03-23-2012, 11:30 PM
#2206 |
Oddometer: 165
I have installed a flood and spot, switch and dash light on my 07 1200GS.
I will be using a 5 pin relay as per an earlier post on this thread. My only question is where to tap in to the high beam circuit to get the switching signal for the relay. I'm not keen on drilling the waterproof cap behind the high beam light. I've searched this thread using a few parameters but no luck yet.
Cheers Rich 07 R12GS/A Hybrid 03 CBR954RR |
03-24-2012, 05:45 AM
#2207 |
Purveyor of Light
Oddometer: 3,711
![]() Live from the Frostproof Bikefest. Frostproof, FL
Model 60 LED 3600 lumens . . LED thread in Vendors Dualsport Fairing w LED...Dirt Ninja Build...TAT 08... |
03-24-2012, 07:20 PM
#2208 | |
Smile 4 Miles
Oddometer: 1,376
03-25-2012, 11:49 AM
#2209 |
Oddometer: 165
Many thanks for that Tallguy.
That looks like a good solution.
03-26-2012, 04:48 AM
#2210 |
Oddometer: 16
Last update for me.
The 60s interfere with the electrical system of the 2008 K1200GT under any configuration--by pass box, autoswitch trigger with relay, and separate circuit with a relay and manual switch all induce the same interference. It must be something the lights emit, or the unshielded wiring? I just don't know and I never did get a response from the vendor. By the way Clearwater lights guarantees their lights will work with the K12GT. They are much more $$, but if you have a K12GT and want LED's this may be a better option. Cheers! |
03-26-2012, 08:53 AM
#2211 | |
Oddometer: 1,508
CANBUS. Is it the German word for crap?
![]() Quote:
#2212 | |
Oddometer: 68
When was the last time you checked your tire pressures? |
03-26-2012, 10:21 AM
#2213 | |
Purveyor of Light
Oddometer: 3,711
03-26-2012, 03:31 PM
#2214 | |
Oddometer: 165
It was made a little more difficult because I have a Touratech dash panel with power outlets. This meant removing the screen, instruments and dash panel. After routing the relay trigger wire through the vent plug I pared back the insulation on the white wire to the headlight connector, soldered the trigger wire on and wrapped the joint in insulation tape. Now I have it all connected via a 5 pin relay with a push switch and indicator light in the dash surround as per the wiring diagram earlier in this thread. Took a couple of hours and it all works. No CANBUS errors so far.
03-26-2012, 05:08 PM
#2215 | |
Oddometer: 16
One quick follow-up. I got the lights to work! Not on my K12GT, but on my 1995 BMW R1100RSL. So they are keepers and will burn holes through the Texas deer during my night excursions on the old RSL. |
03-27-2012, 01:57 AM
#2216 | |
I Ride Ms Piggy
Oddometer: 1,800
viz |
03-27-2012, 02:08 AM
#2217 |
I Ride Ms Piggy
Oddometer: 1,800
Sanjoh - having used these lights for a while now - a couple of observations:
Lights are bright - seriously bright. If you are on a narrow road with lots of growth on the side you get a lot of reflection back which makes the centre of the road a bit dark - the upside is though you can see the sides a lot more and the suicide 'roos and wombats a lot earlier (in Oz - yes we have deer and buffalo and beef here too, but they seem to have more sense) What I need is a spot that is longer ranged and more focussed than the 30's that are currently on offer, to fill up that black hole in the centre. The 10's were useless in my setup - drowned out by the more powerful wides. How about 60 spots - and true spots that are focussed some distance from the source, without light scatter to the sides? Great lights - I am always getting people asking me about them. A little more refining and they will be truly great viz |
03-27-2012, 08:20 AM
#2218 | |
Purveyor of Light
Oddometer: 3,711
03-27-2012, 07:25 PM
#2219 |
Purveyor of Light
Oddometer: 3,711
Harleys need lights to
03-28-2012, 03:32 AM
#2220 | |
Purveyor of Light
Oddometer: 3,711
