Old 02-06-2012, 08:21 AM   #2011
sanjoh OP
Purveyor of Light
sanjoh's Avatar
Oddometer: 5,040
Nice install Mark. The deer in IL must be nervous about now
I like the high beam relay setup, no additional switches on the bars, however you are losing out on the "being seen" advantage of the LEDs. You should consider one of the remote dimmers, same high beam full on function with the capability to dim the light for "normal" operation for those drivers that may not see you.
I can't count how many times the lights have gotten me seen.
Old 02-06-2012, 03:41 PM   #2012
BigDogAdventures
Fart Letter
BigDogAdventures's Avatar
Oddometer: 4,960
John,
I have finally seen the light !!!!!!!!!: clap
Yes your lights with that fancy dimmer is the "cats"----as Barney Fife used to say to Thelma Lou.
I wish I had it this morning on my ride to work-----------it was barely daylight and my low beam blew out. I couldn't turn on my high beam without blinding people----------I was scared to death riding the 6 miles to work with no headlight and minimal daylight.
The dimmer you have come up with is a true stroke of genius !!!
Mark
2008 Yamaha WR250R---by far my main bike.
2006 KTM 450EXC
2014 KTM690 Enduro--we'll see how good it is after 70,000 miles.
2013 Husky 650 TR650 Terra
I'm good--but I ain't no Dingweeds
BigDogAdventures is offline   Reply With Quote
Old 02-06-2012, 09:33 PM   #2013
Yellow Pig
Allergic to Asphalt!
Yellow Pig's Avatar
Oddometer: 7,463
Here is a simple solution to that problem.
Form those that do not want to fuss w/ having to adjust the LED dimmer's rheostat or deal w/ a silly battery operated remote to switch back and forth from hi beam to low beam and prefer simply using the OEM handlebar Hi/Low switch here is a simple solution:
Old 02-07-2012, 04:25 AM   #2014
sanjoh OP
Purveyor of Light
sanjoh's Avatar
Oddometer: 5,040
WOW, you have no idea how our dimmer works, please check your sources before posting this misinformation.
The fob is used to adjust light output. You DO NOT need the fob to activate full power, or switch between modes, it is accomplished with a signal from the stock high beam or a 12v source of your choosing.
Our dimmer has a memory so once the output level is set, it usually doesn't get adjusted unless you are showing off the lights
Our testing has shown that a dimmer with a knob has a higher likely hood of failure when exposed to conditions that can reasonably be expected on a dualsport
Old 02-07-2012, 10:07 AM   #2015
Yellow Pig
Yellow Pig's Avatar
Oddometer: 7,463
Sorry for the mis-information. I did not have the specs on your key fob dimmer.
The diagram above was meant to work w/ any LED dimmer available.
Old 02-07-2012, 10:09 AM   #2016
Yellow Pig
Yellow Pig's Avatar
Oddometer: 7,463
Sorry I did not see the new version.
This is certainly the ticket:
Old 02-07-2012, 01:28 PM   #2017
ewagman
Oddometer: 28
Has anyone switched from 44's to 60's? I am wondering about a real world comparison, I'd like a just a little more distance than my 44's give when I am really rolling along the straightaways, only because I want more reaction time to compensate for 45 years of riding, not because I am dissatisfied with my 44's. Close to medium distance is really lit up well. The 44's would end up on something else I own.
ewagman is offline   Reply With Quote
Old 02-07-2012, 03:28 PM   #2018
beechum1
Grimace Soup
beechum1's Avatar
Oddometer: 8,311
Originally Posted by tallguy-09 View Post
I had the 44's and switched to the 60's, when looking at the lumens rating the 60's offer more than 50% more than the 44's, so in theory the light should travel farther...
do you have them wired up yet?
Originally Posted by Boondoggle View Post
Watching Dakar is like watching people who've built their own world, and for just a couple of weeks they get to live in it.
Old 02-07-2012, 05:15 PM   #2019
FlyingPig
FlyingPig's Avatar
Oddometer: 68
If you still have the 44s and would like to offload them for a good price, I have a project bike I'd love to use them on
When was the last time you checked your tire pressures?
FlyingPig is offline   Reply With Quote
Old 02-07-2012, 09:24 PM   #2020
RoundOz
Plenty of seasoning
Oddometer: 1,004
I don't think that the HB switch normally went to ground on any bike I have owned, so another small wiring change, or tie a relay onto the HB wire and use the relay to switch violet to ground. Otherwise a very helpful diagram for those who are lucky enough to not have to corral electrons 40 hrs a week. Well done.
2009 KTM Adventure
RoundOz is offline   Reply With Quote
Old 02-08-2012, 05:54 AM   #2021
sanjoh OP
Purveyor of Light
sanjoh's Avatar
Oddometer: 5,040
Ground shown for illustration only, the violet lead goes to +12v on the high beam.
Thanks.
Old 02-08-2012, 04:01 PM   #2022
RoundOz
Plenty of seasoning
Oddometer: 1,004
[QUOTE=sanjoh;17937077]Ground shown for illustration only, the violet lead goes to +12v on the high beam.
QUOTE]
ok...that makes sense
2009 KTM Adventure
Old 02-09-2012, 07:41 AM   #2023
Rapid Dog
Rapid Dog's Avatar
Oddometer: 9,453
Question
Is there a wiring diagram in this thread for without a dimmer?
Rapid Dog is offline   Reply With Quote
Old 02-09-2012, 09:12 AM   #2024
sanjoh OP
Purveyor of Light
sanjoh's Avatar
Oddometer: 5,040
How do you want to control the lights? On/off switch, on with high beam only or ?
Old 02-09-2012, 12:53 PM   #2025
Rapid Dog
Rapid Dog's Avatar
Oddometer: 9,453
Just a switch on/off would do, but better if hooked into the switched power.
Times are GMT -7.   It's 04:04 PM.
