Old 01-27-2012, 02:10 PM   #1951
tallguy-09
Smile 4 Miles
tallguy-09's Avatar
Oddometer: 1,436
Originally Posted by Behubert View Post
I bought a model 60 and a bike light. I think there might be a problem with the model 60 because the bike light is noticeably brighter. The model 60 is specked at 3600 lumens, where the bike light is 1000. I also tested it with several batteries and still got the same results. Thoughts?
I've just installed the model 60 and it's bright like crazy (don't look at it without the LED's being dimmed...it still hurts...)
The 60 is by far the brightest, although not sure if upgrading from the "44" realy makes more light, I was only curious and also supporting John
who does a great job with excellent service. Maybe the "60" uses genuine Cree LED's so this could be good.
tallguy-09 screwed with this post 01-27-2012 at 04:38 PM
tallguy-09 is offline   Reply With Quote
Old 01-27-2012, 03:43 PM   #1952
Danjal
Insert wit here.
Danjal's Avatar
Oddometer: 2,755
Just a hypothetical question here. But is there a warranty or replacement parts available in the all too likely event that I break one of your lights somehow?
BTW I placed an order for a 60 and im not sure the coupon went through. It seemed like it though. 100+hd upgrade. The coupon box disappeared and nothing said it applied.
The 30s are retina wreckers too. I hooked one up to a battery to check it and it lit up the neighbors house like day from about 100 yards off. Very focused beam, but still impressive.
Danjal is offline   Reply With Quote
Old 01-27-2012, 04:13 PM   #1953
jeepinbanditrider
Dunkin Donuts Crasher
jeepinbanditrider's Avatar
Oddometer: 1,235
Originally Posted by sanjoh View Post
Not required to mount at 90 degrees. The flat mount uses a single stud that you can rotate the light about and the mount has a hinge that can be adjusted. If you have a pic of where you are considering for a mount location, we can let you know if it will work.
Basically about even with the headlights mounted to the fairing itself with some reinforcement on the back side of the fairing. it's no a 90 degree angle probably around 70 but just a guess
Sent from my iPhone
2004 Suzuki DL650 Weestrom
1978 GS 1000
"Those who would trade security for a little temporary safety deserve neither liberty nor safety."
jeepinbanditrider is offline   Reply With Quote
Old 01-27-2012, 07:02 PM   #1954
tallguy-09
Smile 4 Miles
tallguy-09's Avatar
Oddometer: 1,436
"44" close up, unfortunately ISO1250 so not clear:
"60" close up ISO200. Looks to me there is more "juice" in this:
Old 01-28-2012, 06:15 AM   #1955
sanjoh OP
Purveyor of Light
sanjoh's Avatar
Oddometer: 5,127
Those angles should not be a problem.
However I do not recommend mounting the lights directly on the fairing, it may look stable, even with a full backing plate, it will eventually crack or damage your fairing.
What year and model of bike is it? I'll take a look and recommend some alternative mounting spots.
Old 01-28-2012, 06:19 AM   #1956
sanjoh OP
Purveyor of Light
sanjoh's Avatar
Oddometer: 5,127
The lights come with a one year warranty for product defects. Replacement parts are available.
Old 01-28-2012, 07:04 AM   #1957
jeepinbanditrider
Oddometer: 1,235
It's a 2007 Yamaha FZ6. I'd like to mount the lights high either even with or higher than the headlights.
Another option I was thinking of was using a set of mirror mounts that sandwich between the mirrors and mounts for the mirrors. I used to have a similar setup on my FJR pictured below.
1978 GS 1000
Old 01-28-2012, 08:11 AM   #1958
bandera
Oddometer: 17
Guys - I hope you can help me trouble shoot a problem I have.
I just installed 2 Model 60 LED and a Wireless LED Dimmer with High Beam Bypass on an '08 BMW K12GT. With the bike off the lights turn on and off without any problems, but when I trigger the lights off the high beam switch the dimmer box starts to buzz loudly. I assume it is the relay in the box making the racket.
Guidance is appreciated--thx.
Found it....I just walked back out to the bike and reseated the high beam plug. All is well. It was a basic connectivity problem--sheesh.
bandera screwed with this post 01-28-2012 at 08:26 AM
bandera is offline   Reply With Quote
Old 01-28-2012, 08:17 AM   #1959
sanjoh OP
Purveyor of Light
sanjoh's Avatar
Oddometer: 5,127
Here's a setup on an RC51. Inmate used one of the mirror studs to mount the most forward light.
Old 01-29-2012, 12:02 AM   #1960
n16ht5
ride the night
n16ht5's Avatar
Oddometer: 2,387
n16ht5 screwed with this post 01-29-2012 at 08:39 AM
n16ht5 is offline   Reply With Quote
Old 01-29-2012, 08:22 AM   #1961
tallguy-09
Smile 4 Miles
tallguy-09's Avatar
Oddometer: 1,436
[QUOTE=n16ht5;17858981]LIGHT!!! got the 60 light in.. SO NICE! It's about on par in brightness with the HID (or a 100W Halogen)...
I think you meant model 30?
tallguy-09 screwed with this post 01-29-2012 at 08:34 AM
Old 01-29-2012, 08:37 AM   #1962
n16ht5
ride the night
n16ht5's Avatar
Oddometer: 2,387
Pissed
[QUOTE=tallguy-09;17860678]
wait a minute... I ordered a model 60... this IS the 30
SANJOH !
Old 01-29-2012, 10:07 AM   #1963
rs42sport
rs42sport's Avatar
Oddometer: 132
looks like the 30s to me
2004 honda silverwing 600
2004 Honda VTX 1300c sold at 25250miles
2006 Honda Shadow Spirit 750 traded at 9800miles
2009 Burgman 400 traded at 9424 miles
2007 Kymco People S 250-traded at 7860 miles
rs42sport is online now   Reply With Quote
Old 01-29-2012, 10:55 AM   #1964
RZMike
Oddometer: 63
I got my light (model 30) installed on my Husaberg. i used some silicone tubing for a turbo system with a tbar clamp and mounted it to the fork tube. i used a switch with an indicator light on the dash and wired it to my battery tender lead.
RZMike is offline   Reply With Quote
Old 01-29-2012, 01:29 PM   #1965
Spyker
Oddometer: 186
Hi,
I just ordered a set of Model 44 LED lights with a voltage meter. Can I change Model 44 LED lights to Model 60 and include a dimmer?
Originally Posted by scottie boy
If you calculated the money spent versus time actually used, vaginas cost more per hour than the space shuttle.
Spyker is offline   Reply With Quote
Times are GMT -7.   It's 10:46 AM.
