11-04-2011, 11:56 AM
#1696 |
BluezMan
how much for them ?
this space is currently for rent. |
11-04-2011, 12:00 PM
#1697 |
Purveyor of Light
Oddometer: 3,664
Model 60 LED 3600 lumens . . LED thread in Vendors Dualsport Fairing w LED...Dirt Ninja Build...TAT 08... |
11-04-2011, 12:31 PM
#1698 |
Oddometer: 47
11-05-2011, 02:40 AM
#1699 |
I Ride Ms Piggy
Oddometer: 1,798
I have actually been thinking on how to properly demonstrate the difference - without as you say, "burning" out the camera's CCD. I have been known to do an occasional bit of photography now and then so it should not be too difficult. Watch this space. I am off to a Warbirds Airshow in Temora, NSW (Oz) in a coupla weeks and it should be nice 'n' dark to do things. But depends on which camera I take with me - if I take the DSLR no probs. The little point and shoot, weeeeelll maybe not so easy. iPhone? It'd get nuked I reckon. viz |
11-05-2011, 04:02 AM
#1700 | |
Adventurer Wanabe
Oddometer: 399
![]() I know even with the 44s only the head on shots are blinding. Looking forward to the pics.
'97 Honda ST1100 |
11-05-2011, 06:11 AM
#1701 |
I have no soul
Oddometer: 5,585
Important Ordering Information!!
Hey guys,
Just a heads up for anyone wanting to order lights and accessories from ADVmonster.com on Nov 5th or Nov 12th. Online credit card processing will not be available on the following dates at the following times due to site maintenance: Saturday, Nov. 5, from 5 p.m. - 9 p.m. Pacific Time. Saturday, Nov. 12, from 8:30 p.m. - 1 a.m. Sunday, Nov. 13, Pacific Time. If you need to place an order during those times please contact us either via email or by phone. I apologize in advance for any inconvenience. Dave
"I have great faith in fools; self-confidence my friends call it." ~Edgar Allen Poe~ My HD Scram-ster build Help Save a Pit-Bull |
11-05-2011, 06:59 AM
#1702 | |
Oddometer: 265
Spots were 9W (3x3w) which were upgraded to 11W (3x4w) running slightly below power due to the driver. The driver in this is able to take up to 30v while the 24w one is up to 24v. Also for the record neither spot or flood models have overheat protection in the driver circuits, the lights are designed for water usage which is a much better heatsink than air. This is why some have had LED burn on the 24w models and why I personally don't use them. I've got a 9W and an 11W using flood lenses (you can buy cree lenses on ebay for very little). |
11-05-2011, 08:09 AM
#1703 | |
I have no soul
Oddometer: 5,585
All of our Auxiliary lights have a thermal protector which lowers power output when a preset temperature is reached in order to protect the LED clusters and the internal circuitry. Once they have cooled they will switch back to their previous preset output range. Though the housings do share a similar appearance to other lights on the market, the internal systems which power them have been specially designed by us for the express purpose of motorcycle use.
11-05-2011, 10:21 AM
#1704 | |
Oddometer: 265
Secondly, if you were designing for the "express purpose of motorcycle use" then me thinks you would not have sold them with the crap bracket that comes from the factory.
11-05-2011, 10:28 AM
#1705 |
Oddometer: 1
I was searching for endless time and finally got what i need. I will use this kind of led lights
11-05-2011, 11:54 AM
#1706 |
BluezMan
any chance of you supplying a non wireless dimmer ?
i dont do wireless...
11-06-2011, 05:00 AM
#1707 | |
Purveyor of Light
Oddometer: 3,664
Snoopy - you are obviously using lights from somewhere else, we don't have 9w or 11w lights. And all of our lights have overtemp protection built in. If you are having problems with your lights, why not contact the company that sold them to you?
