Old 09-16-2010, 03:39 AM   #166
JDLuke
Ravening for delight
JDLuke's Avatar
Oddometer: 8,644
Originally Posted by cooter69
Ah ha! If we want to dim the LEDs, all we need to do is ride through a swarm!
Why did I drink all of the ingredients for vomit?
"Used to be Man vs. Nature.. then Man vs. Space.. then Man vs. the Moon. Now it's Man vs. Food" - Dalar
"you cannot reason a person out of something they were not reasoned into." - Jonathan Swift
JDLuke is offline   Reply With Quote
Old 09-16-2010, 05:30 AM   #167
Sunday Rider
Adventurer Wanabe
Sunday Rider's Avatar
Oddometer: 793
Thanks Cooter69 for posting those. That is exactly what I needed to see.
Nice to see it set up on the ST1100. A great choice of bike. We are really out numbered here.
Any problem with the oncoming traffic being blinded?
'97 Honda ST1100
Sunday Rider is offline   Reply With Quote
Old 09-16-2010, 06:06 AM   #168
cooter69
Smells Bad
cooter69's Avatar
Oddometer: 149
Riding with the low beam + led I get flashed no more than with the silverstars alone while riding in the hills. Nobody cared in town where there is more light around
cooter69 is offline   Reply With Quote
Old 09-16-2010, 09:12 AM   #169
cug
Oddometer: 4,945
Here's some shots mounted on a 1999 st1100
The headlight bulbs are silver stars.
Those are the floods, right?
cug is offline   Reply With Quote
Old 09-16-2010, 12:20 PM   #170
cooter69
Smells Bad
cooter69's Avatar
Oddometer: 149
Yep. I plan on adding some spots to the tip over wings since I don't run hiway blades. The mount the light comes with would be pefect for this.
The floods do have a sharp drop off you can see in the pics......
I'm comfrotable doing 55 in the hills with this. For the hiway I would like a little more long range light. This is no different than most aftermarket floods
Old 09-16-2010, 03:33 PM   #171
aalegado
Team Gear Whore
aalegado's Avatar
Oddometer: 477
Always keep your optics clean! Remember what happened to Chris Knight!
2009 Aprilia SL 750 Shiver / 2013 Piaggio BV 350 "Beverly"
aalegado is offline   Reply With Quote
Old 09-16-2010, 03:51 PM   #172
Timmer
Timmer's Avatar
Oddometer: 2,361
I've also thought of mounting them to the tip over wings on my '01 ST1100, but wouldn't that make the lights vulnerable?
Yep. I plan on adding some spots to the tip over wings since I don't run hiway blades. The mount the light comes with would be perfect for this.
Tim in Burien, WA
'05 R1200GS '03 F650GS
'08 WR250R
'03 Wing
'01 ST1100
Timmer is offline   Reply With Quote
Old 09-16-2010, 03:57 PM   #173
Sunday Rider
Adventurer Wanabe
Oddometer: 793
Hey another ST1100, wooohooo.
I have a one LED light on the tip over wing, mounted on the bottom. I have the highway blades.
12,000 miles so far and no trouble, except a big bug can block that one eyed LED.
'97 Honda ST1100
Old 09-16-2010, 04:05 PM   #174
cooter69
Smells Bad
cooter69's Avatar
Oddometer: 149
I don't know if I would hang them off the bottom I think I might knock them off I touch pegs hit boots often enough that this would be an issue. The top of the wing would not be any more of an issue than my current mount. You would have to bend the wings in order to damage the lights. At that point the 100 bucks for the light would be second to breaking the plastics and replacing the color matched bags....
Old 09-16-2010, 04:43 PM   #175
Timmer
Timmer's Avatar
Oddometer: 2,361
You definitely have that right on the color-matched bags. I do like the idea of mounting them on the top side of the tip-over wings. I'll have to look at that closely tonight. I have some used tipover wing covers I could experiment with.
Tim in Burien, WA
'08 WR250R
'03 Wing
'01 ST1100
Old 09-16-2010, 04:59 PM   #176
cooter69
Smells Bad
cooter69's Avatar
Oddometer: 149
I know all about optics.......my name is Jay Knight....now
Old 09-16-2010, 05:10 PM   #177
PattiBlastoff
Pattiblastoff
PattiBlastoff's Avatar
Oddometer: 4
Talking LED Aux Lights from Sanjoh
I love these lights! Thanks! And things I should have done five years ago and I would have loved my bike better like I do now...bar backs and Techlusion to get rid of that crazy surging! Now I am a happy gal
PattiBlastoff is offline   Reply With Quote
Old 09-16-2010, 07:20 PM   #178
Dirt_Bag
Dirt_Bag's Avatar
Oddometer: 38
Do they stay that g a y blue color
Dirt_Bag is offline   Reply With Quote
Old 09-17-2010, 09:18 AM   #179
juddspaintballs
Never too many bikes
juddspaintballs's Avatar
Oddometer: 467
I like these a lot. I've been needing a pair of auxiliary driving lights for the ST1100 for a long time, but haven't found the right ones yet. I think I'll go convince the wife tonight that I need a pair of these flood beams and then I can wire them up to the ST. I'll do a low fork mount for them, though, because I want to be able to leave them on with oncoming traffic.
Let's say I wanted to run these in such a manner that they would be 100% bright with the high beams on and 50% bright with the low beams on. Could I use a standard Bosch relay to power them, with pin 87 going directly to the lights, and pin 87a going through a PWM and then to the lights. When the high beam wire activates the relay, it would power through pin 87, and when the high beam wire is not powered, the relay would be not activated, and power should go through pin 87a. Is this correct? Is that a reasonable way to dim these lights at the same time I dip my headlight?
juddspaintballs is offline   Reply With Quote
Old 09-17-2010, 10:21 PM   #180
Stromdog
Howl at the Moon
Stromdog's Avatar
Oddometer: 2,703
Here's a few pics of these lights mounted on my DL 1000
I bought a toggle switch from the auto parts store that lights up when their on.
Stromdog is offline   Reply With Quote
Times are GMT -7.   It's 01:02 AM.
