03-20-2012, 10:48 AM
#2191 | |
Oddometer: 68
Also, interesting with the double o-rings. I was always under the impression that there should only be one mated to two surfaces, never to each other.
When was the last time you checked your tire pressures? |
03-20-2012, 12:38 PM
#2192 | ||
Purveyor of Light
Oddometer: 3,665
The oring on the body of the light seals the bezel/body and keeps stuff out of the threads. The oring in the bezel seal the lens/bezel. Kind of an oring sandwich, the two orings do not come in contact with each other.
Model 60 LED 3600 lumens . . LED thread in Vendors Dualsport Fairing w LED...Dirt Ninja Build...TAT 08... |
03-20-2012, 03:30 PM
#2193 |
Oddometer: 50
Here you go.
03-20-2012, 03:56 PM
#2194 |
Purveyor of Light
Oddometer: 3,665
Crash bar mounts n lights from inmate islano
03-20-2012, 04:05 PM
#2195 |
Purveyor of Light
Oddometer: 3,665
It looks like you are really close to an optimal position. If you only need a few degres of movement, I would grab the light and gently bend the bracket. If you are more than a few degrees, I'd recommend unscrewing the heatsink and flipping the mount bracket 180 degrees.
Could you describe the flickering you are seeing with the lights? Does it happen with the high beam on?
03-22-2012, 04:26 AM
#2196 | |
Oddometer: 50
The flickering happens when they are dimmed, kind of like a pulsing. It doesn't happen if they are almost full power. More on the left side which has longer wires going to it. (farther away from the dimmer) Also is it normal to not be able to get full power using the dimmer unless you hit high beam? |
03-22-2012, 04:43 AM
#2197 | ||
Oddometer: 16
By the way, I am helping another guy out at the K-Bike community with the exact same problem--switching on the lights throws an ABS Brake failure warning and knocks out his cruise control. My next step is to take the advice of an inmate and completely isolate them from the bike. I hope this works because they go in the trash after that. |
03-22-2012, 07:09 AM
#2198 | |
Oddometer: 68
03-22-2012, 05:33 PM
#2199 |
Adventuring Creep
Mine also flickered, for about 50 miles, then both lights turned off! Turned out the ground terminal had broken! Does sound like the same issue others are dealing with, but always worth a thought!
'99 KTM 640 Adventure R ***************************************** East Bay Weekly Coffee ***************************************** Support your local creep! CREEPS MC |
03-23-2012, 02:44 AM
#2200 | |
I Ride Ms Piggy
Oddometer: 1,798
viz |
03-23-2012, 07:04 AM
#2201 |
Soyez sans que peur
Oddometer: 276
ordered @ 10:00pm last night -- shipped this morning.
Bokrijder
KTM450EXC KLR650 BMW R50/2 |
03-23-2012, 08:00 AM
#2202 |
Soyez sans que peur
Oddometer: 276
Sanjoh
Possible to get a green lens for the helmet light ? I know, what will they ask for next. Do have a good reason and with research others may find the same. My eyes are most sensitive to green light. I've done lots of experimenting with this - for me, green gives the best definition of fine detail. White/blue for distance - green for closer detail. I'm not colorblind but red is a dud for my eyes. Another step in fine tuning the bikes lighting. Bokrijder
03-23-2012, 09:13 AM
#2203 | ||||
Purveyor of Light
Oddometer: 3,665
If you are unhappy with the dimmer, I will replace it, LMK Quote:
03-23-2012, 01:12 PM
#2204 | |
Purveyor of Light
Oddometer: 3,665
03-23-2012, 02:22 PM
#2205 | |
Soyez sans que peur
Oddometer: 276
Bokrijder
