Old 01-26-2012, 09:00 AM   #1936
Ginger Beard
I have no soul
Ginger Beard's Avatar
Oddometer: 6,445
Originally Posted by n16ht5 View Post
sweet! will the m60 overheat if I put it in my headlight housing?
Yes. This light needs airflow for cooling. It does have a thermal protector so that if it does begin to get too hot the power to the light is reduced until it is back to a safe operating temp. It is a very compact design however so finding a mounting solution outside of your headlight housing shouldn't be much of an issue.
"I have great faith in fools; self-confidence my friends call it." ~Edgar Allen Poe~
My Scramster Build
3 weeks solo: Overland Expo East ,Barber Vintage Fest and beyond
Ginger Beard is offline   Reply With Quote
Old 01-26-2012, 09:48 AM   #1937
Drabnor
Oddometer: 104
Yea the 60 does get hot for sure! the 30s stay cool as a cucumber...
just to recap, Im running 2 model 30s and one model 60
please excuse the crappy quality, my phone does not do night shots very well...
low beam/dimmed leds
high beam/full bright leds
shot showing the voltmeter
Drabnor is offline   Reply With Quote
Old 01-26-2012, 09:55 AM   #1938
n16ht5
ride the night
n16ht5's Avatar
Oddometer: 2,346
can I rely on the thermal protector? I was planning on replacing my headlight with this altogether..
n16ht5 is offline   Reply With Quote
Old 01-26-2012, 10:26 AM   #1939
Ginger Beard
I have no soul
Oddometer: 6,445
The thermal protector is quite reliable but understand that when it cuts the power, the light will dim dramatically.
That said, I strongly do not recommend the 60 as your only light for various reasons. The main one being that it is ridiculously bright even when dimmed down a good bit. Having read your RR threads I know that you spend a fair amount of time on the road. It will blind the heck out of anyone that looks at it even if they only look momentarily.
My Scramster Build
Old 01-26-2012, 11:29 AM   #1940
Ginger Beard
I have no soul
Oddometer: 6,445
Hey Drabnor,
Thanks for posting the pics and for the feedback.
My Scramster Build
Old 01-26-2012, 02:05 PM   #1941
subybaja
subybaja's Avatar
Oddometer: 2,889
Hrm. I've got a 44 I'm planning to use with a PWM dimmer as my main light... With the output stepped down it's still too bright? Is that because LEDs are such a concentrated point-source?
We had part of a Slinky. But I straightened it.
subybaja is offline   Reply With Quote
Old 01-26-2012, 03:38 PM   #1942
sanjoh OP
Purveyor of Light
sanjoh's Avatar
Oddometer: 4,937
Dimming will make it much nicer to others on the road. Just make sure whatever dimmer you use it can dim low enough, ours will dim the lights to off with 256 increments.
Old 01-26-2012, 03:44 PM   #1943
FYYFF
Forever young...
FYYFF's Avatar
Oddometer: 2,023
Queston: Can I use your Xpel Clear Light Protection on 60's safely? Or are they gonna melt???
- 2010 KTM 990 Adv. -
My Smugmug
Follow me with SPOT
My YouTube
FYYFF is offline   Reply With Quote
Old 01-26-2012, 04:00 PM   #1944
sanjoh OP
Purveyor of Light
sanjoh's Avatar
Oddometer: 4,937
You should be good, they withstood 135c for 16 days with no detrimental effects.
Old 01-26-2012, 04:18 PM   #1945
jeepinbanditrider
Dunkin Donuts Crasher
jeepinbanditrider's Avatar
Oddometer: 1,164
Quick question.
Do these need to be mounted at a 90 degree angle? I.E. do they need to be "straight down" or "straight out" to the side relative to the road or does that matter? If I do a high fairing mount I may need to go at an odd angle like 40 degrees or so from the brackets.
2004 Suzuki DL650 Weestrom
1978 GS 1000
"Those who would trade security for a little temporary safety deserve neither liberty nor safety."
jeepinbanditrider is offline   Reply With Quote
Old 01-26-2012, 06:38 PM   #1946
n16ht5
ride the night
n16ht5's Avatar
Oddometer: 2,346
I was going to puta resistor to the low beam switch... I have a bunch of xml flashlights, they arent too bad for road use
Old 01-26-2012, 06:44 PM   #1947
Subaru297
Oddometer: 116
[/QUOTE]
Do you still have your brackets for the reflectors that were mounted on your forks? Looking at my WRX that will be a perfect place to mount the lights when I order some more.
A picture of the reflector brackets is in this post, hanging off the lower triple clamp bolts;
http://www.advrider.com/forums/showp...ostcount=24242
I have the lights mounted on my Adventure now and they sure do light up the back of the garage door but it is too snowy and cold here for a test drive.
Cheers
Subaru297 is offline   Reply With Quote
Old 01-26-2012, 09:21 PM   #1948
Ohio_Danimal
Midlife Crisis Man
Ohio_Danimal's Avatar
Oddometer: 596
Hey guys.
I'm on a budget and looking for an older model 30 used from someone who has upgraded to one of these new retina wreckers.
If anyone has a good deal on an older one with sitch (or not) PM me please.
I'm gonna run it on my right mirror stalk on my SV650 to help spot deer eyes off to the side of the road a bit.
Wisdom is age well spent.
Anger is age, hell bent.
Ohio_Danimal is offline   Reply With Quote
Old 01-27-2012, 05:13 AM   #1949
Ginger Beard
I have no soul
Oddometer: 6,445
Originally Posted by Behubert View Post
I bought a model 60 and a bike light. I think there might be a problem with the model 60 because the bike light is noticeably brighter. The model 60 is specked at 3600 lumens, where the bike light is 1000. I also tested it with several batteries and still got the same results. Thoughts?
Definitely should not be the case.
PM sent.
My Scramster Build
Old 01-27-2012, 03:05 PM   #1950
sanjoh OP
Purveyor of Light
sanjoh's Avatar
Oddometer: 4,937
Not required to mount at 90 degrees. The flat mount uses a single stud that you can rotate the light about and the mount has a hinge that can be adjusted. If you have a pic of where you are considering for a mount location, we can let you know if it will work.
Originally Posted by jeepinbanditrider View Post
Quick question.
Times are GMT -7.   It's 11:07 PM.
