Old 03-14-2012, 04:39 AM   #2161
sanjoh OP
Purveyor of Light
sanjoh's Avatar
Oddometer: 5,132
Originally Posted by marcopolos View Post
HAA! Blind them right into me at a stop light!
The red mutes the output so it's not as "blinding". I find most folks stop well short due to the force-field emanating from Dirt Ninja
Here's a side shot of the light, just under the rack, to the right of the givi.
Old 03-14-2012, 11:49 AM   #2162
Callahan
Callahan's Avatar
Oddometer: 1,181
Love the maroon frame with black engine guard.
Callahan is offline   Reply With Quote
Old 03-15-2012, 01:37 PM   #2163
sanjoh OP
Purveyor of Light
sanjoh's Avatar
Oddometer: 5,132
Found that under all the Georgia clay from the last trip.
Old 03-15-2012, 02:09 PM   #2164
Callahan
Callahan's Avatar
Oddometer: 1,181
Is it Powder Coated or Painted ?
and
How does it hold up to scratches and scrapes ?
I am thinking of re-coloring my frame.
Old 03-15-2012, 07:27 PM   #2165
marcopolos
Oddometer: 10
does this work
Does anyone have the 60s mounted on to this made for the KLR and could you post a pic. I am not sure why my previous post of this was removed. Please explain. Thanks.
marcopolos is offline   Reply With Quote
Old 03-15-2012, 07:53 PM   #2166
sanjoh OP
Purveyor of Light
sanjoh's Avatar
Oddometer: 5,132
Marcopolos please contact the vendor you purchased the brackets from. Hint, I don't sell those brackets
Old 03-16-2012, 03:28 AM   #2167
Sunday Rider
Adventurer Wanabe
Sunday Rider's Avatar
Oddometer: 778
Hi Sanjoh,
Is that new red "lens" the prismatic one you spoke of earlier? I thought for some reason it was a stick on type thingie. I wanted to attach it to the rear brake light. Is that possible?
'97 Honda ST1100
Sunday Rider is offline   Reply With Quote
Old 03-16-2012, 04:38 AM   #2168
sanjoh OP
Purveyor of Light
sanjoh's Avatar
Oddometer: 5,132
Originally Posted by Sunday Rider View Post
Hi Sanjoh,
The prismatic lens is in the works, it will be attached to the lens. This one is a lens replacement.
Old 03-16-2012, 11:59 AM   #2169
beechum1
Grimace Soup
beechum1's Avatar
Oddometer: 8,358
Can't wait to get my 2 30's and 2 60's mounted. I'll disrupt all the cell phones nearby with solar flares....
Originally Posted by Boondoggle View Post
Watching Dakar is like watching people who've built their own world, and for just a couple of weeks they get to live in it.
Old 03-16-2012, 02:33 PM   #2170
M_A_K_O
M_A_K_O's Avatar
Oddometer: 31
Hi i bought the dimmer and I am not sure how to connect the bypass wire on 1200 gs. In the switch is a lot of wires and I don't want to cut them unless I am 100%sure which wire is the right one. Can someone help me please?
No brain, no pain
M_A_K_O is offline   Reply With Quote
Old 03-16-2012, 07:27 PM   #2171
Sunday Rider
Adventurer Wanabe
Oddometer: 778
Thanks, looking forward to it then.
'97 Honda ST1100
Old 03-17-2012, 04:27 AM   #2172
FlyingPig
FlyingPig's Avatar
Oddometer: 68
Hey Sanjoh, I noticed that one of my lights has condensation on the inside of the lens while the other is perfectly clear. Should I be concerned? I thought these are supposed to be water/weatherproof? I have been riding in the rain for what it's worth
When was the last time you checked your tire pressures?
FlyingPig is offline   Reply With Quote
Old 03-17-2012, 06:13 AM   #2173
Cmyers
Oddometer: 30
FlyinPig: For what its worth in rain or even heavy fog my lights have always ended up with some condensation inside; thankfully it doesn't seem to affect the lights - yet.
95 Nighthawk 750
93 Nighthawk 750
Living Life in the Wind
Cmyers is offline   Reply With Quote
Old 03-17-2012, 01:56 PM   #2174
Yellow Pig
Allergic to Asphalt!
Yellow Pig's Avatar
Oddometer: 7,508
I'm sold on them. The addition of the dimmer that alows a hi power/low power setting and has a high beam override switch is the ticket.
I have installed this set up on both my Super Enduro and my Super Duke.
Old 03-17-2012, 03:55 PM   #2175
bandera
Oddometer: 17
Guys I could use some help.
I installed a pair of model 60s along with the wireless LED dimmer/high beam bypass into a 2008 BMW K1200GT.
The installation went fine and the lights are amazing, but every single time I turn them on I get a Brake Failure warning on my dash. It even knocks out the cruise control when I switch them on.
To clear the brake failure light I have to shutdown and restart the bike.
The GS-911 is throwing and storing ABS codes, but I can clear them by shutting down the bike.
I do not have any codes or brake failure lights so long as I keep the M60s DARK. Well that sucks, eh?
Ok - onto what I tired --none of it was successful.
  1. Swapped batteries - zip, same problem.
  2. Rerouted the wiring away from the front harness - nope.
  3. Pulled the wireless box and wired it to a spare AutoSwitch designed for the K1200GT - same problem.
To say I am pissed off is an understatement.
I hope that someone reading this will see the error of my ways and clue me in to where I've gone wrong.
I was about an inch away from pulling them out of the bike today and running them over with my truck.
Any help you can throw my way will be much appreciated.
I guess on the bright side is I have the brackets and wiring in place for a set of ClearWater lights.
Cheers!
bandera is offline   Reply With Quote
Times are GMT -7.   It's 10:47 PM.
