Old 06-10-2012, 02:30 PM   #2401
Low594
Adventuring Creep
Low594's Avatar
Oddometer: 1,160
Originally Posted by sanjoh View Post
Sometimes the spacers can fit fine on the crash bar. If the bar diameter is just a bit undersize it will leave the clamp a bit loose. A couple of options: add some tape to the crash bar or to the spacer, effectively increasing the diameter or remove some of the aluminum between the clamp halves.
Also, you can cut shim/spacers from alum soda cans or even better bicycle inner tubes which add a bit of shock/vibration dampening!
Low594 is offline   Reply With Quote
Old 06-10-2012, 07:15 PM   #2402
MotoTex
Miles of Smiles
MotoTex's Avatar
Oddometer: 1,845
I like this idea. Lay some strips in between the clamp and spacer and not mar that sweet finish with machining! Thanks!
This is The Internet. Confirm for yourself anything you may see while visiting this strange and uncertain land.
MotoTex is offline   Reply With Quote
Old 06-10-2012, 07:33 PM   #2403
Callahan
Callahan's Avatar
Oddometer: 1,181
Callahan is offline   Reply With Quote
Old 06-10-2012, 09:17 PM   #2404
Honkey Cat
Tailights Fade!
Oddometer: 1,154
Led
I was sceptical, called and talked in person. Ordered lights and received them in a few days. Installed very easy, nice quality very bright. Very satisfied.
Uploaded from the Photobucket Android App
My favorite philosopher is Cha Ching !
Honkey Cat is offline   Reply With Quote
Old 06-10-2012, 10:04 PM   #2405
beechum1
Grimace Soup
beechum1's Avatar
Oddometer: 8,635
Installed mine yesterday. two 30's and two 60's. I'll get a few pics up here soon. But the UFO flying down the freeway on saturday night STILL wasn't enough to keep some dumb C from pulling out in front of me from the on ramp.
Originally Posted by Boondoggle View Post
Watching Dakar is like watching people who've built their own world, and for just a couple of weeks they get to live in it.
Old 06-10-2012, 11:28 PM   #2406
Rev
Asshole
Rev's Avatar
Oddometer: 278
how does the new ST dimmer, um, *dim* the light? the knob is PWM, but it doesnt say what the strobe mod does. Can we get a video of the flash modes? and lastly, do the flash modes cycle every time you press it or can you pick your fav and stick with it?
thanks!!!!
Give a man fire, and he's warm for a night.
Set a man on fire, and he's warm for the rest of his life.
Rev is offline   Reply With Quote
Old 06-11-2012, 06:46 AM   #2407
sanjoh OP
Purveyor of Light
sanjoh's Avatar
Oddometer: 5,368
Great to hear you are happy with the lights. What bike did you install them on?
ADVmonster...BLOG....Dirt Ninja Build...TAT 08
Old 06-11-2012, 06:57 AM   #2408
sanjoh OP
Purveyor of Light
sanjoh's Avatar
Oddometer: 5,368
Did the person even have a pulse? How in the... could someone miss that much light
The ST dimmer uses PWM as do all of our dimmers.
Strobe mode makes the lights strobe ie on/off with different timings, will try to post a vid.
ST Dimmer has a memory so the last setting will be maintained until changed, even if power is removed.
We recommend using switched power with this dimmer as there is no internal on/off switch. The lights can be dimmed very low.
Old 06-11-2012, 10:11 AM   #2409
sanjoh OP
Purveyor of Light
sanjoh's Avatar
Oddometer: 5,368
ST Dimmer Video
Old 06-11-2012, 10:20 AM   #2410
beechum1
Grimace Soup
beechum1's Avatar
Oddometer: 8,635
ST Dimmer Video
Yes. On the list. Thanks.
Old 06-11-2012, 10:26 AM   #2411
Rev
Asshole
Rev's Avatar
Oddometer: 278
thanks for the video. i was hoping the strobe patterns would be more like a flash then back to normal light output, but its nice and simple so ill be picking one up anyway
does the bar bracket swivel at all? looks like the allen bolt can loosen up and move about if you liked.
Old 06-11-2012, 11:11 AM   #2412
sanjoh OP
Purveyor of Light
sanjoh's Avatar
Oddometer: 5,368
The crash bar bracket does rotate to multiple angles.
Old 06-11-2012, 12:33 PM   #2413
Rev
Asshole
Rev's Avatar
Oddometer: 278
sweet. you sir, have my money. now give me light!
Old 06-11-2012, 02:22 PM   #2414
walkergreenlabel
Oddometer: 191
distance
How far do the spot lights light up the trail? I was thinking of getting one spot to wire in with the high beam for fast trails and the flood for low beam when riding slower more technical stuff.
thoughts?
walkergreenlabel is offline   Reply With Quote
Old 06-11-2012, 08:45 PM   #2415
beechum1
Grimace Soup
beechum1's Avatar
Oddometer: 8,635
Alot of cleanup to do, but you can see what it's supposed to do. Some night pics to follow. It's really hard to see the difference in lighting, so I'll do my best, maybe take a video.
beechum1 screwed with this post 06-11-2012 at 09:37 PM
Times are GMT -7.   It's 02:36 AM.
