Old 06-03-2012, 09:04 AM   #2386
C-Stain
C-Stain's Avatar
Oddometer: 6,413
Originally Posted by sanjoh View Post
That's the first reasonbly priced light bar I've seen. How has it held up?
It's been on for a year, over the TLH and survived numerous "naps". So far so good!
Originally Posted by Mr_Gone View Post
C-Stain is wise.
C-Stain is offline   Reply With Quote
Old 06-04-2012, 11:23 AM   #2387
sanjoh OP
Purveyor of Light
sanjoh's Avatar
Oddometer: 5,268
Another satisfied customer.
Wow
ADVmonster...BLOG....Dirt Ninja Build...TAT 08
Old 06-06-2012, 09:15 AM   #2388
GP1200
Oddometer: 379
Thanks for your business, look forward to the pics. Contact me if you need any install help.
Will be available next week, parts are on the way so we can build em.
I noticed your manual dimmer is available. How does this mount to the bike ? I own a 2010 GSA
GP1200 is offline   Reply With Quote
Old 06-06-2012, 10:22 AM   #2389
sanjoh OP
Purveyor of Light
sanjoh's Avatar
Oddometer: 5,268
The rotary dimmer is a surface mount. You can use double sided tape, velcro, silicone or your choice. Here it is mounted on a BMW F650. The box is velcroed to the brake master cylinder.
Old 06-06-2012, 10:31 AM   #2390
Callahan
Callahan's Avatar
Oddometer: 1,181
Rotary Dimmer question
Does the Rotary Dimmer also function as - OFF, turn(click) to On, turn up to full brightness , type of control ?
Callahan is online now   Reply With Quote
Old 06-06-2012, 11:20 AM   #2391
sanjoh OP
Purveyor of Light
sanjoh's Avatar
Oddometer: 5,268
Yes, however it has a high beam bypass so you get the dimmed setting while having full power available with your oem switch. I recommend using a switched power source that comes on with the bike so you don't need to turn it off and on each time you are on/off the bike.
The dimmer uses pulse width modulation to dim the lights so it is very efficient.
Old 06-06-2012, 12:33 PM   #2392
Callahan
Callahan's Avatar
Oddometer: 1,181
Sanjoh,
Thanks for the answer.
I am going to be putting additional lights on my bike soon for backcountry night vision. Maybe your Model 60 LED x2.
Trying to keep the number of switches/wiring/electronics to a minimum, i.e. I already have several items which I think is enough.
Also molding/building a carbon fiber dash panel to mount items on, as listed left to right row by row.
top row - Roll Chart Holder (lighted) - GPS - Odometer (lighted)
bottom row - WaterResistant 12v Power Socket - Push Button WaterResistant Power Switch for lights to R.C.H. & Odo. - Push Button WaterResistant Power Switch for power to GPS with Red Snap-In LED Panel Mount Indicator mounted above it - Rotary LED Dimmer (hopefully no additional switch needed) - USB WaterResistant (double) Power Socket (lighted)
Sanjoh and or anybody , Correct me if I am wrong here, please as I am on a XR-R , with no battery , not looking for a High Beam Bypass , not looking to put on a power switch to LED lights , i.e. if the Rotary Dimmer will dial all the way to off, which is what I think Sanjoh has already answered.
- Power from Stator to Regulator/Rectifier to Dial Switch Controller to Diode (protected) Relay to Light/s
Callahan screwed with this post 06-06-2012 at 01:04 PM
Old 06-07-2012, 04:56 AM   #2393
sanjoh OP
Purveyor of Light
sanjoh's Avatar
Oddometer: 5,268
Which part of Yes is not clear? Have you bothered to read the product information ?
Addtional Lights with 2 model 60s You won't realize you have other lights once the 60s are on.
Why waist your time, just go for our Dual Sport Faring with 2 Model 60s in it, you won't need any additional light. Sounds like whatever you are using is not meeting your needs?