#1708 | |
Oddometer: 89
http://www.advrider.com/forums/showp...&postcount=395 Here's the one I used: http://www.advrider.com/forums/showp...&postcount=605 I've thrown away the plastic casing. The PCB itself is 50x50x14mm, pretty slim, I've desoldered the green terminal block from the board and soldered in/out wires there, also desoldered the pot connector from the board and soldered longer wires in place (this is not necessary if the length of the original pot wires is enough). Then I went to a local electronics DIY shop and bought a 50x50x15mm plastic case and some special 2-part compound used for sealing electronics modules. The compound is waterproof, dielectric, a good heat conductor (allowing proper cooling for the dimmer's electronic components) , and it cures to a solid but somewhat elastic substance, which is good for vibration resistance.. The wires bundle just stick up from the sealed module. I also bought some very nice panel-mount IP67 sealed potentiometer made by Vishay-Sfernice to use instead of the pot supplied with the dimmer. If using the supplied pot, it should be put into an enclosure (e.g. a small plastic case) for water resistance, otherwise I don't think it would last long. The sealed pot costs more than a couple of these chinese-made dimmers, but should last a lifetime. The sealing compound has also cost me a bit (the local Russian shops are all quite expensive), so the final product costs maybe 5x of the dimmer's cost. But I like the final result :) Here's a dimmer just like I bought (well at least it's the same case, innards might be different, as is usual with Chinese-made goods - it's common to several factories buy the same cases/enclosures/flashlight bodies from a single (or several other) manufacturers and put their own, widely differing electronics inside, so it's best to ask the seller for a photo of the internals): http://www.ebay.com/itm/New-DC-12V-8...item336cbea9a6 And here's the sealed pot I'm using: http://www.newark.com/vishay-sfernic...-1w/dp/76M9955 Here's a pic of my dimmer with the original pot enclosed in a small plastic case and the Vishay-Sfernice sealed pot beside it.
heilong screwed with this post 11-06-2011 at 07:50 AM |
11-06-2011, 05:21 AM
#1709 | |
Oddometer: 89
Here's a link to the pics and tests made by an inmate: http://www.advrider.com/forums/showp...&postcount=305 The lights do have thermal protection, and it works. Don't be so certain in your skepticism before you get the facts straight. Judging by the number of people reporting problems with the brackets, they are adequate for most users. This probably depends mostly on the particular mounting locations chosen by the users. Some people might need the heavy-duty bracket, indeed, but I suppose the majority doesn't. I like my equipment to be as durable and reliable as possible, so I did pick up the heavy-duty brackets for my lights, but I'm pretty sure I wouldn't have any problems with the original brackets. In a modern world many, if not most, products are made in China. It's quite common for manufacturers in China to mix and match components from different suppliers to make their own products. So inside an identically looking enclosures/cases/bodies might be completely different internal parts. If an entrepreneur/small-business owner/inventor has a product idea, it's more economical, practical and faster to use readily available components for the product, than to custom design and produce all the parts. Small orders with manufacturers are usually very expensive (per item), so it makes a lot of sense to not use custom parts when and where possible. Thus a company like ADV Monster selects a readily available light housing, the LED assembly, and designs their own rugged electronics driver to power the light (plus who knows what other parts and mods). So even if they look 100% identical to a model of underwater aquarium lights, it's quite probable that they are not them, but instead are former underwater lights adapted and upgraded for motorcycle use. heilong screwed with this post 11-06-2011 at 06:06 AM |
11-06-2011, 06:53 AM
#1710 |
Oddometer: 265
The way I see it these guys have bulk ordered from the Chinese factory and say they've made some super-duper changes yet the facts are;
1. this light is designed for under water. It requires a bigger heatsink for sustained usage in air or movement. 2. the bracket is designed for a fish tank, and they passed on the original bracket for use on a motorcycle. It is clearly going to fail but is a matter of time and frequency of the engine. 3. the lights they sell exhibit LED burn, indicating they are using the same internal electronics. If you're happy to take their word for it then fine. I'll keep my scepticism until proved otherwise with proper evidence. |
