Old 04-26-2012, 06:27 AM   #2296
MotoTex
Miles of Smiles
MotoTex's Avatar
Oddometer: 1,710
Originally Posted by Callahan View Post
PICS pics,,,, just a couple would be great
Here ya go.
This is the broken Heavy Duty bracket on the light.
This is the broken HD bracket, foot-end.
This is the opposite light's broken foot on the old-style mount.
John is sending replacements and I'm upgrading to the new version of the bar mounts to provide a wider mounting surface for the foot of the mounting bracket.
ADV Monster rules!
This is The Internet. Confirm for yourself anything you may see while visiting this strange and uncertain land.
MotoTex is offline   Reply With Quote
Old 04-27-2012, 02:59 AM   #2297
sanjoh OP
Purveyor of Light
sanjoh's Avatar
Oddometer: 5,202
I'd recommend you check your motor mounts. The vibration needed to fracture the HD mount is significant.
Old 04-27-2012, 11:42 PM   #2298
blues_bleu
Oddometer: 145
hi guys,
sorrie.
just wanna check have anyone compare these led light to the HID spot and fog lamp. maybe the hella micro de and the FF50.
which is better??
thanks!
blues_bleu is offline   Reply With Quote
Old 04-28-2012, 07:30 AM   #2299
tallguy-09
Smile 4 Miles
tallguy-09's Avatar
Oddometer: 1,436
Originally Posted by blues_bleu View Post
hi guys,
sorrie.
just wanna check have anyone compare these led light to the HID spot and fog lamp. maybe the hella micro de and the FF50 which is better??
thanks!
I'd say LED's win over HID and other lights.
They can be easily dimmed (PWM) and don't mess with the bike electronics. They are not that heavy either.
I'm using the model 60 with dimmer and high-beam override, can't do that with HID.
Ducati Panignale first motorcycle with LED headlights.
Common to all the Ducati 1199 Panigale superbikes, the LED headlight really is something to behold. In its low-beam setting, the two groupings of LEDs near the center of the Panigale’s nose illuminate the way ahead. They are noticeably bright, with a slightly bluish hue. Flipping the switch to the high-beam setting though, and the lux value doubles by our estimates, with the entire headlight array projecting photons. Sources have told us that the entire headlight package is very thin, and surely there is some significant weight savings occurring here because of the LED implementation.
No Ducati here but my pig with model 60 in ~40% dimmed brightness
tallguy-09 screwed with this post 04-30-2012 at 06:52 PM
tallguy-09 is offline   Reply With Quote
Old 04-28-2012, 08:16 PM   #2300
viz
I Ride Ms Piggy
viz's Avatar
Oddometer: 1,813
Originally Posted by tallguy-09 View Post
What's that LED array in the radiator opening??
viz
Pig In The City - 2010 BMW R1200 GSA Adventure
Webmaster BMW Touring Club of NSW
viz is offline   Reply With Quote
Old 04-28-2012, 09:00 PM   #2301
tallguy-09
Smile 4 Miles
tallguy-09's Avatar
Oddometer: 1,436
viz
DSLR. Reflection of the LED array, kind of weird but that always happens when taking pictures of the lights.
Edited the picture and removed that reflection...
tallguy-09 screwed with this post 04-30-2012 at 06:53 PM
Old 04-30-2012, 03:44 AM   #2302
viz
I Ride Ms Piggy
viz's Avatar
Oddometer: 1,813
That does my head in trying to think what would cause that - internal reflection from somewhere... I have a DSLR as well - will have to have a look next time if that happens to me too.
viz
Old 04-30-2012, 04:40 AM   #2303
RoundOz
Plenty of seasoning
Oddometer: 1,014
viz
Pretty common with older dslr's with pix of bright light sources. Not sure if the newer ones prefilters or photosite arrangements have fixed this...
2009 KTM Adventure
RoundOz is offline   Reply With Quote
Old 04-30-2012, 07:09 AM   #2304
NovaMoto
Oddometer: 133
Here's a shot of 690ER with a model 44 grafted into the OEM mask. I used some 303 stainless plate & ground/cut/bend large 'winged' washer that I attached to the original mount points in the mask. The fit is tight & I'm truly impressed with the results. The photo below will give you an idea of full brightness (looking into the beam). I set low beam (via Skene's IQ170 - thanks, Jerry!) at 40% & oncoming traffic hasn't given me a second look with the current aim & low scatter I've achieved with this combo.
NovaMoto is offline   Reply With Quote
Old 04-30-2012, 08:28 AM   #2305
tallguy-09
Smile 4 Miles
tallguy-09's Avatar
Oddometer: 1,436
Darn, that was an expensive Nikon D300 but I guess time goes by and what was expensive 3 years ago is dirt cheap and old in 2012...otherwise best digital I've ever owned.
Old 04-30-2012, 11:20 AM   #2306
sanjoh OP
Purveyor of Light
sanjoh's Avatar
Oddometer: 5,202
Very Nice!
How bout some closeups on the mounting?
We will be introducing a rotary dimmer (1.5"x1.2"x.8" or 38mmx31mmx20mm) with high beam bypass that might be a bit easier than having to program the dimming levels.
Old 04-30-2012, 12:34 PM   #2307
Low594
Adventuring Creep
Low594's Avatar
Oddometer: 1,157
Sweet! ETA? Projected cost?
Low594 is offline   Reply With Quote
Old 04-30-2012, 03:16 PM   #2308
cjb4u
Oddometer: 11
Originally Posted by sanjoh View Post
Very Nice!
That kinda stinks I just got the remote dimmer today.
I have read most all of this thread over the past year. Wow that is a ton of info.
this is my first post and I have a few questions. 1 I got a voltmeter with is it is sixty's and a dimmer. what do you hook the third wire voltmeter up to?
cjb4u is offline   Reply With Quote
Old 04-30-2012, 03:20 PM   #2309
sanjoh OP
Purveyor of Light
sanjoh's Avatar
Oddometer: 5,202
End of May, pricing around $30 tbd.
Old 04-30-2012, 03:23 PM   #2310
sanjoh OP
Purveyor of Light
sanjoh's Avatar
Oddometer: 5,202
Originally Posted by cjb4u View Post
What do you hook the third wire voltmeter up to?
From the product page. Three wire connection: Red power, Blue voltage signal, Black ground
Thanks for your business.
Times are GMT -7.   It's 02:03 AM.
