Old 03-05-2012, 06:31 AM   #2131
sanjoh OP
Purveyor of Light
sanjoh's Avatar
Oddometer: 5,368
Originally Posted by n16ht5 View Post
Got my M60 mounted on my WR450F... awesomeness!!
(coupled with my HID, HI setting on my bars)
LO setting (HID only)
OEM WR450F headlight
as you can see the M60 is brighter than my HID... and the HID is VERY BRIGHT! I am very pleased.
It is mounted to my top triple on the fork clamp bolt
Looks great, thanks for posting the pics.
How would you describe night time trail riding with the light? Do you have it wired to come on with high beam only or ?
ADVmonster...BLOG....Dirt Ninja Build...TAT 08
Old 03-05-2012, 08:57 AM   #2132
sanjoh OP
Purveyor of Light
sanjoh's Avatar
Oddometer: 5,368
Red prismatic lens on 10 watt led
Pics as promised, this is a 450 lumen, 10 watt, 3 leds. Please excuse the mess, we had a marathon wrenching session this weekend.
Running and brake only, aftermarket taillight on a Ninja 650rr
Running, Brake and led lights, tough to capture without overexposure.
Too the rear
Running and brake with led light
You can see that I don't worry much about folks not seeing my brake lights
Old 03-05-2012, 09:43 AM   #2133
n16ht5
ride the night
n16ht5's Avatar
Oddometer: 2,422
thanks, it comes on with the high beam.. well it is the hi beam.. I use a lo only HID, so this works out perfectly.. the HID stays on via relay with the LED on HI which gives nice coverage.
. I only had time for a spin in the yard.. Tonight or tomorrow I will strap my gopro on and take it down to the local trails for ya. I already know it is going to be a blast... no more riding past my light.
n16ht5 is offline   Reply With Quote
Old 03-05-2012, 01:17 PM   #2134
Bobmws
Curmudgeon At Large
Bobmws's Avatar
Oddometer: 1,398
Too the rear
Very nice Sanjoh! You sent me the info on the prismatic red lens, but I don't see the light itself listed on your site. Where can I find it?
Bob Weis 04 K12RS - Hannigan Hack
Everything happens for a reason, but sometimes the reason is you're stupid and make bad decisions.
Photo's: http://s1077.photobucket.com/albums/w464/Bobmws/
www.earplugco.com
Bobmws is offline   Reply With Quote
Old 03-05-2012, 01:39 PM   #2135
mrfixit54016
Wisconsin Dual Sporter
mrfixit54016's Avatar
Oddometer: 679
How is the Daylight performance? I think the LEDs always look brighter in the dark, but the LED turn signals and brakelights usually look dimmer to me in the sunlight.
I would love to have a brighter taillight on my XR650L, but only if it truly is brighter even in the daytime.
1993 RD07 Africa Twin
1994 XR650L farkled
1985 XL600R (sold!)
1985 XR600R tagged
1983 XL100S, 1980 XL80S, and 1985 ATC250ES
mrfixit54016 is offline   Reply With Quote
Old 03-06-2012, 02:33 AM   #2136
sanjoh OP
Purveyor of Light
sanjoh's Avatar
Oddometer: 5,368
Will let you know when the lens is posted.
The daytime performance is great. The main reason I put it on is the aftermarket led tailightl is marginal and the "integrated" turn signals are a joke. Where would you mount the light on your XRL?
Old 03-06-2012, 12:48 PM   #2137
hammick
hammick's Avatar
Oddometer: 2,086
Pretty sure I am going to buy either a set of the model 44 floods or the model 60 floods and run them on my K1600GT engine bars.
Does anyone have experience with both models. I don't mind spending the extra cash for the model 60s but don't want to go completely overkill either.
Either way I'll probably use the remote dimmer with high beam overide.
2015 R1200 GSA; 2015 R1200R; 2014 FE501
hammick is offline   Reply With Quote
Old 03-06-2012, 03:01 PM   #2138
Weekend Warrior
Weekend Warrior's Avatar
Oddometer: 129
I have a set of the 44's on my Tiger 800XC with the remote dimmer control. In normal mode which is probably 30-40% in the day they are noticable to fellow riders etc and in high beam they provide incredible brightness. I have not seen the 60's but the 44's will give your bike all the light it ever needed and then some. The stock lights look yellow and dull in comparison and they are actually pretty good lights by themselves. Pay the extra for the heavy duty brackets. They are double the thickness and I could see the regular ones being a little flimsy in comparison.
With either the 44's or 60's you will blind people when they are full power so be careful.
Great addition to my bike, pictures a dozen or so pages back on this thread. You can't go wrong with either.
Weekend Warrior is offline   Reply With Quote
Old 03-06-2012, 03:51 PM   #2139
Throttle-jockey
Throttle-jockey's Avatar
Oddometer: 63
Are Cree LEDS used on the model 44?
Throttle-jockey is offline   Reply With Quote
Old 03-06-2012, 06:58 PM   #2140
sanjoh OP
Purveyor of Light
sanjoh's Avatar
Oddometer: 5,368
Yes, XP-G R5
Old 03-06-2012, 07:05 PM   #2141
Throttle-jockey
Oddometer: 63
Thanks for the reply!
Old 03-07-2012, 04:38 AM   #2142
MN_Smurf
Capt_Confusion
MN_Smurf's Avatar
Oddometer: 2,765
sanjoh, I don't know how you guys stay in business.....I placed and order at 2:24 yesterday afternoon and it took you guys 13 minutes to ship it. That is simply not fast enough......
Of course, I'm kidding.....thanks for the tremendous service.
'09 Kawi Versys
"A life is like a garden. Perfect moments can be had, but not preserved, except in memory. LLAP" - Leonard Nimoy
MN_Smurf is offline   Reply With Quote
Old 03-07-2012, 07:13 AM   #2143
FlyingPig
FlyingPig's Avatar
Oddometer: 68
Hmm. Would heat build-up from a lack of airflow if mounting one to the rear be an issue? Or should it be fine since using the light dimmed as an aux running light would not cause enough heat to be an issue? I'm thinking I could drill a hole through part of my rear fender for one light and mount it flush with the fender. What do you think?
Oh, and I just got a new dslr in the mail yesterday. It takes much better pics than my old dslr in low light conditions, so maybe this weekend, I'll settle down and take some real pics of the lights to help show the perceived difference in light output
When was the last time you checked your tire pressures?
FlyingPig is offline   Reply With Quote
Old 03-07-2012, 07:57 AM   #2144
sanjoh OP
Purveyor of Light
sanjoh's Avatar
Oddometer: 5,368
Originally Posted by MN_Smurf View Post
sanjoh, I don't know how you guys stay in business.....I placed and order at 2:24 yesterday afternoon and it took you guys 13 minutes to ship it. That is simply not fast enough......Of course, I'm kidding.....thanks for the tremendous service.
Thanks for your business. The quick shipping has been directly attrbuted to café cubano
Old 03-07-2012, 08:03 AM   #2145
sanjoh OP
Purveyor of Light
sanjoh's Avatar
Oddometer: 5,368
Less of an issue than mounting it forward, with a rearward facing light, the heatsink is now in the "front" which is a better scenario for cooling. I don't see it as an issue.
Need a pic to better understand what you are asking DSLR
Times are GMT -7.   It's 01:25 AM.
