Old 04-30-2012, 03:27 PM   #2311
GsVs
Goin' Somewhere
GsVs's Avatar
Oddometer: 1,407
Dimmer !
Fantastic -- that's what alot of us have been looking for ...
Originally Posted by sanjoh View Post
Very Nice!
How bout some closeups on the mounting?
We will be introducing a rotary dimmer (1.5"x1.2"x.8" or 38mmx31mmx20mm) with high beam bypass that might be a bit easier than having to program the dimming levels.
Honda
GsVs is offline   Reply With Quote
Old 04-30-2012, 04:22 PM   #2312
tallguy-09
Smile 4 Miles
tallguy-09's Avatar
Oddometer: 1,436
Nice John! Are you considering a display or scale so you know what settings you've selected?
tallguy-09 is offline   Reply With Quote
Old 04-30-2012, 04:29 PM   #2313
Sunday Rider
Adventurer Wanabe
Sunday Rider's Avatar
Oddometer: 783
End of May, pricing around $30 tbd.
Great idea John, Can't wait. I tried one from my heated clothing, but all it did was flash the lights and not dim too much
I assume it will be water proof?
'97 Honda ST1100
Sunday Rider is offline   Reply With Quote
Old 04-30-2012, 04:33 PM   #2314
christian
Exchange your GPS Track!
christian's Avatar
Oddometer: 2,656
1- Waterproof would be great
2- price ~$30 would be great
3- indicator would be great - but I'd rather have the $30 price tag
we can make little marks on the body and knobs to do 25% / 50% / 75%
KTM 950 ADV '05.5
KTM 690 '10
christian is offline   Reply With Quote
Old 04-30-2012, 04:36 PM   #2315
cjb4u
Oddometer: 11
From the product page. Three wire connection: Red power, Blue voltage signal, Black ground
Thanks for your business.
sorry I am going to show my lack of understanding could you give me an example of voltage signal. I thought the positive wire on my battery would be that.
cjb4u is offline   Reply With Quote
Old 04-30-2012, 05:03 PM   #2316
sanjoh OP
Purveyor of Light
sanjoh's Avatar
Oddometer: 5,203
That's the goal. Still being tested but looks good.
It will have a bluetooth as well and an i7 just in case you want to design the next one while riding.
Voltage signal is the source you want to measure. Your battery is a source, it will work fine with that connection. The red wire hooked up to switched power (power that comes on with the key) will have your meter on and off with the bike. If you want to hook both up to the same switched power, that is fine as well but it will likely show a reduced reading than when connected directly to the battery due to voltage loss from the oem wiring.
Old 04-30-2012, 06:28 PM   #2317
Callahan
Callahan's Avatar
Oddometer: 1,181
Hey John,
Any chance the wiring could be set to exit out of the bottom ??
Callahan is offline   Reply With Quote
Old 04-30-2012, 06:47 PM   #2318
tallguy-09
Smile 4 Miles
tallguy-09's Avatar
Oddometer: 1,436
"It will have a bluetooth as well and an i7 just in case you want to design the next one while riding"
Maybe make it voice controlled by Apple Sushi? or whatever it's called again
Old 04-30-2012, 07:20 PM   #2319
cjb4u
Oddometer: 11
dimmer help
Ok I am now officially needy!!!
Just installed 2 60s with the remote dimmer and a new led head light. but the dimmer does not work!!!!
In fact when I can not even turn them off or on but when I hit the bright the 60s go out and the dimmer makes a bad buzz. PLEASE HELP ME!!! What did i do wrong?
Old 04-30-2012, 07:38 PM   #2320
sanjoh OP
Purveyor of Light
sanjoh's Avatar
Oddometer: 5,203
Originally Posted by Callahan View Post
Hey John,
Not at this time, no room
Please call me tomorrow 9549935581.
Check the wiring schematic here.
Old 05-01-2012, 07:27 AM   #2321
cjb4u
Oddometer: 11
HEY I got it fixed and it was my fault as I figured. Guess you have to ground it properly. I used the existing wire harness that was from my current set of lights and the ground tied in on the way to the lights and I ended up not getting the input of the dimmer grounded. Being Grounded always helps. That sounds like something my dad would have said.
http://youtu.be/e5ZdLR18wHs
Sorry I guess I do not know how to embed a video on here.
Old 05-01-2012, 08:53 AM   #2322
sanjoh OP
Purveyor of Light
sanjoh's Avatar
Oddometer: 5,203
Embeded video is working fine.
Glad to hear you got the wiring straightened out.
FYI, the strobing seen in the video is not visible to the human eye.
Old 05-01-2012, 11:46 AM   #2323
Low594
Adventuring Creep
Low594's Avatar
Oddometer: 1,157
PM sent about your headlight, so as to not hijack Sanjohs thread!
Low594 is offline   Reply With Quote
Old 05-01-2012, 06:57 PM   #2324
Small's
Oddometer: 330
Question 44's
What is the beam angle on the 44's? Just curious..
Small's is offline   Reply With Quote
Old 05-02-2012, 03:36 AM   #2325
sanjoh OP
Purveyor of Light
sanjoh's Avatar
Oddometer: 5,203
Check out the detailed description on the product page.
Times are GMT -7.   It's 03:40 AM.
