is made uniform, so if, for example, my lights dimmer fails while I'm on the road, I can just unplug the heated grips dimmer and use it instead to control lights (and vice versa), or plug the lights directly into the connector that should normally power the dimmer.
Old 10-31-2011, 12:32 PM   #1679
Ginger Beard
I have no soul
Oddometer: 6,854
I will be doing a dimmer and volt meter install within the next few days. It will be a picture tutorial on my KLX300. Sadly due to a stator that puts out power slightly north of a potato battery I will only be a able to run 1 Model 30.
Old 10-31-2011, 06:42 PM   #1680
viz
I Ride Ms Piggy
viz's Avatar
Oddometer: 1,813
Nero
Guys thanks for the info - just had it confirmed that the voltmeter wont do what I wanted... Oh well - I am sure that I will find a use for it, somewhere. Still cannot work out what the signal wire is for...
Please note that while I can work my way around a simple electrical system, anything that involves more than a vacuum tube has me beat...
viz
Times are GMT -7.   It's 07:46 AM.