No need for the relay on your suggested wiring. I will suggest you put in a large capacitor to absorb some of the lows and highs of the charging system, I'm sure you've seen the large thread on XRR electricity.
Old 06-07-2012, 07:26 AM   #2394
Callahan
Callahan's Avatar
Oddometer: 1,181
LIKE THIS PIECE OF INFO,
Rotoray detent in off position.
Why waist my money as I may not want to spend more money on another dual sport kit and the two lights.
Have you considered I might like to have the current DS kit on one power 125W output and MAYBE your 60's on the other 125W power output. I have had a problem with Stator power before and crash more often at night (particularly when in silt/sand),
I guess as you are a salesman (?) I would think you would applaud the idea of more lights on a bike.
Thank you for the suggestion of the Capacitor.
Old 06-07-2012, 09:47 AM   #2395
M1Jeep
M1Jeep's Avatar
Oddometer: 1,958
Is there a pic of this dual sport faring? Pricing also? I don't see one on your website. TIA!
Rich
My YouTube
M1Jeep is offline   Reply With Quote
Old 06-07-2012, 10:00 AM   #2396
sanjoh OP
Purveyor of Light
sanjoh's Avatar
Oddometer: 5,268
Check this thread for more info, including ballpark pricing. Not on the website yet, look for it next week
Thanks for the interest.
Old 06-07-2012, 10:12 AM   #2397
sanjoh OP
Purveyor of Light
sanjoh's Avatar
Oddometer: 5,268
I don't need to sell anyone lights and no I'm not a salesman, I have a degree in Engineering and Math.
I am passionate about what I do! What I do know is that I would rather ride a bike that has less weight, any time you add something to a bike, well guess what, you just increased the weight. Having had an XRR for many thousands of miles, the fairing would work well and fix your lighting issue, while providing other benefits like reducing the electical load on the stator.
Now if you would just spend more time on your XRR you might figure out where I'm comin from
From yesterdays (Wednesday about 2:00pm) ride
Old 06-08-2012, 04:16 AM   #2398
Sunday Rider
Adventurer Wanabe
Sunday Rider's Avatar
Oddometer: 806
and a PHD in Patience
'97 Honda ST1100
Sunday Rider is offline   Reply With Quote
Old 06-09-2012, 04:27 PM   #2399
MotoTex
Miles of Smiles
MotoTex's Avatar
Oddometer: 1,776
Mount Installation Problems
Received the new bar mounts, thanks!
They look great and are significantly better than the originals. I particularly like the way you have keyed the platform to which the light attaches. Very nicely done.
I'm having a problem with the installation though.
I'm using the middle sized spacer, which fits my crash bar OD perfectly. When holding the spacer halves on the bar the mating surface is a machine fit and the spacer halves have a few millimeters of compression space where they meet.
When I tighten up the two Allen head bolts to clamp things together the bolts tighten the clamp halves together solidly before any pressure is put on the spacer.
End result, the bolts are tight and the clamp halves are touching where the bolts go through, but, the clamp halves are loose against the spacer. The clamp can just spin around the spacer and the bar without restriction.
Looks like one half of the clamp could use less metal at the mating surface around the bolts so it can come together far enough to contact the spacers before it contacts the other half of the clamp.
The next larger spacer diameter is much too small for the bar, and of course the thinnest spacer (for larger diameter) is much looser once the clamp is bolted tight together.
Am I missing something obvious on this installation, or is it possible that this part was not machined to the design specification?
This is The Internet. Confirm for yourself anything you may see while visiting this strange and uncertain land.
MotoTex is offline   Reply With Quote
Old 06-10-2012, 04:56 AM   #2400
sanjoh OP
Purveyor of Light
sanjoh's Avatar
Oddometer: 5,268
Sometimes the spacers can fit fine on the crash bar. If the bar diameter is just a bit undersize it will leave the clamp a bit loose. A couple of options: add some tape to the crash bar or to the spacer, effectively increasing the diameter or remove some of the aluminum between the clamp halves.
Times are GMT -7.   It's 01:17 AM.
